SOURCE: dishwasher problem
Hi Sharon , Im not finding your model number dwf415. See if you have high temp wash and heated dry buttons on your dishwasher. If you do, press high temp wash, heated dry, high temp wash, heated dry in that order. This will run the service mode and reset the board. If you don't have those buttons post the cycles you have or the full model number. Catriver
SOURCE: KitchenAid KUDP02 built-in dishwasher will not fill with water
Couple of things that come to mind here... May be helpful or not - but after all this is free ifo and probably worth what you are paying!!!
Anyway:
1: Have you tried removing power from the appliance?? All these modern appliances use a microprocessor and - like MS WINDOWS - need a kick up the bum now and then - (Well.. with Windows it seems to be every day- hour -minute - or so)
2: Dishwashers are installed with water reduction valves, so there could be a problem with one of there (particularly the hot water side).
3: The water inlet is controlled by soleniod valves (read: electronic valves). If the valves are not opening, no water will enter the appliance, so there could be a problem with the valves.
SOURCE: GE Dishwasher will not fill with water
You probably have a bad water valve. It is not expensive to replace. About 25-30 dollars. Go to an appliance dealer and tell him the model and he will sell you the part. It is fairly easy to replace too.
SOURCE: ariston dishwasher
i have a brand new ariston ll-64 and the wash cycle won't start and two flashing lights
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
