Question about Kitchen Ranges
Oven thermostat needs adjusting leisure voctoriana si - ffd replaced recently
  • idrisfawr Sep 13, 2008
    We recently had the ffd in our Leisure Victoriana SI replaced as it was failing to heat up. We now have heat but not much control (according to the thermometer we put on on gas mark 2 the temp was about normal for gas mark 4).
    Can anyone tell me whether the thermostat can be adjusted and if so WHERE is it...
    Thanks
    Apologies should have said it is a gas stove
    Sergeant:
  • 409 Answers
Is your stove gas or electric?
most stoves have a heat probe, unfortunately it cannot be adjusted.
is there are fault code on the display?
Posted on Sep 13, 2008
  • Carmen Mikulic Sep 13, 2008
    in that case can you supply me with the make & model # please?
How to Change The fsd on the two ovens of the rangemaster leisure classic 110
hello Terry,
it is not to difficult.
I tried to download a picture here, but that does not work.
On this link, you can see how they look like:
https://www.ebay.co.uk/p/Rangemaster-110-A027947-Gas-Oven-Burner-FSD/1123358801?iid=322891761660
Here you have the complete unit. This unit is connected at the bottem of the oven with 2 screws. You need also to disconnect the small gaspipe. Then you can remove the whole item.
When that is done you easyly can remove and replace the ffd.
I wish you succes.
Kind regards, Di
Feb 15, 2018 | Rangemaster Kitchen Ranges
Oven igniter comes on gas burner lights but goes out after 15 seconds cutting power to the stove power comes back on after a couple of minutes model mgs5770
Hello Susan,
it is not quite clear to me what you mean.
But I think, the ingition in the gas oven works and lights the burner.
and then after 15 seconds the burner goes out.
Any modern oven has a Flame Failure Device.
That prevents the oven getting gas when the burner went out for some reason.
I would suspect that FFD, it is mounted besides the burner.
You can not repair that part for safety reasons, You have to replace it when it is gone.
Kind regards, Dik
Flavel Leisure Cooker Spare Flame Failure Device FFD CO1464
Feb 10, 2018 | Kitchen Ranges
Hello Susan,
Kind regards, Dik Flavel Leisure Cooker Spare Flame Failure Device FFD CO1464
My leisure 90 FFD will not energise to allow any gas through to go through the liting process. Any ideas or anything similar would be most helpful. Its a new FFD.
  1. Brochures and Manuals for Leisure Freestanding and ...
    leisurecooker.co.uk/manuals/brochuresmanuals To learn more about the Leisure range, please download a copy of one of our brochures.For any questions about the day-to-day working of our range cookers, ...Missing: ffdenergise
Jul 21, 2015 | Leisure Kitchen Ranges
Creda cf50g cooker oven not getting hot
sounds like the ffd is at fault, this is a safety device that alows the main flow of gas through. when the cooker is cleaned the sensor can be moved by accident from its position over the flame, another reason could be a build up of grease etc, stopping the flame reaching the sensor. if none of these then the ffd unit needs to be replaced. they are about £20.00 for the part
Apr 06, 2010 | Ovens
I have a leisure rangemaster 110 double gas oven the left oven stays low i have tried cleaning jets but this has no effect can you suggest a cause
the flame safety device need replacing (FFD)... this lets the full gas through when flame is sensed... safety 1st as a gas engineer will be required..
Dec 18, 2009 | Rangemaster 110 (Gas) Kitchen Range
Both ovens only light to pilot light, wont go
Faulty FFD's ( flame failure devices) once the flame is established it allows the full flow of gas to the burner... must be a gas-safe engineer to replace part..
Dec 17, 2009 | Rangemaster Classic 110 Kitchen Range
How do I fit a Flame Failure Device into a Mistral EL
you should not attempt to repair this unless you are gas registered. It is against the law!
Oct 21, 2009 | Ovens
How to fit a flame failure device to rangemaster 55
the part that you need is the oven ignitor, located nest to the oven burner. that part gets hot to open the gas to the burner, that will make the oven work again.
Dec 08, 2008 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Leisure rangemaster 55 gas cooker
It sounds exactly the same as I am experiencing on my oven of the same model. My theory is that the full flame gas is controlled by a thermostat, and that this has broken hence why the oven only stays on preheat. This will be a matter of a replacement part. Most likely the thermostat is a bi-metal strip that, because it has heated and cooled so many times in it's life it has simply finally given up. Try searching online for the correct part and get a corgi registered fitter or another suitably qualified fitter to come and replace it.
Nov 13, 2007 | Ovens
Kitchen Ranges Logo
313 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
