Question about Weber Genesis Silver A Grill
My Weber Summit Grill is new. Works fine with new LP tank. When tank is half full grill lights but does not heat very high. Have had this problem with multiple LP tanks.
    Problem Solver:
  • 15 Answers
Sometimes in colder weather, if the tank is less than full the gas can settle. Close the tank valve and unscrew the tank hose connecter. Turn the tank upside down several times and then reconnect and try lighting it up. That is usually fixes it.
Posted on Apr 09, 2015
    Problem Solver:
  • 5 Answers
IS PROPANE TANK RESIGNED TO BE MOUNTED VERTICAL OR HORIZONTAL? The Outflow tube of the vertically mounted tank runs to within an inch of the bottom of the tank. The horizontally mounted Tank Design has an outflow tube that has a 90 degree bend half way down to 1" of the side of the tank if it mounted in the wrong orientation for it's design, it stops picking up LPG halfway down. When used in it's proper application, the orientation would be correct for gas pickup. A tank designed for horizontal mounting used in a verticle position picks up LPG for half of the tank, then it will light (because of the fumes are flammable) but do not posses the density to heat. (Too much Air) in the mixture fuel to air ratio. We found this out after pulling the shut off valve off of a tank with same problem. It was a horzontal tank used in a verticle positiuon. It worked for half a tank of fuel.
    Problem Solver:
  • 18 Answers
The overfill protection device in LP tanks will cause this problem if you open valve quickly. Try closing the valve on tank, unscrewing the tank grill regulator to relieve pressure from hose and then screw it back on. Open valve on tank very slowly then open the burner farthest away from tank first to light. then light the remaining burners while working your way towards the tank side. This has fixed my problem of low heat several times but that is also caused when tank is getting low so make sure you do have propane in the tank. for a 20 lb tank, and empty tank is 17.5 lbs so a full one would weigh 37.5 lbs.
Posted on Sep 08, 2011
Hello. I have Weber Summit 670 NG and I would like to convert it to LPG. I was told that it can be solved if I replace the NG Orifice with LPG Orifice. Is that true ? Where can I buy the LPG Orifice...
Ronni, unfortunately none of the Weber grills are approved for conversion from one type of gas to another. Each grill is tested and approved for it's specific gas type. Based on that, converting it, places all the liability on you, if something should go wrong. In addition, it takes more than just the burner orifices to convert a grill safely. With any gas appliance, always err on the side of caution and safety.
Thanks for choosing FixYa.
Sep 12, 2011 | Weber Summit S-670 Gas Grill
Burners won't heat adequately when I plum to bulk propoane tank supply line at my house. What is psi weber requires? Grill works fine when connected to portable tank.
For gas, it's not the psi, you need to know. It's the water column inches of gas at the grill. In which case, it should be 11 to 13 WCI.
If you didn't remove the original gas regulator on the grill. That's the problem. You bulk tank already has a regulator. However, if you LPG System is a high pressure system, then you would need a regulator, but not the one you have. Check with your LP Gas provider for the Btu output regulator that would be required.
Jul 04, 2011 | Weber Genesis Silver B Grill
Can a weber summit s-440 built in grill that is natural gas be switched to a propane?
The easy answer is yes. Unfortuantely Weber no longer sells conversion kits, even to me, and I am an authorized Weber waranty service company. The only thing you can do is try and find a competant grill company in your area who has the expertise to buy the correct orifices and then the expertixe to drill them out to the correct size for LP gas. NG orifices are to large and will give you wild, uncontrollable flames if just hook the grill up to LP. LP orifices are smaller because LP gas burns hotter.
Jun 21, 2011 | Weber Summit S-440 Gas Grill
Grill won't heat up above 200 DEGREES with a nearly full tank
Try replacing the regulator and hose, not very expensive and fairly easy to do. If that doesn't help, let me know.
Jul 11, 2010 | Weber Genesis Silver B Grill
How do I convert a natural gas grill to propaine
You would have to get the orifices from Weber for your specific grill. A couple of weeks ago, Weber informed me that they would no longer ge doing conversions, so I don't know if you can get the parts or not. You would also need an LP hose and regulator and an LP tank.
Jun 24, 2010 | Weber Summit S-650 Gas All-in-One Grill /...
We have a new Weber Genesis LP gas grill. The
My thoughts, are you turning tank off after cooking, not only turning of cooking valves but also turn off tank, if you don't gas will leak out. If you do turn tank off, then you have a leaking valve in the tank.
Jun 13, 2010 | Weber Genesis E-310 Gas Grill
New webber will not start
Ok, let's tackle the obvious things first. New grill with new tank... so was the tank filled? Did they purge it before they filled it? Did you turn the tank valve on very slowly? Were all the grill knobs turned to off when you turned on the gas tank? Try closing the propane tank valve, disconnecting it and reconnecting it. Then very slowly turn it on and light one burner at a time at turn to low heat. Then light additional burners the same way and adjust flame as needed after all are lit. Hope this helps! Douglas
Jun 06, 2010 | Weber Summit S-470 Propane Grill
Grill will not ignite even with manually trying
Can you hear or small gas? It's possible to may have turned the propane tank valve on too fast. Close the tank valve, disconnect it, then reconnect it. Slowly turn the tank valve back on and try lighting it again. Hopefully this is your solution, but let us know if you need more assistance. Or check out my Tips & Tricks for gas grill lighting problems, just click on my user name and scroll down to my Tips & Tricks and see if any of those solutions help.
Douglas
Jun 04, 2010 | Weber Summit Platinum C4 (LP) Grill
Can't get a flame
Unscrew the fitting off the tank and make sure there isn't an extra washer in there. Sometimes when you get a tank there will be a washer inside it that has slid of the last guys POL(screw in hickey) With this extra washer, the POL isn't going in far enough to open the tank valve.
Sep 08, 2009 | Weber Summit E-620 Gas Grill
Weber Genesis Silver A Grill Logo
299 people viewed this question
Top Weber Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
