Question about Dell Dimension 5100 (D51L1) PC Desktop
Dell dimension power supply / motherboard
We had a power outage today and even with a good surge protector my PC now will not start. The green LED is on when the unit is pluged in but it will not fire up. I have 5volts on 2 wires going to motherboard, I have no power at the on/off button on the front of the PC. Question is: How do I know if my power supply is bad or the motherboard? Can anyone help? Comment by kristech, posted on Sep 13, 2008 I have had the power supply in and out of the machine several times, I have reseated all possible connection cables and still nothing.
Just trying to figure out which part is faulty without taking the whole thing into the shop.
  • Anonymous Sep 23, 2008
    I pulled the supply, plugged in 115V, shorted PSON to GND in the ATX
    connector. The fan turned on and all supply voltages checked ok.
    I plan to strap PSON to GND and put the supply back in the PC and see if it runs. Maybe the switch is bad.
  • 749 Answers
You can pick up a P/S checker for about 20 bucks all over the net. we used to have to use an oscilloscope to check it for spikes and such....
Posted on Sep 17, 2008
Can't turn my computer on and i have a yellow blinking light on my dell dimension E510
Do you use a surge protector? If you do, try turning off the power supply to the surge protector and switch on again.
There are a number of causes for this problem, the most likely being a PSU problem or a motherboard fault/failure. To check the power from the PSU to the motherboard, you will need a multimeter to make sure enough power is going to the motherboard. Also check the motherboard closely to see if there is any signs of corrosion or blackened areas, which could be caused by overheating components. Check for leaky or burnt capacitors.
Apr 13, 2012 | Dell Dimension E510 PC Desktop
I recently had a power outage for about an hour. My desktop was protected by a surge protector. After the power came on, my computer won't power up and there's no power light. However, there is a blinking...
if the system will not power on, I would suggest a new power supply as the first troubleshooting option as they are about 1/3 the price of the motherboard. The Flea Power indication on the motherboard only indicates power is reaching the board, not if all needed voltages are being received.
Normally on a Dell, if you are getting power then when you attempt to power on, you usually get a power LED indication on the power button. Solid Green/Blue is normal, Flashing Amber is Power supply bus failure, Solid Amber is normally a motherboard.
If you haven't bypassed the UPS and connected direct to the outlet, I would try that 1st, as the UPS could be the failure too.
Dec 23, 2010 | Dell XPS 200 PC Desktop
Dell Dimension 3100
You most likely just need a new power supply. You can pick these up for around $40 for a 450W, which is plenty for your machine. Pretty simple to replace, unscrew the 4 screws in back, around the fan on top, then unplug all the power wires, pull the old one out, and then put the new one in. There is a slim chance that other components were damaged, but this is your first step to fixing it. The power supply is the martyr of the computer. It will throw itself in front of power surges to save the rest of your computer....
Feb 11, 2010 | Dell Dimension 3100 PC Desktop
Will not turn, might new parts
Try replacing your power strip or surge protector first. Verify that any power switches are turned on on the back of the PC where the power plugs into.
If not, try contacting your nearest Dell certified service center. You may have received a serious jolt which could have damaged one or several components.
Nov 25, 2009 | Dell Dimension 2400 PC Desktop
Computer won't power up
The power supply should have given way. Replace the PSU and check if it works.
Jun 24, 2009 | Dell Dimension 2400 PC Desktop
Desktop won't start after Hurrican IKE power outage
the only thing i can think of is the power supply got fried that is the most common problem when it comes to the pc not powering on. Now hopefully that is all that it fried and not the motherboard my suggestion is to take to local pc repair shop and have them change your power supply or you could put it in if you familiar with how the machine is wired.
-replex
Sep 14, 2008 | HP Pavilion a800n (PP163AA) PC Desktop
you may consider reseating the P1 and P2 cables (from the power supply) connected to the motherboard.
you can go to www.support.dell.com and enter the service tag of your dell system (found at the back of your system) and look for the manual on how to add/remove the parts of the computer.
thanks.
Sep 13, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Power outage, now pc will not power up at all.
sounds like the surge protector didn't protect. I would change the power supply.
Jun 12, 2008 | HP Media Center m7060n PC Desktop
OK FIRST A POWER SURGE PROTECTOR WILL ONLY PROTECT YOU 7 % OF THE TIME, WHICH YOU JUST REALIZED. SO YOU NEED TO BUY A BATTERY BACKUP ALSO KNOWN AS A UPS.... I CANNOT STRESS THIS ENOUGH. BRING YOUR PC TO BEST BUY AND THEY WILL TEST YOUR POWER SUPPLY, IF IT TESTS OUT OK THEN YOU BLEW SOMETHING IN YOUR MOTHERBOARD. GET A BATTERY BACKUPS/UPS!!!!!!!!!!!!!!!
Dell 5100 Dimension - No Power
there are fuses inside psu`s some are solderd and some pop out it i would suggest that u throw the psu away and buy new chances are that it will only cause continues and may even result in
complete mobo failure problems heres a link to a cheap psu   http://www.microdirect.co.uk/(3649)400W-P4AMD-quiet-PSU-with-PFC-20-pin-24-pin.aspx or a more upmarket more powerfull http://www.microdirect.co.uk/(11879)ThermalTake-TR2-500W-Black-Silent-ATX-12V.aspx the choice is yours.
Nov 18, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 (D51L1) PC Desktop Logo
Alun Cox
