We have a Maytag Neptune front loading washer that is not starting when the start button is pushed. It'll start for a couple seconds -- then stop. Thanks
    Sniper:
  • 88 Answers
The Neptunes are hard to diagnose without being there, so here's my best shot. It is almost definitely the main control or the motor control. First I would open the top control panel, (three screws along the top of panel) and just make a visual inspection of the ccu located in the right hand side. If there are no visible burned components, I would check the motor control board located in the bottom right side of the machine for the same. Let me know if you need steps for opening the front of the machine. I immediately suspect the motor control, as there is a Neptune motor conversion kit depending on which specific model you have, I have replaced several to solve that exact problem.
Posted on Sep 14, 2008
Maytag washer wiring diagram
machine start when you push the start button but stops 3 or 4 seconds after the button is released help me dennis montgomery maytag neptune model #mah3000aww
Aug 27, 2010 | Maytag MAH8700AWM Neptune Front Load...
Washer starts/ stops
recycle power. if problem persists, timer problem
Mar 18, 2010 | Maytag Neptune MAH5500B Front Load Washer
The lights go on, but washer will not start.
door not closed try open door and then closing again
Feb 11, 2010 | Maytag Neptune MAH5500B Front Load Washer
Won't spin or drain, have tried to rerun cycle and checked drain hose
Check pump / outlet filter , refer to instruction book , clean and replace then re- try
Nov 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Front load washer maytag stopped working during wash
the start button is part of the board their.if you hear frying noise their when pushing it there ,you may have a failling board.god bless your way.Tom
Dec 31, 2008 | Maytag Neptune MAH5500B Front Load Washer
I have the neptune front loader. The lock light wont come on and the door wont lock. During a wash cycle the water just started comming out of the door. If I hold the stop/start button manually the light...
hi there,
you have a door latch problem. the reason you can still push on the button is because this particular washer has a time delay function. i would recommend taking a look at the latch itself and possibly the wax motor that runs the latch.
Dec 04, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH4000 - Washer won't shut off!
sounds like to me you have a bad board needs to be changed
Sep 16, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune rinse cycle doesn't start.
cold water valve screen plugged or bad valve, just check it!
Aug 06, 2008 | Maytag Neptune MAH6500A Front Load Washer
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
