Question about LG 32LG30 32 in. LCD HDTV
Contrast really dark but seems to improve after the tv has been on several hours
    Genius:
  • 1,112 Answers
Hi:
You may have a problem with the inverters in the unit, they are responsible for lighting up the back panel. Check or have checked the power supply voltage to the inverters, should be around 18-24 volts DC. Also leaky capacitors on the power supply will cause this issue as well as leaky or puffy capacitors on the inverter.
Posted on Sep 08, 2011
    Scholar:
  • 118 Answers
Related products:
LG 26LG30
LG 37LG30
LG 42LG30
Below you'll find the settings we found best for viewing the LG 32LG30 in a completely dark room via the HDMI input with a 720p, film-based source. Your settings may very depending on source, room conditions, and personal preference.
--Picture menu
Aspect Ratio: Just Scan
Picture Mode: Expert 1
Backlight: 30
Contrast: 94
Brightness: 54
Sharpness: 45
Color: 52
Tint: 0
--Expert control menu
Fresh contrast: Off
Noise reduction: Off
Gamma: Medium
Black level: Low
Real Cinema: On
TruMotion: Off
Color Standard: [grayed out]
White balance: Warm
Method: 10 point IRE
-- 10 point IRE calibration
IRE: [Red, Green, Blue results, respectively, for each IRE point]
100 [50, 40, -50]
90 [1, 33, -50]
80 [9, 32, -50]
70 [-3, 6, -48]
60 [-1, 4, -34]
50 [-4, -4, -38]
40 [-5, 0, -26]
30 [5, 9, -13]
20 [4, 9, -6]
10 [0, 9, -6]
--2 point IRE calibration [the 10-point method worked better for us, but we'll also include our 2 point calibration for the sake of completeness]
Red contrast: 1
Green contrast: 13
Blue contrast: -26
Red brightness: 0
Green brightness: 9
Blue brightness: -2
Color management system
Red color: 0
Red tint: 4
Green color: 0
Green tint: -15
Blue color: 0
Blue tint: 5
Yellow color: 0
Yellow tint: 1
Cyan color: 0
Cyan tint: 0
Magenta color: 0
Magenta tint: -1
SOURCE:
Color is grate on my Sharp 26" TV. However night scenes have become almost too dark to see. I have tried to adjust the settings but no improvement. Is this a fixable problem? Using Comcast Cable a
Check 'brightness' and 'contrast' settings in (usually) 'picture' menu. Use a recording (DVD etc.) of a dark scene to adjust the picture. My TV (not Sharp) has several pre-programmed picture settings. If yours has that, maybe one of them will be good. Otherwise, use manual settings.
Oct 18, 2014 | Sharp Televison & Video
Color settings for an older panasonic tv trying to adjust the color setting for this older panasonic tv, it seems the dark colors are really dark and there faces are really red. Model# CT-32g19j
This is not a projection set; but a picture tube set or CRT (Cathode Ray Tube) technology. If the set is working correctly you should be able to go into the menu and set the color, brilliance and contrast to get the right color and picture intensity. If the controls don't give you what is correct viewing it may be over age and need an adjustment of the internal chroma circuits - which may cost more than the set is worth since it is quite old. Hope this helsp.
Oct 08, 2014 | Televison & Video
WD 73835 has ghosting images during dark or red scenes
Make sure your contrast isn't set too high. Most ghosting is caused by either contrast, brightness or tint issues. Try adjusting these settings. Also check if there is a Dynamic contrast setting for your TV as well as this can cause ghosting also.
Apr 06, 2014 | Mitsubishi Diamond 835 Wd-73835 73" 1080p...
Voire 46" plasma tv- best color settings, to much white
The proper way to set flat screen tv's is opposite of old school CRT tv. First, find a movie with dark scenes and pause on a really dark part. Now set brightness only high enough to see some detail - no more. then go to a really bright scene and set contrast just high enough for good brightness. You may need to go back and forth a few times to get good setting.
Dec 21, 2013 | Toymax Viore 42 in. Plasma TV
Hi Guys, I have a JVC 32T55EKS TV & the picture is overly dark. When the picture goes through the set-top box the picture gets even darker. The brightness is turned up fully & I have accessed the...
U turn on the contrast level to the max,if still not watchable,tv cathoray tube is dying,radiaton is disappearing.Time to buy another tv.
Feb 14, 2011 | JVC AV-27230 27" TV
Best solution to improve picture quality. Screen
Try to turn the contrast down. It can really help out a lot. If this is not working look up your tv's best settings. CNET.com has some great settings under the forums.
If all else fails but a calibration dvd and go thru the settings. Some dreamworks and disney dvds even have them right under the disc extras. Hope I could help!
by the way, remember to cut some of the light in your room if it is well lit. It will help make the picture look better as your eyes can distiguse the light and darks better
Mar 16, 2010 | Mitsubishi WS-55311 55" Rear Projection...
Hi there, im a student photographer and all my images look too dark on my monitor. i have tried looking at them on another computer and they seem fine. i have also tried messing about with brightness and...
hi polly ... I assume you are using a CRT monitor ... if you are then the monitor is simply showing its age ... CRT tubes use a electron gun which over time looses its perfromance... there is really nothing you can do except to replace the monitor.... although if your graphics card has a gamma correction setting you might be able to improve the brightness but at a cost of other settings like contrast...
Mar 29, 2008 | Computers & Internet
FINE TUNING tv PICTURE
try calling the Insignia help line at 877-467-4289
Mar 28, 2008 | Insignia LCDTV26 26 in. Television
LG 32LG30 32 in. LCD HDTV Logo
896 people viewed this question
Steve Allison
Steve Allison
