Question about Pyle 800W GUITAR AMP Car Audio Amplifier
My amp makes a constant tone
I have a 20watt bass amp and it was working fine, but half way trough playing it cut out and went to a constant tone (c sharp to be exact) what has happend and what can i do to fix this?
    President:
  • 3,130 Answers
Its says 800 watt and you say 20 watt bass amp?? Is this for a car or a guitar??
Posted on May 24, 2006
My technics amp SU-G75 keeps shutting off and reads OVERLOAD when played over the volume of -40 to -35. I kept playing around and it works fine when the bass dial is on half, but more bass shuts it off. I...
some amps are made more for low ohm loads (bass) and some are made for high impedence loads (mids/highs) and it seems you are asking too much from your amp.
Mar 05, 2013 | Audio Players & Recorders
My radio cuts out when i turn it up and the bass hits on my subwoofer
You are drawing to much power to the amp. I assume that there is no dedicated power fron the battery to the amp. If there is you should look into a capacitor
Feb 13, 2013 | Car Audio & Video
I just installed a Clarion NX500 in my Chevy Avalanche. I really like it a lot. The only problem that I am having is when I play either my iPod, a DVD/CD, or a bluetooth device the bass cuts out. When I...
Try turning your gain down on your amp and make sure all your settings on your deck are set to zero if there up with subs hooked up it distorts the vocal and bass
May 25, 2010 | Clarion NX500 Car Video Player
They also try to play the bass
a crossover cuts the certain tones out of the sound.example: the high side cuts out low and mid tones,or the mid side cuts out high and low. The only problems this could be is that the crossover is not set right or not wired right. These speakers should be plugged into the high side of the crossover. If wired right and set right then your crossover is no good.
Mar 23, 2010 | Kicker KS13 Car Tweeter
Why does my KAC-8404 cut off at high volume bass?
amp 101
1/0 wire to the amp or the amps will loose power
check the connections mainly the negative
wiggle the wires see if you get a cut out or not
a cap will help you give constant power to the amp and not allow them to drain on long bass notes
hope this helps
Dec 26, 2008 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Ive got no power to the amp trough the rem wire unless i connect.
You need a bigger amp and make sure its a two channel. Four and five channel amps are for mids and highs. If you want real bass get a two channel. If you dont want to buy a bigger amp, Go get a capacitor. It acts like a battery charge storage for when your sub needs to hit those real low notes. It takes a lot of power. Also if you get a capacitor your altinater that charges your battery will not have to work so hard keeping your battery charged, Thus not wearing out your altinater and not having to replace it so soon because it will happen.
Another quick fix is turning your gain down. I turn my gain up half way, maybe a little past half way. You might not get the bass hitting as hard but at least it wont shut off on you.
Nov 20, 2008 | Kicker 01C8VR4 Car Subwoofer
Amp trouble
The ohm load may be too low. What make/model amp is it?
Jul 31, 2008 | Car Audio & Video
Bass problem
You're getting some sort of capacitor discharge noise on your signal. There's no easy fix for that. It will have to be taken in for service.
Mar 16, 2008 | JVC RV-B90 Boombox
Amp cuts off
You may have a problem with the power source feeding the amp. You need to check the voltage across the amplifier's B+ and ground terminals when the amp is playing/cutting off. If it's dropping below ~11 volts, you need to determine why it's dropping so low.
Sep 18, 2007 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
PLEASE HELP!!!
The Amp stays on because you have a constant 12V to the Remote.
If your stereo remote is no longer working then run a wire from a 12 volt source that turns on and off with your ignition something like your radio fuse in the vehicle fuse box.
As far as the Bass Knob if it is connected properly and still not working check the line for wire kinks or cuts that may have happened during installation if you cant find any problems you can get a universal bass knob that plugs via your RCA cables for under 20 bucks.
Hope this gives u some ideas.
May 05, 2007 | Pyle PLA2480 Car Audio Amplifier
Pyle 800W GUITAR AMP Car Audio Amplifier Logo
69 people viewed this question
Top Pyle Car Audio & Video Experts
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
