Question about RCA P52930BL 52" Rear Projection Television
Help with RCA projection TV P46812BL (chasis ptk195AA)
Main fuse blown.Replaced fuse.Now screen appears to bow at top and bottom,3 colors are separated,missing adjust projection tv in screen menu.poss covergence problem? If so, where can I puchase the convergence circuit board/power supply? My picture bows on the top and bottom after a few minutes of powering on. The colors go out of alignment also. is this a bad convergence board?
  • Albert DiTomaso
    Albert DiTomaso Sep 13, 2008
    My last response from 'Ginko' was great (thank you). however, partstore.com doesn't carry this item. I cant find it on ebay or nextag either. any advise? convergence board for RCA p52930bl
  • 10,594 Answers
your tv requires STK730-020 quantity 02 and you can replace it yourself if you know soldering well.
If you wanna replace complete convergence board, its available Part Store and price is $119
Regards,
Posted on Sep 13, 2008
  • RCA Master
  • 19,396 Answers
You have probably blown one of the convergence ICs. Effectively the easiest thing to do is replacing the whole convergence board, so that no soldering is involved.
Here you can buy a replacement convergence board, just select your model.
Let me know if you need further help.
Tip
The Fl231 PROBLEM(CONVERGENCE NOT IN CUSTOMER MENU) ITC22 chasis
FL231. FUSE.... The RCA ITC222 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and green shadows? Does it have bowing in affect on the top and bottom of picture? when you turn it on does some thin red green and blue line bow in from the top then go away. The main question to determine if you have the fl231 fuse problem is if you go into customer menu then setup do you have the "CONVERGENCE' option. If you do not. then i suspect you have this problem. In the manufactering of these sets Lead free solder is used. now there is great debate over the use of lead free. connection tend to be more brittle. cracks develop around the solder connections of the high voltage flyback transformer. this very small crack set up oscillations in the cuicit with a 400 milliamp fuse. THis fuse cant take it. When this fuse blows the processor then does not know its a projection tv with three projection tubes. it thinks its a crt tube tv. and crt tube tv dont need "convergence" so it removes the convergence from the set.
TO REPAIR... 1. Warning. this set can generate leathal dangerous voltages even unplug do not attempt if you have no experence with electronics.
2. Remove the back. there a number of torx 20 screws.
3. what you will see is a number of circit boards There will be one on the right and one on the left. the one on the right is the small signal board. the one on the left is called the power deflection board. it has a large black part with a big red or black wire coming from the top, this is the flyback.Next to the flyback on the right of it there will be three small rectangular componets tan or brown in color. these are fuses. the one in the middle is the fl231 fuse.
4. getting to this fuse can be difficult. these two cuicit boards sit on a tray that is removable. to remove this tray it is pulled out and up. BUt watch the wires.loosen the wire tyes.
5 when you get the tray up the bottom side of the board can be accessed
you will now have to unsolder that fuse. one side of this fuse is under a plastic part of the tray. i have found the easest way is to cut away the plastic to get to it. if you dont want to do this you will have to remove the board. only remove half of the plastic brace
6. REPLACE FUSE RCA PART 259213
7 RESOLDER FLYBACK CONNECTIONS simply heat up and add a little solder
8 reassemble set. make sure you examine the set for loose connections.
9 and remember "BE Careful'
on Sep 20, 2008 | RCA R52WH73 Projection Television
RCA model P61950
fl231 is the convergence fuse, and is soldered to the board in proximity of the convergence ICS, on RCA rear projection TVs.
If
fl231 has blown, TV usually does not turn on at al, if you get bowed picture, that means that the convergence ICs must be replaced.
The fuse is on the same board where you find convergence ICs, if the fuse had blown, or the pico fuses at the base of the STK convergence ics had blown, the STKs must be replaced.
There is need of purchasing the service manual to do the job.
The repair shuld be done by a technician.
This is the convergence IC, model may vary:
Dec 13, 2008 | Televison & Video
No Power
Try removing the Green CRt PC voard that is on the bottom of the green Picture tube which is the center one. Then replace the fuse and see if your set powers up if it does you need a new gree tube. Just be sure the crt board doesnt touch anything while you try it. then let me know what happened, if you need a tube they arent available new any longer but I have a source for good used picture tubes,
May 22, 2008 | RCA P46812BL 46" Rear Projection...
RCA Projection TV
Located on the power supply right next to where the power cord hooks to the chassis. However most models have 2 or 3 fuses.
Apr 06, 2008 | RCA P46812BL 46" Rear Projection...
Distorted Screen for RCA HD56w66
convergence is the problem. first question do you have convergence in the customer setup menu. if you do not it could be a special small fuse if you do have "convergence" in the setup menu then you most likely have a convergence power board issue. and generally they are replaced. in our shop such board replacement average 124 labor and about 100 for part. if the fuse bout 15 for part and 80 for labor. there are solder connection that cause the blown fuse
Feb 20, 2008 | RCA HD56W66 56" HDTV
Rca projection
Conversion problem most likely. Do your conversion controls work both colors in all 4 directions.
Jan 04, 2008 | RCA P52926 52" Rear Projection Television
Help me please
Sounds like you have a convergence power supply failing due to heat,from the back of the set,make sure to unplug set first and remove back cover,on the right side abouve the main board the is a board mounted on black plastic,on this board is a reg. part number 215530,this ic is most likely the trouble.
Dec 09, 2007 | RCA P46812BL 46" Rear Projection...
Trouble Aligning Colors
If the convergence is missing in the menu in screens,you have a bad reg ic on the convergence power supply the part number is 215530,the power supply is located on the black plastic above the right module with all the heat sinks
Nov 15, 2007 | RCA P56930BL 56" Rear Projection...
RCA 52" Big Screen TV model;P52920BL Chassis;PTK195KB PICTURE BOWED AFTER FUSE BLOWN.
You have bad convergence IC's.. If your not experienced in troubleshooting electronics or soldering, you should have a trained tech take a gander at the set. Its not worth risking life and limb to save a few bucks, Good Luck
Jul 30, 2006 | RCA P52920BL 52" Rear Projection...
Televison & Video Logo
183 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
