Question about Panasonic NV-GS3B Mini DV Digital Camcorder
Lost connection to TV and PC
My Camcorder has been working fine through the SCART connection to a TV and through a firewire cable to my PC. It has now developed a fault and cannot display movies on anything other than the Camcorder's own LCD. Is there a chance it has blown it's circuit for external viewing? If so is it going to be economical to fix?
  • Jason Taylor Aug 03, 2006
    Excellent!
    Thank you for your advice - I will contact them for a price and go from there.
    I will keep you posted how I get on in case someone else has the same fault.
  • 1,476 Answers
Sounds like the communications interface has a problem. It could be as simple as a loose or unhooked ribbon cable or a bad solder joint. As far as cost, it depends on what the problem is. It does not sound like it would be an expensive fix. Here are two websites which offer free estimates - http://www.camcorderrepair.com and http://www.videotech.com Good luck.
Posted on Jul 20, 2006
I bought my camera used online. The DV cable input does not work. (Unfortunately I was not told about this problem.) I cannot pass the tape to my computer now because of the DV input problem. Does...
I recommend you, test the cable, the Firewire ports. test connection.
Plug the firewire into the camcorder BEFORE turning it on,
You must use a Firewire cable and FW ports (Firewire to Firewire) NOT USB port
Check the cable no bend.
1.- Try with other cable
2.- Try connect a different Firewire port on your PC (or connect to other PC)
3.- To test the FW port on your PC connecting other devices by example external hard drive
If the Hardrive work fine the problem is with your camcorder
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 21, 2011 | Panasonic DVX-100 Camcorder
Can't connect my JVC camcorder to my PC
You need to install the drivers BEFORE connecting pc to camcorder
Jun 22, 2008 | JVC GR-D350 Mini DV Digital Camcorder
How to fix Sony DCR TR7000 Firewire port
if you can open camera make sure the ribbon cable from port is seated all the way. if not replace input board.
Jun 02, 2009 | Sony Handycam DCR-TR7000 Digital Camcorder
Firewire and playback on TV
I don't know it this will solve your problem but I'm using a 3 pole male plug and getting picture on the TV (but not great picture - see above).
Jan 01, 2009 | Canon ZR900 Mini DV Camcorder
GR-D60EK importing data from camera to computer
You need a cable. If your camcorder has a DV port you need a firewire port in the back of your computer as well as a firewire cable. If your computer has a USB port you need a USB cable.
You also need video capturing software to use it. Pinnacle Systems makes an easy to use system that work with your camcorder. Once the software is installed, the cable is plugged in and the camera is turned on, your computer will lauch Studio for you.
Jul 12, 2008 | JVC GR-D50 Mini DV Digital Camcorder
Which cable do I need to conect my camcorder to pc
if you need a visual on it, there is a video on www.HandBookLive.com under Electronics. The example is Belkin IEEE 1394 cable (Firewire and I-Link compatable) and it connects digital camera to a laptop.
May 28, 2008 | Sony Handycam CCD-TRV78E Camcorder
Help!! Can not connect my Sharp ViewCam Z VL-Z3U Through FireWire
Try searching these posts to see if they will help your problem. Seems this is common. See the link below.
http://www.fixya.com/tags/VL_Z3U
Mar 26, 2008 | Sharp Viewcam VL-Z3U Mini DV Digital...
Connection to PC does not work
Hello, yes I am aware of that problem. Basically one should change the so called VC441 Board. Luckily PAL version has almost twice cheaper VC441 board then the US version. For my account about 300 Euro. So, in order to repair the camcorder above mentioned board has to be replaced. If you need more info please advice.
Mar 18, 2007 | Sony Handycam HDR-HC3 HDV Digital...
JVC GR-D275 not seen as connected to computer
Many Camcorder users have faced problems while connecting their camcorder to their PC. One of the most common problems is ?no activity? after connecting the camcorder to the PC. The found new hardware wizard does not run and fails to detect the camcorder. This can mean two things. Either the DV port on the Camcorder is not working or the FireWire cable is faulty. Try using a different FireWire cable. If the camera is still not detected by the PC, try connecting it to a different PC. If the Camcorder is still not detected, then your camcorders DV port is most likely at fault. Confirming that the FireWire Port on you PC is working fine You can check the status of the FireWire port from under Device Manager. To access the Device Manager, Right Click on My Computer and then click on Properties. Select the Hardware tab and click on Device Manager. If you cannot see the FireWire port in the list, then it is not inserted properly into the motherboard. If you see a Yellow exclamation mark, then you need to install the drivers, which are usually bundled with a Floppy or CD with the FireWire card.
Dec 21, 2005 | JVC GR-D275 Mini DV Digital Camcorder
Panasonic NV-GS3B Mini DV Digital Camcorder Logo
57 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
