SOURCE: I have a microwave drawer
The
first thing I would suggest is a hard reset. Unplug the unit for a
minute or so. Then plug it back in, set the clock and try again.
But if the oven light is getting power when you try to cook, but the oven won't heat, the next question is this: Does it sound louder or quieter than normal?
If quieter, I would suspect a relay or connection on the control panel.
If louder, I would suspect a shorted high voltage diode or a bad magnetron.
Since
it's less than one year old, it should be fully covered under warranty.
I'd suggest contacting the manufacturer to get it fixed free.
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277) or visit them online to arrange service.
SOURCE: Sharp microwave r610dsa - display faint - barely visible.
We regularly repair such control units for
customers nationwide by mail for $39.95 postpaid in about a
week or so with a one-year guarantee.
We have the full service
manual at our site, which contains the specific safety &
disassembly information you'll need here.
If you decide to send yours in for repair, we
would really need the front door panel assembly (which contains the keypad,
display board and connecting cable) as well as the power board to which
the cable connects, as shown in the manual.
If you prefer, you can order part number DPWBFC212WRKZ (CPU/display unit) for $73.33 plus shipping from Encompass here or you can call them toll-free at 866-779-5835.
Feel free to contact me directly (and please remind me of your
full model number from the tag on the unit) for more information & help.
We're
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
SOURCE: Sharp Microwave Model R-510B Light burned out -
Generic answer:
You probably have to remove the case. DO NOT TOUCH THE SILVER CAN - LETHAL. There are probably 8 phillips or torx head screws to remove the cover.
Alternatively, their may be access inside, where I would look first.
Let me know if this works.
a
SOURCE: Re: Sharp carousel microwave oven minute display light out
Hello there
To replace the light you will first have to remove the outer shell.
To do this
(1). Remove all of the screws on the back of the microwave that hold on the shell
(2) Remove the screws that are on the bottom.
(3) now the shell should slide off towards the back of the microvave.
Note : this may take a little bit of pressure to get it off ok?
(4) Once the cover is off look towards the fromt of the microwave and
you will see the bulb. now just replace the bulb and reinsert the cover and the screws and you are all done ok? pretty easy ha/
best regards michael
SOURCE: My Sharp microwave drawer oven model KB6015KS has
We have the service manual for this model and have uploaded it for you here.
You can order
parts for this brand from Encompass here or you can call them toll-free at 866-779-5835.
We're
Hi
You can check out these links to
buy Sharp Microwave in UK:
Hope this helps...please post back
for further assistance.
Daniel
