Question about Nokia N73 Cellular Phone
N73 phone start up failed
Two day before.. phone automatically switched off.. and after i tryed to swicth it on but it shows phone start up failed.. it is a two day problem..
please fix it..
  • Anonymous Mar 29, 2009
    my phone hang and switched off..after restarted, the screen view that the 'phone start-up failed.contact the retailer'
    Genius:
  • 1,239 Answers
Hi.
please format the memory card. and start the phone.. it work's.. if not there is a memory card problem..please fix it. thank u..
Posted on Sep 13, 2008
Hi,i had a problem with my nokia n73,it always showed a msg that "phone memory is full delete some data"....i tried to change the phone to its original settings from...
switch off ur phone
press
calling button{green button}and
perss on off switch{switch on ur phone}
press contiune they four key
if not come on display
formatting
then formetting ur phone
or select ur country or language
set time
date
ur fault
will solved 10000000%
its my gurrenty
note:
{the work will start full bettry}
idrish 911
Oct 28, 2010 | Nokia N73 Cellular Phone
I am having N73.......Two days before msg memory was full...I cleared all msgs...Now i don have even a single msg in the phone.........But even nw if i try to send msg,it sits in the outbox without getting...
your phone might be infected with virus, reformat phone will do, also reformat mmc, but make sure if you have some important file back it up on your pc,
hard reset is effective, switch off phone press hold green key, * and 3, switch on while holding this three keys
Oct 04, 2010 | Nokia N73 Cellular Phone
My nokia n73 failed to start up and i don`t know
switch of your phone then press calling key (green button)+3+* and then switch on your phone. don't release the keys for an minute. then your phone will be formatted and it will be ok.
Nov 07, 2009 | Nokia N73 Cellular Phone
Start up fails
i think your cell was internally damaged so you check your start up ic
Oct 07, 2009 | Nokia N73 Cellular Phone
Its urgnt
does it show phone start up failed and if so it means--------- u have got to a mobile service shop where your phone ill be flashed. then it will start automatically it may cost up to rs.200.it will take only 30to 40 min. But if u go to a NOKIA showroom they will charge more and duration will also be more.
send me your result to meeraowther@gmail.com
Sep 24, 2009 | Nokia N73 Cellular Phone
N73 camera switch problem
n 73 camera swich not working problem plz help me
Aug 24, 2009 | Nokia N73 Cellular Phone
My nokia N73 have problem After I press switch on button phone start but after 10 second it will switch off and then swicth again then on automatically. It repeat and repeat and repeats again.
You have to format your phone.
To format N 73 Cellular Phone Steps are shown below
  1. You can remove the mmc but keep the sim card and restart your phone.
  2. Then press the keys *#7370#.
  3. The phone would ask a confirmation.
  4. Select yes.
  5. Then it will ask for a code.
  6. Type the phone lock code (the default code is 12345).
  7. There you are! your phone will restart with all the phone memory formatted.
Tips
  • Also remember that you can reset your phone but not loose any of your personal files (I.E restore the settings that came when you bought the phone while keeping contacts etc) by following the above procedure but using the code *#7780#
Warnings
  • Don't apply these steps if you are not sure what you are doing.
  • Make sure you have enough battery power before beginning this procedure.
Mar 03, 2009 | Nokia N73 Cellular Phone
How to flash nokia N73
you can flash your N73 by using the normal data cable also but your cell must be in working condition for that ...
if your cell is in working condition then you do that by following these below given steps :
1. make a back up of all your data in cell and remove memory card ..
2. download the "nokia software updater " from the nokia website. below is the website given for you:
http://www.nokia.co.in/A4767968
3.install that and keep connected to internet it will automatically download and flashes and installs the new firmware for your cell .
remember dont disconnect or switch off the pc or remove battery while the process is going this may severely damage your cell and it may become unrepairable ....
if your phone is not working presently means then you can buy a DKU series cable which allows you to flash the phone,reset any codes,etc ...
if you dont like to buy then you can just visit some service center and get the cell flashed ... as you are also from india it may cost you some just 200 or 300 rs that s it ...
thank you
regards
-Dileep
rate my solution
Nov 13, 2008 | Nokia N73 Cellular Phone
NOKIA N73 PROBLEMS
my n73 hand set problem is if i connect the charger on the screen displayed not charging, and i use to charge the battery charger to store power in battery. charger is working fine but hand set troubled me and the other problem is if i listen the music files after 2 minutes phone is off, in a day its happening lot of times give a complete repairing solutions.
Jul 16, 2008 | Nokia N73 Cellular Phone
Nokia N73 Cellular Phone Logo
71 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
