Question about Kitchen Ranges
Kitchenaid Superba gas stove. Oven does not work, goes to pre-heat and stops
  • 11 more comments
  • bkelcey Oct 11, 2008
    I'm bafffled two. For the second time this year, for an extended time after several tries, I try to bake or roast and the over just stays locked on "Lo" heat, with the temp never rising above it.
    Struggling to find manual. Please help...
  • arebick Oct 13, 2008
    oven goes to LO and never gets hot. this happens periodicly
  • Anonymous Oct 24, 2008
    Same problem. I bought a oven thermometer and discovered that the temp is often much lower than what it should be. And the display often stays on "lo."
  • darla_moorma Oct 30, 2008
    Same exact problem. My stove is 3 years old. I haven't had any problems with it until now. Broiler will work but the over will not. It goes to low and doesn't heat up.
  • mallikaj_jam Dec 10, 2008
    I have had my kitchenaid gave range for about 7 years. I have not had any problems with it until 2 days ago. The gas stove is working just fine, but my oven when turned on does not get heated.
  • illuzions Dec 27, 2008
    YEEAH, I'm now having the same problem after running the Self Clean, the oven won't heat up, stuck on "low" setting and everything else works just fine. Anyone ever get this fixed?
  • thejelineks Jan 04, 2009
    Same probelm. both igniters work but oven temp often reads "low" and does not heat up, or does so very slowly
  • Anonymous Jan 25, 2009
    Me too, Me too. Does anyone have ANY answers??????
  • RogerN Feb 22, 2009
    Same problem. After a week of this, I tried to self-cleaning and cancelled. It may have fixed my problem
  • rasm1 Mar 23, 2009
    Broiler Gas Burner lights, but the lower burner element does not ignite. Pilot light does go on. I have also noticed that the rate of gas flow must not be too high as the burner will light when direct flame is used, but not enough for the pilot light to start. Once lit, the oven takes a long time to heat up.
    Do I have a burner issue?
    The top heating element works fine and the oven heats up fast.
  • edfoley Mar 29, 2009
    I have the same problem. Worked fine for four years. Did the self-cleaning for the first time. Now it heats up extremely slowly, stuck on "lo" for 15 minutes now.
  • Anonymous Apr 20, 2009
    Mine beeps when it decides to shut off (not always right when it's done pre-heating) and shows error message F4E1. Sometimes it works fine - I can't figure out what's going on.
  • Anonymous Mar 17, 2014
    F2:E3 on display.
    Sergeant:
  • 409 Answers
So you get an error message on the display?
do the burners work?
Posted on Sep 13, 2008
How to unlock a kitchenaid superba stove
How-To Unlock A Kitchenaid Superba Oven - YouTube
? 1:24
www.youtube.com/watch?v=yKNGTVCEiuM
Sep 22, 2014 - Uploaded by Public Relations & Promotions
How-To Unlock A Kitchenaid Superba Oven ... Repair - Deadoven after self clean mode, blank display, locked door Kitchen
Sep 09, 2015 | KitchenAid Kitchen Ranges
Kitchenaid superba stove baking element does not heat
There has to be a baking element. Find it and replace it.
Aug 19, 2017 | KitchenAid Kitchen Aid Superba Series...
Kitchenaid superba oven
It is very possible that moisture from the cleaning has caused the ignition switches to make enough resistance to cause the burners to spark. It usually goes away after the stove has dried out. If it continues after a day or so one or more of the ignitor switches may need replacing.
Nov 20, 2013 | Ovens
I set my kitchenaid superba self clean oven to clean mode. It cleaned it however now I cant get the oven to work. Stove top works but oven doesn't. What can I do to fix this?
Pyrolitic mode heats up quite hot. Might have tripped the high temp cutout.
Does the oven fan work? if so >> check element
Oct 17, 2013 | Ovens
KitchenAid KGSC308LSS Gas Kitchen Range OVEN won't heat up
Does the igniter in the oven glow white hot when it tries to start?
Dec 20, 2012 | KitchenAid KGSC308LSS Gas Kitchen Range
My beep quit! Beep used to work when the oven came up to temp, the timer timed out, or a button was touched. Can it be reset or will I need to replace it? Where's the control board located and how do I...
We have a Kitchenaid Superba gas stove and the beeps would not sound. We thought the control panel was shot, but we have a WONDERFUL repair man. Here was his re-set.....open oven door, push the cancel button, push stop-time button and hold that button for about 5 seconds. When the beep sounds let go and the panel is re-set. WOW!!!!
Oct 23, 2010 | KitchenAid KGRT607 Gas Kitchen Range
My stove does not maintain a consistent
This is most common with electric ovens and the bottom element goning bad...but I will also include the most common problem for gas ovens also when this happens, as you did not specify which you have...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
If you have a gas oven...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
May 04, 2010 | Kitchen Ranges
The oven will not reach desired temperature. Had
it sounds like you have a bad temperature controller thermostat or your temperature sensor inside the oven, (a metal rod attached to a thin metal wire) is not in its proper place. It clips into connectors located at the back center of the oven itself.
Mar 14, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Superba KGT607HBS oven stopped working
The flame went out.  Move the oven control back to where it sounds like it is lighting.  After it clicks a few times and sounds like you have a flame set your temperature again.
Nov 27, 2009 | KitchenAid KGRT607HBS Gas Kitchen Range
Kitchen Ranges Logo
2,091 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
