Question about Gateway FPD2275W LCD Monitor
Pc Laptop display dim
Hi, i have this old dell laptop that has been working without any problems. Yesterday after using it for about 10 min, the display just turned very dim, it was difficult to see. So i pressed fn+arrow up-down and the display did become brigther but after about 5 minutes it went back to dark dim. Do you have any suggestion? Could it be power issue(friends advice) Thank you soooooooo much!
  • hadzibdic071 Nov 14, 2008
    ok, the monitor was fixed for couple of months, but yesterday it went dark! It was only after 10 min, so do you think that it is the same problem? I will change the power saving settings. oh, by the way, this laptop was originally purchased in USA, now i am using it in Europe, could this be of any effect?
    Thank you for your help, and have a great day!
  • Gateway Master
  • 19,396 Answers
If laptop is running on battery, that will be normal, check the AC adapter cable.
If laptop does that even when connected to charger, change power saving settings.
Posted on Oct 16, 2008
  • 4 Answers
Does sound like a power issue. Assuming it's windows xp, you can check to see if it is a poiwer management setting:
Go to start, settings, control panel, display, and on the 'screen saver' tab at the bottom should be the "monitor power" area, click "power".
There is a power schemes area there. Check out what your settings are. Laptops often have settings for when plugged in versus when unplugged; when troubleshooting this make sure you are positive about if you are 'plugged in' or not as it will affect settings! :)
(On Vista go to Control Panel, Power Options; same thing, change your settings there)
Posted on Sep 13, 2008
I have dell inspiron n5110 get charging problem sometimes then after a week my display becomes dim. I can able to see that my display is working with without brightness. I connect it to external display it...
Is the brightness ok if the charger is connected to the laptop and dull when the charger is not connected - also what operatng system are you using ???
Oct 13, 2013 | Computers & Internet
I have dell d600.when i switch on my laptop.on dell logo wnd windows logo it displays vertical lines blinking some dots.but when windows xp starts the lines disappears.and when i run a video then again it...
that the problem goes away when the pc heats up for a couple minutes would lead me to believe that the problem is a bad connection. in short driver issues and hardware failure rarely if ever fixes itself after 10 min of running, where a loose connection might tighten up as it expands in response to the` heat.
Oct 20, 2010 | Dell Latitude D600: Pentium M 1.6GHz,...
Error 2000-0334 Dell laptop
How can I repair the error 2000-0334 Dell Laptop?
Dec 31, 2009 | Dell Inspiron 6000 Notebook
I have a Dell laptop D505. The laptop powers up but the screen display is very dim. I can't see the image on the monitor. I've tried to manually increase the color/brightness button and nothing changes. ...
Sounds like your inverter or your backlight is failing. The inverter is an easy repair, the backlight can be replaced but it involves taking the LCD panel apart, The backlight comes installed on new screens. I can include a service manual below and possibly a generic guide to backlight replacement....
http://support.dell.com/support/edocs/systems/latd505/sm/display.htm#1052500
http://www.laptoprepair101.com/laptop/2007/01/31/replace-screen-inverter-fix-backlight/
Sep 23, 2009 | Dell Latitude D505 Notebook
Laptop went blank suddenly
chck the memory ,,and reboot the machn..thn c,,if nt tht remov the memory n clean it n put it bck and try
Aug 12, 2009 | Dell Inspiron 1525 Notebook
The LCD display dims almost to black after 20-40 mins.
Power save settings or it may have an ambient light sensor that automatically adjusts the screen to "match" the surrounding light. Power settings in the control panel will hold the key.
Aug 05, 2009 | Dell Vostro 1500 Notebook
Dell inspiron 6400 display goes off < 1 min after switch on time
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
If you see a very dim image or black screen or flicking image on the LCD screen it means you have a backlight problem.
The buzzing sound is most likely the inverter problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 26, 2009 | Dell Inspiron 6400 Notebook
Dell Vostro 1710 display problem
Hello My Dell Vostro Laptop Display Not Working Correctly it showing Dim but in other desktop when i connect to the Laptop Of Mine it showing Correctly With No Dim Problems? How can I fix the Problem?
Nov 19, 2008 | Dell Vostro 1500 Notebook
Dell inspiron 4150 video dim
The empty slot is for a mini-PC card, usually a wireless network card. The 2 wires are actually the antenna wires that connect to the wireless card. The dim LCD may be a problem with the LCD panel display, video controller or motherboard. Try connecting the laptop to an external monitor by connecting to the Video Connector located on the back of the laptop. If the display on the external monitor appears to be normal, then your LCD display panel on the laptop has a problem. If the display on the external monitor is dim then you probably have a bad video controller card or motherboard.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 25, 2008 | Dell Inspiron 4150 Notebook
Dell Laptop Screen goes Dim After 5-10 minutes
plase use another RAM in the same machine if the sam e problem will arise..its u r mother board prblem otherwise u r ram problem
Jan 19, 2008 | Computers & Internet
Gateway FPD2275W LCD Monitor Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
