Question about Apple iPod MA446LL/A MP3 Player
IPod is not getting switched on
I have not been using my iPod (say for 1 - 2 months) and now I find it's not getting switched on and also not recongised by the system when connected thru a USB port. Please help.
  • winniethepoo Sep 13, 2008
    I tried the above link (to set the iPod back to factory settings), but the problem with my iPod is
    1. Not getting switched on (Display is blank always)
    2. Not recongised by the system.
    Please help.
    Now I remember the last time I tried to use my iPod to listen to songs, the battery level was very low. I tried charging it thru my system's USB only. Looks like my iPod's battery is drained. I tried connecting to USB for some 4 hours, but the sam blank screen continues. Is there still a way to get this resolved?
  • 1,879 Answers
  • monk3ybidzness
    monk3ybidzness Sep 13, 2008
    missed the first one - not turning on as in looks like dead
    tried charging it using another power source line an AC adapter? If yes, nothing else we can do since all resets need the pod to be fully charged and it's not even charging via USB.
On the ipod 20gb after apple logo comes then bettry logo comes
Reset Click Wheel Ipod (newer ipods including resetting an ipod video)
1. Flip the Hold switch on and off and make sure it ends up no longer on hold.
2. Press and hold the Menu and Select buttons (center Button) until the Apple logo appears (may take 5-11 seconds, and you may need to repeat this step)
If this not work for you try plugging your ipod into computer or wall power
Resetting iPod (with dock connector)
Most problems with iPod can be solved by resetting it.
To reset iPod:
1 Connect iPod to a power outlet using the iPod Power Adapter.
2 Toggle the Hold switch on and off (set it to Hold, then turn it off again).
3 Press and hold the Play/Pause and Menu buttons for at least 5 seconds, until the
Apple logo appears.
If Your iPod Won't Turn On or Respond
* Make sure the Hold switch is off.
* If you're using the iPod Remote, make sure the remotes Hold switch is off.
* If that doesn't work, connect iPod to the iPod Power Adapter and connect the
adapter to a working electrical outlet. Your iPod battery may need to be recharged.
Resetting iPod (with out dock connector)
If that doesn't work, your iPod may need to be reset.While the iPod
is connected to power, press and hold the Play and Menu buttons
for at least 5 seconds, until the Apple logo appears.
Mar 03, 2011 | Apple iPod classic MP3 Player
Ipod touch
Your battery is draining too fast . There is some problem with the internal battery .Since it is brand new I will prefer you to go to apple service center to get your itouch repaired . Some products will be having these kind of problem . Apple will replace it .
Hope this helps .
Thanks for using Fixya.
Feb 27, 2010 | Apple iPod touch
My lock symbol wont come off my ipod can you please help?
1. Try sliding the little switch on the top on and off several times. If that doesn't work the slide switch is broken. If it's under warranty (12 months), take it to your nearest Authorised Apple Service Centre and they will get it exchanged in a couple of days
No warranty? Google "iPod repairs" in your country and you should be able to find someone who can fix it. The usually have a self diagnosis on line so will get an idea of the cost before you begin
Nov 30, 2009 | Apple iPod nano
Ipod is not playing..PLzzz help
auto fill all songs with the help of itunes by updatings music library
Nov 26, 2009 | Apple iPod shuffle Second Gen. Silver (1...
Ipod nano not charging on jbl docking station 2
my apple ipod is not charging what should i do plz help me [nano 3rd genaration]
Jun 07, 2009 | Apple iPod touch
My ipod shuffle won't charge
ok try this and see what happens. plug in the charger and let it charge for a while.
unplug it and find the switch on the top of the ipod which you will turn off. No Green will be showing.
wait 5 minutes and whic it to shuffle or play and you should have just reset you shuffle.
Good Luck
May 24, 2009 | Apple iPod shuffle Second Gen. Silver (1...
Dead ipod 18 months old
Hi, Lets try 1 more step.!!!!!!!!!!
Try connecting ur ipod to ur computer..If desktop, then conenct it to USB port at the rear of ur computer....Make sure ur computer is not set to sleep mode or screen saver mode... Charge it for at least 4 to 8 hrs(without a break)... Then try reseting the ipod when it is connected....
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Let me know the status????
Feb 20, 2009 | Apple iPod MA446LL/A MP3 Player
IPod not getting switched on and not recongised by system
This could be due to a broken usb cable.... if not that,give it a 24 hour charge!
thanks for your question,
have a nice day
Sep 14, 2008 | Apple iPod MA446LL/A MP3 Player
Apple iPod touch Not able to Switch ON
http://www.ziphone.org/
Use the Ziphone ipod touch and iphone jailbreak GUI to put the ipod in recovery mode. Then restore it using iTunes.
You don't have to jail break it.
THat happened to me once when I installed something on my ipod.
it kept on restarting, and i used ziphone recovery and started over.
Make sure to get 1.1.4 firmware. its the most recent update on ipod touch.
May 28, 2008 | Apple iPod touch
Apple iPod MA446LL/A MP3 Player Logo
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
