Question about Dishwashers
Bosch SGS45E08BG/45 Not Washing Correctly
I have the above dishwasher, about 2 years old. All worked fine until I put it on today. When I turn it on it fills with water then seems to just go through a constant cycle of pumping a bit of water out, a bit more in, a bit out, a bit in... and on it goes endlessly. No water comes out of the rotar arms, and while the pumping in and out is happening the timer on the front stays on the starting time and doesn't change, regardless of which program I try and run..
I've tried turning it on with the 3 reset buttons pressed but as soon as I let go of the buttons it tries to start the wash cycle again. First draining all the water, then filling up again, then back to the same cycle of pump a bit out, a bit in, a bit out, a bit in....
So it fills up and drains out fine, but it gets stuck in a loop and never actually starts to wash.
Does anyone know what is wrong and how I fix it?
The dishwasher does not fill. The inlet valve solenoid registers within the ohms limits
Posted on Oct 27, 2008
    Sergeant:
  • 409 Answers
Does your dishwasher have a timer or and LCD screen?
if it has timer, replace it or have a techncian do it.
if it has an lcd, replace the touchpad.
Posted on Sep 13, 2008
Bosch avantixx front loader leaking underneath machine? machine only 2 years old
  • You will find a small door on the front bottom of the washing machine.
  • Open it.
  • Unscrew the filter and rinse it with running water.
  • Put it back in place and repeat the above steps in reverse order.
This should solve your leakage problem.
Aug 03, 2014 | Bosch Washing Machines
No indicator lights
A Bosch washing machine can make your life easier. Look in the troubleshooting section of your owner's manual for specific information related to the make and model of your Bosch washing machine.
Find more details on Bosch Home Appliances at Appliances Connection online.
Make sure the washing machine is unplugged or the circuit breaker is turned off before you attempt to replace any parts.
Dec 31, 2013 | Bosch Evolution 800 SHE68M05UC Stainless...
Bosch Dishwasher will not dry dishes, washing is fine. Model SHU43C05UC / 17. About 4 years old. Cannot find the manual. Any help is appreciated.
Bosch dishwashers do not have built in heated dryers. Be sure your water is hot enough and the rinse aid dispenser is not empty. The Bosch should heat your water to a minimum temp and if it is not, this could be your problem.
Ken
Oct 25, 2010 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Have a Bosch dishwasher, about 10 years old works ...
Check the hinges in the sides. may be requires little lubrication. Use an appropriate lube spray available in your shopping area.
May 21, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishwasher won't wash
pump is likely gone ......without pressure from the pump .the arms will not turn and no water will shoot from the arm jets .....it's kinda like a whirlpool tub that way .....no pump no bubbles ..good luck
Jul 25, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
ASKO 1605
Hi Guys
My dishwasher this morning has desided to not work correctly.
Its a ASKO 1302 about 20 years old. It has been a very good machine.
Over the last couple of weeks during the washing cycle, the dishwasher has been making a loader noise than usual.
1. Today, the dishwasher timer, travels all the way through its cycle, but very little washing take place.
2. Soap power is still there, plates not clean!!!!
3. Water is hot
4. At the end of the cycle, there is no water in the dishwasher.
5. I'm thinking the problem could be the pump needs replacing.
What do you think?
Greg
Sep 05, 2008 | Asko 1375 Dishwasher
Bosch dishwasher regularly floods
fault is with dishwasher. even if drain blocked, would not cause overfill.
possibly the pipe to sump from fill mechanism partially blocked
Jul 18, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch Dishwasher SHU43C02UC
Unplug from mains for 5-10mins. Are you having any power difficultys? sometimes this can crash the controller.
if none of the above possible that its the controller
Jan 03, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU5316
Sounds like the control module is out -- cost about $100 (I am on my third). I got a "lifetime" warranty when buying my second one. If you are handy, you can replace it yourself. You can call Bosch to confirm this (I did). It mounts inside the door.
Apr 15, 2007 | Bosch 23 in. SHU5302UC Built-in Dishwasher
Dishwashers Logo
217 people viewed this question
Top Dishwashers Experts
