Question about Canon imageRUNNER 400S Copier
Cannon IR 400S Copier
I have replaced the toner, now i have black lines on my copies. how do I resolve this? help please
    Problem Solver:
  • 11 Answers
Clean all mirrors.count u r drum counting its poor change u r drum next how is u r drum cleaning blade its poor change it last see u r heater rolar seems any lines change it. check u r input voltage.final black line comes go service mode coper-function-clear-err-clear one by one( u touch top one then ok touch top second then ok........clear all ) sure u r problem solved
Posted on Sep 17, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
1-en front door look inside and see if there are black rings around the shiny Drum cylinder, if yes replace drum blade (may have to replace drum also).
2- if lines only come when doing from ADF then lift top and clean the small strip of glass.
Posted on Sep 15, 2008
There is a black dotted line whenever I make copies on the cannon imagerunner 400s
It's either a speck on the scanner glass for the document feeder, or a smear of toner on one of the rollers. Check the skinny band of glass inside the document feeder for specks and clean it with a lint-free soft cloth and a little rubbing alcohol or a very little bit of water.
May 30, 2012 | Canon imageRUNNER 400S Copier
DEAR SIR, MY CANON IR 400 MACHINES COPY IS TOTALLY BLACK .I WILL NOT HAVE ANY TYPE OF KNOWLEDGE . PLEASE GIVE THE ANY RESOLUTION, FOR GET CLEAR COPY OR ANY TYPE OF FUNCTION IS USE FOR CLEARING...
I will tell you the problem but you need Technician. First try cleaning/replace the flash rom or change tthe Camera together with the CCD Board.
May 11, 2011 | Canon imageRUNNER 400S Copier
I need a pdf user manual/repair manual for the Canon Imagerunner 400s copier. Can you email it to me? I changed the toner but the copies are still coming out light with lines. Maybe it's the drum. My...
Hi, Please get your driver here, select your country first before do next step : http://www.canon.com/products/office.html
Other reference website for your canon is here : http://www.freedownloadsarchive.com/c-download/canon-ir-400-copier-user-manual.html
Regars, vote please, Jay
Jan 18, 2011 | Office Equipment & Supplies
Sir, I am getting black patch on right side of the paper when I take xerox. Please reply
is these black patch like the toner isnt baked and it peels of the paper?
If yes, you have problem in fixing section, probably fixing rollers bushing.
Also remove the drum unit and check drum for toner leftovers. If the drum is covered with toner after copieing replace drum unit.
Hope that helps!
Aug 03, 2010 | Canon imageRUNNER 400S Copier
Just tell me how to get the Material Safety Data sheet for the cannon ir 400
This link has the MSDS for the toner. I beleive it is the only MSDS available or that you would need.
http://www.canon.ca/sd_busdrivers/buzdriver.asp?lng=en&pid=84
About 3/4 the way down the page.
Nov 24, 2009 | Canon imageRUNNER 400S Copier
I am own a canon IR 400 copier printer. it is persist of black copy for xerox. but printing is alright please solve my problem
Hello sir; When you make a copy, lift up the cover check the exposue lamp is on, if not replace it.
Aug 02, 2009 | Canon imageRUNNER 400S Copier
Plz send me (detail) feachar of cannon 6050 & cannon 400s on this address CHECHANI TELECOM & PHOTO COPIERS C-278, R.K.COLONY,NEAR CHOTI PULIYA, BHILWARA,(RAJ)311001 +919829045797 +919413824797
CANON IR 6050 IS AN ANALOG COPIER.
CANON IR 400 IS A DIGITAL COPIER.IR 400 IS SINGLE SCAN & MULTI PRINTS ,STACKLESS DUPLEX & ITS CAN BE USE PRINTER & FAX ALSO.
FOR MORE DETAILS VISIT WWW.CANON.COM
Mar 15, 2009 | Canon imageRUNNER 400S Copier
I have lost my Cannon ir 330-400 pcl driver cd
Hi!
You can download the drivers needed from the link. Please select the driver you want to install from this link--
Drivers from Canon
In this link please find the drivers in the bottom.
Please rate this solution if you find this solution helpful.
Thanks
Rylee
Feb 08, 2009 | Canon imageRUNNER 400S Copier
Canon ir 400 copier
Check the scanner. If the lube has dried up it could be causing the scanner to vibrate slightly when reading the image.
Oct 14, 2008 | Canon imageRUNNER 400S Copier
Service manual
I want user manual for cannon imagerunner 400 / 330 series
Sep 19, 2007 | Canon imageRUNNER 400S Copier
Canon imageRUNNER 400S Copier Logo
102 people viewed this question
old marine
old marine
