Question about Nokia N95 Cellular Phone
HELP ! Frozen Nokia N95
Hi, I have just attempted to do the firmware update on my N95,
about half way through, the Nokia pc suite said that the phone was no longer connected, I left it for a while and the updater said to remove the battery from the phone, replace and turn back on in order to attempt recovery.
Now the phone constantly displays "Nokia" across a blank screen while powered off, and won't power up at all.
Even if I take the battery out, the Nokia logo stays on the screen for about 20 seconds and re-appears as soon as I replace the battery and attempt to switch on.
If anybody has any ideas how to reset the phone or restore the firmware, I would be eternally grateful, as I also need the phone for work.
Thanks in advance
Ade
  • hajoy Jan 16, 2009
    when i turn on my n95 it stays on the nokia logo and does not comes off. I then took out the battery and it takes about 30 seconds until the nokia logo comes off.
    Problem Solver:
  • 8 Answers
Try to push and hold together buttons * ,3 and green handset then press power ( still holding buttons) .
If it's not work you must do a manual software upgrade in service centre or someone who have special hardware for that. if you need that you can contact me at pluciorx@wp.eu
Posted on Sep 14, 2008
My phone always hang(software)
It may be due to an incompatible software or low on RAM.
Check the firmware of your phone by pressing *#0000# and check the latest firmware for your phone on the nokia website. It should solve your problem for sure.
PS - Take a back-up with Nokia Ovi/PC Suite before updating firmware.
Jun 20, 2010 | Nokia N95 Cellular Phone
I update the nokia firmware from pc suit and when i tried to restart the phone it's not working what to do?
the problem is that you might have disconnected the phone before everything is done. so retry to update the firmware it will work
Nov 15, 2009 | Nokia N95 Cellular Phone
My Nokia N95 keeps "freezing up", as in it just wont do anything. It wont even power down using the off button. The only way of sorting it seeems to be to take the battery out of the phone and power up...
Its very hard to diagnose without inspecting the phone. But one thing is water damage. If sure that it is not water then it might be a virus or file corruption. Also try to connect it to your pc and run "Nokia PC suite" with "Nokia software Updater". Can you perform a reinstall of your firmware??
Jun 04, 2009 | Nokia N95 Cellular Phone
Frozen N95
kindly reset like below or pls update ur phone firmware from NOKIA download update application from www.nokia.com for ur mobile N95 and it will help u in this software issue
but pls first try to reset the device like this it may resolve it
and RATE ME WELL !
Option 1
Press Call + 3 + * simultaneously during the bootup phase, forces the N95 to do a complete wipe of internal memory.
This will reset the phone back to 100% standard factory configuration.
Option 2
Master reset
1) *#7370#, then enter 12345 (This is the default security code unless the user has changed it) and then Yes. The phone then wipes all apps and phonebook contacts on the internal memory.
May 19, 2009 | Nokia N95 Cellular Phone
My screen is upside down N95
Try a firmware (software) update, you can download the NOKIA Software Updater from the NOKIA web site.Do the update even if it is the same SW version that is already on your fone
MAKE SURE YOU BACK UP YOUR DATA 1ST, EITHER WITH THE NOKIA PC SUITE OR ONTO YOUR MEMORY CARD
Dec 27, 2008 | Nokia N95 Cellular Phone
Audio failure
Maybe you should try updating the firmware of the product through nokia pc suite. Most latest firmware for N95 is V 21.0.016.
Try it. Most problems with the N95 as solved by updating the firmware.
Sep 20, 2008 | Nokia N95 Cellular Phone
Nokia n95
Try formatting your phone. Turn it off. Then hold the following keys WHILE it's turning back on: (3 + * + green call key). Don't let go till it asks you about your location. Be aware that it will delete everything saved in your phone memory. Let me know how it goes. :)
Jun 26, 2008 | Nokia N95 Cellular Phone
NOKIA BARCODE READER
HI, I HAD THE SAME PROB WITH MY NOKIA N95 1 GB, I DID A FIRMWARE UPDATE. http://www.nokia.com/ INSTALL THE (NokiaSoftwareUpdater), RUN THE NokiaSoftwareUpdater FROM YOUR NOKIA PC SUITE. NB!!!!!! REMOVE MEMORY CARD, BACKUP ALL UR DATA THAT YOU DONT WANT TO LOOSE!!!!! RUN BARCODE READER, LINE THE CODE UP, BETWEEN THE 2 RED LINES, AND WHALA!!!!
Jun 04, 2008 | Nokia N95 Cellular Phone
Nokia n95 8gb
UPDATE FIRMWARE!!!!!! GO TO WWW.NOKIA.COM DOWNLOAD AND INSTALL NokiaSoftwareUpdater INTO UR PC SUITE, RUN NokiaSoftwareUpdater. NB REMOVE MEMORY CARD, AND BACKUP PHONE MEMORY, ALL DATA WIL BE ERASED FROM CELL
Jun 03, 2008 | Nokia N95 Cellular Phone
Nokia n95
well it sounds like you have two major problems first you need to get the lcd change and the phone's need to have the firmware reflash........take the phone to a recognise mobile service center and have them replace it for you and fix the freezing issue.
Mar 11, 2008 | Nokia N95 Cellular Phone
Nokia N95 Cellular Phone Logo
83 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
