Question about Garden
How to adjust carb. settings on a McCulloch Pro Mac 610 chain saw
Model 600041c start up settings mabe from factory
  • Anonymous Nov 18, 2008
    McColluch 610 setting for H/L are just 1 1/2 turns and not 2 1/2 turns.
  • Anonymous Mar 22, 2014
    Please could you tell me the factory settings of a carb on a model 355 chainsaw
Turn both jets in untill snug (don't force) turn out ccw one full turn. increase by 1/8 turns untill set proper. should be between 1 1/4 and 1 1/2 normally. good luck. be safe.
Posted on Sep 21, 2008
How to repair vacume leak on pro mac 610
Where is the leak coming from? I'd check the Gas line between gas tank and carb.
Oct 02, 2012 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I have an older McCulloch chain saw- Pro Mac 610. When using the saw the chain will get very tight. If I adjust the chain to the proper tension, make a couple of cuts the chain loosens and must be...
The main reason for a chain to tighten is because it is not getting enough oil to the bar, or too thin an oil is being used, you should see a good spray of oil off the end of the bar when held against a tree stump, if not try adjusting the flow if it has an adjuster.
Apr 01, 2011 | McCulloch Points Pro Mac 6 Or 6a Chainsaw...
Where do u tighting up the chain on the chain saw.
Depends on what model, however there are two main locations for the adjuster screw, the most common is at the very front of the saw, running inline with the guide bar , you may well have to clean the dirt and saw dust from the front of the saw to see it,it will be close to the inside edge of the bar, it will be a normal screw driver head screw, turn clockwise to tention the chain, the other type will be in the side cover, at right angles to the saw, again it will be a normak screw driver head, turn clockwise to increase the chain tention.
Mar 20, 2011 | McCulloch Garden
What should the carburetor settings suppose to be on a mcculloch pro mac 610
Most of the time about 2 rounds out, but you will have do the fine adjustments with the saw running.
Jan 07, 2011 | McCulloch Garden
Chain Saw Collectors Corner
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/564ff25e56449e8c88256c2f001cd723?OpenDocument
Current mix for McCulloch/Poulan is 40:1.
1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
If your saw is adjusted for 50:1 it starts easier, takes longer to carbon foul, and your grandchildren breath a little easier.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 09, 2010 | Oregon Scientific Oregon S54 Replacement...
I have a McCulloch chain saw- pro mac - 610- the saws chain lock came apart, do you have a diagram of one?
This saw? Be kind to your elders.
The IPLs I’ve found for your saw don't show this detail. I suggest you try here:
ArboristSite.com Chainsaw thread
http://www.arboristsite.com/forumdisplay.php?f=9 (free to join)
There is a McCulloch thread. Your saw is held in high regard. I’m quite sure some of the members will be willing to post some close up photos of the set up on their saws. HTH
Lou
Sep 27, 2009 | McCulloch Garden
Operator and parts manual
Robin219,
I have found an owners manual on E-bay for 7.99 + Shipping. Will this suit your needs? The Auction on it ends on Sunday the 25. Take a look at http://cgi.ebay.com/McCULLOCH-CHAIN-SAW-PARTS-MANUAL-FOR-PRO-MAC-610-%2F-650_W0QQitemZ360124205014QQcmdZViewItemQQimsxZ20090119?IMSfp=TL090119129004r31016 Hope this works out for you.
Jan 21, 2009 | McCulloch Garden
McCulloch Pro Mac 610 replacement chain
The McCulloch ProMac 600 series (610/650) doesn't recommend a saw chain replacement part because you can get differently-sized bars for it. This one came with a 20" bar.
According to an Amazon.com search tonight, the Oregon company makes a replacement part stock number D70. I have got an Oregon H78 replacement chain at my hardware store and it's a hair too small. Not all 20" saw chains are created equal!!
Dec 07, 2008 | Oregon Scientific Oregon S54 Replacement...
Garden Logo
4,282 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
