2701HG-G DSL light constantly flashes green
I just got my 2701HG-G hooked up (using a splitter and yes, I have a filter on the phone) and have no connection.
I can connect to the modem, but it says there's no internet connection available. The DSL light is constantly flashing. I've tried restarting and connecting without the splitter in place. Any suggestions?
  • onyxblue Mar 04, 2009
    Netopia 2247 has been flashing green for days. advised its a router problem. used a brand new netopia 2247 and still have the same problem.
    this looks like an authentication problem to me!
    any ideas out there?
  • 5 Answers
SOURCE: siemens gigaset se587 wlan dsl
connection should be as follows..........
comp>>eth cable>>>modem or router>>>>>fone cable>>>filter>>>>wall socket
telefone cble>> ^
no ext should be there ....... no external device should be connected........
if using any device in any socket at home then make sure that they r filterd correctly .....
try resetting the modem/router..... then check the lights.......
last option is to unplug n re plug all the cables.....
80% this should wrk....
ny more q: mail
Posted on Sep 25, 2008
  • 42 Answers
SOURCE: need to find security codes for 2wire dskl
When you say security code do you mean you wireless password?
Posted on Jan 04, 2009
  • 84 Answers
SOURCE: 2WIRE 2701HG-B with flickering DSL light.
The DSL is out in your area or the phone line has been disconnected.
I would contact ATT&T to find out if thire is a service issue in your area
Posted on Aug 16, 2009
  • 149 Answers
SOURCE: Yesterday had Cable Internet hooked
Sounds like a problem with your cable connection. Check your coaxial cable, and the splitter from where the cable enters your home. The tech will use a signal meter to measure the quality of your cable, and then replace the wiring if necessary.
Posted on Jan 04, 2011
SOURCE: Cannot connect to my Internet.
With the DSL light always flashing, it means that either the ADSL signal (synchronization) does not reach your modem, or your modem cannot 'read' the signal.
You need to determine if the problem is from one of the following places :
  • outside of your house (your land line or ISP equipment) or from the modem;
  • your telephone-cable inside your house or
  • one of your equipment;
Try the following manipulations to determine from where the default comes :
  1. Determine if the problem is in your house or on the land line
    • Unplug each and every equipment which is connected to your telephonic installation (Fax, phones, answering machines etc);
    • Using the shortest telephone cable (RJ11) you possess, plug only your modem to the main telephone jack of your house.
    • If the DSL LED still flashes continuously, the problem is somewhere between your ISP's equipment and your house. You should call them and expose the situation. At this stage, you can't do much else.
  2. Determine if the problem is in your house installation
    If the DSL LED lights up when it is plugged to the main telephone jack, then it is either one of your equipment which is at fault, or the house installation. To pinpoint the problem, do the following :
    • With all the other equipment still unplugged, try the modem on all the other telephone jacks you have around the house.
    • If the DSL flashes continuously on one of the jacks, you will have found the source of your miseries. Depending on your ISP's terms and conditions, you will either have to call them of call for the services of a third-party technician to solve the problem.
    • If the DSL lights up correctly on all the telephone jacks, then your house telephone installation is good. Proceed to the next series of tests.
  3. Determine which equipment is at fault
    • Plus your modem to one telephone jack and wait for the DSL line to light solid.
    • Use a splitter (ADSL filter) to plug the equipments you possess (telephone, fax etc) one by one. Verify each time if the DSL LED is still lit or flashes continuously.
    • If one of the equipment causes the DSL LED to flash, it is that equipment which causes your problem.
    • If every equipment causes the DSL LED to flash, the it is the splitter (ADSL filter) which is causing the problem. You can confirm this hypothesis by testing each and every ADSL filter you have in your possession.
    • Replace any faulty equipment and you should have eliminated the problem.
If nothing of this solves your problem, you won't have any choice but call you ISP. Don't hesitate to tell them all tests you will have done.
May I also make some recommendations :
  1. Use a power surge protector (not a UPS though) to plug your modem to the electric outlet BUT plug it directly to the telephone jack;
  2. Make sure your modem is plugged in as far as possible from UPS, television, etc.;
  3. If possible, don't plug the modem in the same electric outlet as other equipments;
  4. Don't use any telephone extension cable to plug your modem to the telephone jack.
Hope this helps you. Let me know what happens next.
Posted on May 12, 2011
Zoom X7n Dsl 2/2 Modem/router/gw dsl light blinks constantly when trying to connect to Earthlink
Try removing the splitter, if it works then you might have a faulty splitter and you need to get it replaced. You might check if you are using the first phone jack in your house / apartment. I remember that was key when i was on DSL. Hope you get it sorted out, not having a working connection is very annoying.
Nov 18, 2013 | Zoom X7n Dsl 2/2 Modem/router/gw
When i connect the dsl cable to it the dsl light starts flashing green then red
Put tinfoil over your splice connectors and filters as they leak signals that totally confuse your modem. Never leave any bare wires, I tinfoil the entire modem to prevent the neighbors from hacking me. I don't use wireless, only CAT5 ethernet cable.
Jan 02, 2013 | Gateway 2wire 2701hg Wireless Dsl Modem
Internet connectivity problems HP pavilion a6230n desktop pc
1.Unplug all phone, fax and satellite TV cables from the wall phone jacks.
2.Plug the double DSL filter into the wall phone jack where the 2701HG-B will be located.
3.Plug the phone wire (for phone, fax, etc.) into the jack on the filter labeled "Phone."
4.Plug the gray phone cable into the other jack on the filter labeled "DSL."
5.Add the single DSL filters on all remaining phone jacks in the same manner, plugging the device phone cables into the filter. The single filters only have one jack.
Ethernet Connection
6.Plug the power adapter into the power port on the back of the 2710HG-B router and then plug the other end into a power outlet. This will cause the power light on the front of the router to turn green.
7.Plug the free end of the gray phone cable into the port on the back of the router labeled "Phone Line."
8.Plug one end of the yellow Ethernet cable into one of the four ports on the back of the router labeled "Ethernet."
9.Plug the other end of the Ethernet cable into your computer's Ethernet port. The Ethernet light on the router should now be green.
Wireless Connection
10.Plug the power adapter into the back of the 2701HG-B and the wall power outlet.
11.Plug the gray phone cable into the jack on the back of the router labeled "Phone Line."
12.Open the Network and Sharing Center on your computer by right-clicking the Internet connection icon in your taskbar.
13.Click "Set up a new connection or network" and follow the instructions provided by the wizard to set up the wireless connection on your computer.
14.Enter the SSID and WEP key when prompted. The SSID is "2WIRE" followed by the last three digits of the router's serial number, which is located on the bottom side of your 2701HG-B router. You will also be prompted to enter a WEP encryption key, also found on the bottom side of the router. The WEP key is the 10 digit number that appears in brackets under the first bar code.
Sep 12, 2012 | HP PAVILION A6230N DESKTOP PC
My modem is blinking green and it doesn't work
if dsl light is flashing is trying to get connetion from isp check wires from jack to modem
check for filters on phones,fax,alarm systems(not on modem)
or call your isp
Apr 28, 2010 | 2wire (2701HG-B) Wireless Router
When my phone rings the kids get booted off xbox live and i have wireless internet and wireless adapter for xbox360
Hi Jeannie,
Based on your problem I assume that you have DSL. When you get hooked up for DSL they send filters that you are supposed to put between EVERY phone and the jack. (Don't forget phone lines for satellite and alarm systems).
If your dsl drops every time the phone rings, there are usually 2 things that cause this.
1) A bad filter in your house. If a filter is bad or missing it can cause the dsl to drop either when the phone rings or if someone picks up the phone with the bad filter.
2) The other reason could be on your ISP's side. It's called a POTS splitter. You have one of these if you have BOTH phone and DSL. It's what sort of combines the 2 together. There are a number of problems that can occur with a bad pots splitter. i.e. DSL works - phone totally dead, Phone works-dsl - totally dead, disconnects, etc...
I suggest that you hook up the dsl modem by itself. DISCONNECT ALL PHONES IN THE HOUSE. Do NOT have anything connected at all except the dsl modem. No filters, phones, directv, digital cable, or anything else in a phone jack. Then when you are up and surfing, take your cell phone and call your house. Technically it should just ring and ring. Unless you have voice mail in which case it will go to voice mail after so many rings. Anyway, see if when the line is ringing in your cell phone if it is dropping you off. If it DOESN'T, then it's probably one of the filters, jacks, or wiring. If it still disconnects, it's probably the POTS splitter with your ISP.
Good luck and if this helped please help me out and leave feedback!
Feb 08, 2010 | Computers & Internet
Cordless phone has volume problems with DSL
For starters that dsl modem should not be filtered.
You should place the splitter directly into the wall jack and place the filter on the side used for the phone. The side feeding the dsl line should not be filtered.
The filter serves 2 purposes. 1 it reduces data noise interference onto the voice line. 2 it prevents dsl interference from voice such as picking up and hanging up the receiver.
Aug 26, 2009 | Uniden Cordless Phone
Aug 15, 2009 | 2wire Computers & Internet
My linksys router keeps dropping connectivity to the internet
does your router and your landline phone is in one connection in with a splitter..
does connection failed whenever there's a call?
if so your splitter might be broken
or you must insert your phone line with the splitter, it might be in your connection set up..
or make sure your utp cable is stable and not in exposure area of people or pet where it might be touch or something..
hope this helps...
Jan 13, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Siemens gigaset se587 wlan dsl
A flashing ADSL light on the router means its not getting constant broadband signals. Make sure it is connected to the adsl filter without any extensions and the filter should be directly connect to the main phone socket and not to an extension socket. Also check if the phone socket has 1 or more than 1 ports on it. If it has two port its most likely a SSFP socket which does not require a filter as it is inbuit.If all the connections are fine try changing da filter.
Sep 07, 2008 | Siemens (120-5830-001) Modem
Hi. I will not repeat the check the phone line and resetting comments as it's now redundant.
I always have a spare modem as a line tester.
I've seen several 2700HG-B 2wire modem/routers burn out and every single time it's the DSL signal or modem portion that is burnt out. Even if you have two or three phone line surge protectors these 2700s are prone to shorting out unless you have a direct signal splitter DSL setup.
Here are a few things you can try to confirm if the 2700 is no longer functional on the DSL signal light problem.
#1: Turn on (plug in) your 2700 without the phone line plugged in and wait. If the DSL starts flashing red then there is a hardware problem in the modem/router.
#2: Plug the phone line into the 2700 while the dsl light is flashing red. It might take about 3 seconds however it should start to flash green and let it flash for about (usually) three minutes. If it turns red then the 2700 is indeed damaged.
#3: If you can enter into your modem using the http://2wire... and check the connection status. The first two status lines should read attempting to connect and no connection.
Nov 01, 2007 | 2wire 2700HG-B Router (2700HGB)
Computers & Internet Logo
224 people viewed this question
David Payne
David Payne
