Question about Pioneer DEH-3400 CD Player
I shut off my car and turn it back on i need to setup the radio and my settings again it doesnt save ! im missing the orange wire for illumination but my deck still illuminates its the memory thats doesnt work...
    New Friend:
Found this solution on Halfords UK - thanks to Steve51:
The Pioneer DEH-3400UB was bought as a present for my daughter and ticked all the boxes. As a word of caution, I installed the radio myself, replacing an old Pioneer radio. After installation the radio kept returning to setup every time she turned on the ignition. The instruction manual does not make the resolution clear( there is a small diagram with no instruction). If you experience this issue the solution is simple, reconnect the yellow wire to the red wire on the wiring loom and the red wire to yellow. The radio now works great and I can recommend the tone and quality.
Posted on Aug 12, 2013
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Pioneer Master
  • 2,226 Answers
Make sure the yellow wire is going to a source that still has 12v when the key is turned off. The yellow wire controls the memory and needs to be connected to a constant power source.
Posted on Sep 12, 2011
SOURCE:
1994 honda accord radio wont save settings.
If you have a multimeter or test light, try to find a wire that still has 12v when the key is off. Connect that wire to the yellow wire of the radio. The yellow wire has to have constant voltage going to it to maintain the memory.
Feb 11, 2013 | JVC KD BT11 CD MP3 CAR RADIO IPOD AUX...
I have a 2000 chevy impala i cut wires on factory n dont know what wires go to what on after market stereo need to know what colors on factory harnus r what ex-orange,illuminate orange 2...
2000 Chevrolet Impala Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Antenna Trigger: White
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Mar 03, 2018 | Chevrolet Impala Cars & Trucks
Sebring 04 where to connect the illumination/ dash light wire
Get this manual online at www.reliable-store.com and get complete guide on whether to repair or not, service it, and how to repair etc, along with wiring diagrams, electrical diagrams, torque specs, error codes, everything.
Mar 01, 2018 | 2004 Chrysler Sebring Coupe
I'm putting panasonic cq-c1103u player into 2001 corolla using an adapter plug. I have all the wires connected from plug to player harness, but the is 2 wires left over from the plug, the blue power antena...
unless you have a power antenna or an external amp, all those are extra wires. just cap them off. the orange wire is only used if the radio has an illumination feature that allows dimming on the radio. it is not needed to see the radio. DO NOT connect the blue/white from the radio to the orange of the harness. whenever you turn the radio on it will send 12V to your cars illumination circuit. this could damage your lights, dash lights and maybe the radios output.
Apr 12, 2011 | Panasonic CQ-C1103U CD Player
I need a radio wiring diagram for a Hyundai Accent 11/2000.
Radio 12v orange/black + radio
Radio Ground black - radio
Radio Ignition blue/black + radio
Radio Illumination green/orange + radio
Factory Amp Turn-on
Power Antenna pink + radio
LF Speaker +/- red - blue radio
RF Speaker +/- white - brown radio
LR Speaker +/- green - orange radio
RR Speaker +/- orange - blue radio
Feb 27, 2011 | 2000 Hyundai Accent
Im installing a JVC KD - A315 radio in a 2003 alero, when i took out old radio all the wires were cut and turned into speaker wire running all over the place the factory amp is in the back i went ahead...
There may be extra wires you don't need. The basic set of wires on the radio is 4 pairs of colored wires--one black-striped and one plain for each speaker. Yellow is usually accessory power, red is hot, and black is ground. Some additional wires may be one for a power antenna, one for an external amplifyer, and one for facelight (in case it will run on dimmer)
The car should have the following corresponding wires:
Radio 12v--- orange
Radio Ground--- black
Radio Ignition--- yellow
Radio Illumination--- brown
Dimmer--- gray
Power Antenna--- pink (if you have one)
LF Speaker +/- tan - grey
RF Speaker +/- lt green - dk green
LR Speaker +/- brown - yellow
RR Speaker +/- dk. blue- lt. blue
The car or radio could have additional connectors, such as for a subwoofer, CD changer, etc.
Aug 28, 2010 | 2003 Oldsmobile Alero
I need the wire color codes for a 2008 ford focus, for the stereo! please help me!
OK HERE IS THE WIRING COLORS I SHOW, I WILL CAUTION U THAT THIS RADIO IS PART OF THE COMPUTER CONTROL SYSTEM OF THE DASH LIGHTING AND U CAN'T JUST PLUG ANY RADIO IN, CONTACT A CAR STEREO SHOP FOR COMPATABLE MODELS
2008 Ford Focus Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: White/Red
Car Radio Accessory Switched 12v+ Wire: Gray/Orange & Violet/Orange (This vehicle uses the can data network for accessory turn on.)
Car Radio Ground Wire: Black/Blue
Car Radio Illumination Wire: Gray/Orange & Violet/Orange (This vehicle uses the can data network for illumination and dimmer controls.)
Car Stereo Antenna Trigger Wire: Black
Car Stereo Amp Trigger Wire: Violet/Red
Left Front Speaker Positive Wire (+): White
Left Front Speaker Negative Wire (-): White/Brown
Right Front Speaker Positive Wire (+): White/Violet
Right Front Speaker Negative Wire (-): White/Orange
Left Rear Speaker Positive Wire (+): White/Green
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Brown/White
Right Rear Speaker Negative Wire (-): Brown/Blue
Apr 28, 2010 | Car Audio & Video
Im trying to connect my pioneer radio to my hyundai tiburon GT 2003, and i need to know what color wires on the radio go to what color wires on the cars wiring harness
Radio Constant Wire 12V+: Red
Radio Ignition Switched Wire 12V+: Yellow
Radio Illumination Wire: Pink/Black
Radio Dimmer Wire: n/a
Radio Antenna Trigger Wire: n/a
Factory Amplifier Turn On Wire: n/a
Left Front Speaker Wire (+): White
Left Front Speaker Wire (-): Brown
Right Front Speaker Wire (+): Black
Right Front Speaker Wire (-): Yellow
Left Rear Speaker Wire (+): Blue
Left Rear Speaker Wire (-): Red
Right Rear Speaker Wire (+): Green
Right Rear Speaker Wire (-): Orange
Oct 06, 2009 | 2003 Hyundai Tiburon
What is the orange wire on kenwood deck for?illuminate what?
the orange wire is for illumination it doesnt necassarilly mean that it illuminates your radio some vehicles it illuminates the dash lights or a/c controls so on and so fourth it may do nothing to your praticular car but others it does
Dec 28, 2008 | Kenwood KDC-MPV619 CD Player
DehP6700 mp restet everytime keys is turned on.
first red is ignition or acc (turns off and on with the key) yellow is constant power (always hot keeps memory) orange is illumination (lights up radio) if vehicle doesnt have a seperate illumination wire connect it to the ignition wire. now process of elimination your ground is correct because it worked with all wires to acc your acc works because u had all them connected to it and it worked your problem is in your yellow or constant/memory i suggest u test it again take piece of wire any old thing long enough will do and run the wire directly from the battery under the hood and just run it outside the car through the window and connect it directly to the yellow wire make sure u have a good connection at the battery on the positive side if u have test light or volt meter test the wire before connecting it to the radio if it works then u know there is a problem with the wire from the vehicle (fuse wrong wire bad wire ) if it doesnt work make sure ground is connected tight and that paint is cleaned of the surface where ground connects and that the yellow wire to the radio is tight in the back of the radio.
Nov 13, 2008 | Car Audio & Video
Pioneer DEH-3400 CD Player Logo
128 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
