Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
Screen there is a pink line color about 2 inch in height and it goes across the screen
  • rebel711 Oct 06, 2008
    Pink line run cross screen at top of tv end to end.
  • Anonymous Jan 04, 2009
    I have the same problem. A light pink ,cloudy back-round about 2 inches wide that goes from top to bottom in the center and wiggles around but you can still watch the tv. You have to look for it but it is there.You can see it on all inputs.
    Problem Solver:
  • 17 Answers
HI, need to see a picture of the line and need to know if you see it on all inputs and whitch ones are you using and does it do it on all of them.
If you cannot send me a picture then let me know what color is the line,is it from left to the right end of the screen and the top and the bottom of the line are they straight all the way horrizontally.
Wait your response then I will do my best to find the solution.
Posted on Sep 22, 2008
I have a 70 inch Bravia XBR 70X850B which up until yesterday green/red/pink vertical line that runs across the middle of the screen.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Nov 17, 2016 | Sony XBR Televison & Video
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Lines on display, numerous horizontal, 3 vertical
This problem is caused by a defective LCD display. It is a common problem too. The only way to repair it is to replace the LCD display.
Dec 20, 2012 | Garmin nuvi 1450 GPS Receiver
How do I correct pink and green bands accross HP-R4252 Plasma TV
First of all try, changing the input device to some other and see whether you see the same problem. Then connect your present input to a different TV and see. If you feel the input is ok, and it is a problem in the display, this is a case to be handled by a qualified service technician.
Jul 16, 2012 | Samsung HP-R4252 42 in. Plasma HDTV
Pink/Blue horizontal line on TV
Considering it is a 32 inch set and costs now under 300 dollars it may or may not be worth fixing.
To give an educated guess: either whatever it uses for an inverter board may be bad or damaged OR even the main board that processes all signal into or out to the screen may have either a bad connection(unlikely but possible) or be causing this.
A fatal issue could be something wrong in the screen unit (panel) itself.
I gather set is not under any warranty at this time.
Apr 05, 2012 | Televison & Video
I have purchased Sony Bravia LCD BX 42, which has a very thin horizontal line across the screen, how to fix the problem
my sony bravia BX42 has a color green horizontal line and it makes bigger and bigger until some color pink was appeared then I am worried if it will not turn to normal as it goes :(
Aug 29, 2011 | Sony BRAVIA KDL52XBR2 Television
A pink line the whole height of the monitor has
Try setting you screen size to a larger or lower size. and the pixel color. try 32bit instead of 16bit.
Jul 18, 2009 | Acer 22" X223w LCD Monitor
Pink bar across top of tv screen
This could be from 2 things. 1 is the optical block is going bad or 2 you got a peice of dust blown in from the cooling fan and its blocking the color filter internally. If you are capable you can take the tv apart and blow compressed air into the color block and remove the dust. Hope this helps
May 25, 2009 | Sony KDF46E2000 46" Projection HDTV
Yellow and pink line accross top of screen.
We have aKDF-E42A10 for a bout 2 yearsnow and we now have 13 horizonal lines across the screen, they look like small square dotted lines across the entire screen from top to bottom. It be gan acouple of months ago as 2 of these lines that seemed to move up the screen. I called technical support and he made it sound like he never heard of the problem. I am very upset with sony right now. Anybody know how to fix the problem?ricedog
Aug 14, 2008 | Sony KDF-E42A10 42 in. LCD Television
Color line across the center of a black screen
Hi. this is caused by dry solder joints on the frame o/p IC. Resolder all legs of frame chip. Should sort that out.
Sep 06, 2007 | Toshiba 32A60 32" TV
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
113 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
