Question about Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water
Ice Maker not dispensing ice...
Hi Guys! Hope you can help. My ice maker makes the ice and drops it into the bin fine. It won't dispense it down the chute. The electric panel seems to be working fine and water still dispenses. When the button is pushed it hums as though it's trying but then it sometimes makes a loud pop and nothing comes out. I took it out and inspected the auger and blades and saw no obstructions. The auger doesn't turn all the way around, however, and I don't know if it should or not. It just shifts about 120 degrees back and forth in the bottom of the bin. Any suggestions?? Thanks!
Thanks anyway, guys, but I figured it out. Hopefully this can help someone else. I noted that the auger indeed is supposed to rotate fully and not just swing from side to side as mine was doing. I then noted that my auger had screwed itself too far into the slotted plastic plate at the back of the bin. It was therefore lopsided in the bin and hitting on both sides. I took the contraption apart so that I could back it out and put it back correctly in the slot. The ring shape of the end of the auger fit snugly back around the round plastic ring again. Buttoned it all back up and I'm good to go....for now. (smile)
Posted on Sep 14, 2008
Ice maker will only provide crushed ice through the front door dispenser
The stirrup behind the ice maker is in the up position remove the ice bin and find the square hole and make sure the plastic stirrup is down, then reinstall the bin
Jan 06, 2016 | Refrigerators
Why is icemaker making a clicking sound?
Ice Maker Not Dispensing Ice ' ThriftyFun
www.thriftyfun.com/Ice-Maker-Not-Dispensing-Ice-4.html
Sometimes your refrigerator ice maker makes ice, but does not dispense it. ... If it gets pushed all the way back to the ice maker it prevents the metal arm from full ... Itry not to put anything on the shelf over the bin and also try to keep it pulled out just a little ... My ice maker is making a clicking noise and not making much ice.
Ice maker making ice, but won't come out thru door
www.appliance-repair-it.com/ice-maker-making-ice-but-wont-come-out-...
If when you attempt to dispense ice (and it doesn't work) the whole refrigerator seems to .... Many have just bought a new refridgerator or don't use the ice dispenser. ... I'vetried to decrease the cold in it from the dial and that doesn't help. ... The motor was working and the auger would turn with no ice in bin but the added ...
Dec 25, 2015 | Samsung RH29H9000SR RH29H9000SR 29 cu. ft....
Frigidaire frs6lf7fm. Ice maker dispenser, the auger won't turn (tested with ttay out). It makes ice and dumps it into the bin no problem. And the water side is fine.
[FIXED] Icemaker auger motor won't turn - ApplianceBlog
www.applianceblog.com/.../18196-FIXED-Icemaker-auger-motor-won-t...
Apr 16, 2010 - 9 posts - ‎2 authors Does the auger motor need to be re-set or something? I wonder if it shut itself down to prevent burnout (because it had been unable to turn the ... FIXED Auger won't turn to dispense ice.
Jun 1, 2014
Ice maker auger will not turn
Mar 17, 2013
FIXED Ice Auger won't turn
Sep 3, 2012
GE Icemaker: Makes Ice, Doesn't Dispense In Door?
Apr 19, 2005
More results from www.applianceblog.com
Oct 01, 2015 | Frigidaire Refrigerators
Buzzing sound Kitchen Aid fridge Model KBLA20EMSS
It may be the arm in the ice maker is down. Even though the ice maker does not have the water hooked up if the arm above the ice bin is down it will still cycle the ice maker try lifting up the arm it should stay up this signals the ice maker that the bin is full and should shut off the ice maker. Hope this helps.
Dec 31, 2013 | KitchenAid KSCS25FKSS Side by Side...
My refrigerator won't dispense ice cubes or crushed ice or water at the front door, I was wondering if it could be the Touch pad control panel on the front of the refrigerator. If it is can you give...
The front touch pad board /panel which you are referring is called dispenser board.To access the dispenser board assembly, click this link below:---
http://howtobyme.blogspot.com/2011/06/ge-side-by-side-refrigerator-will-not.html ------------ The dispenser board removal procedure is mentioned at the last on the link instructions.-------- -------------- But the engineer at your place has pointed you to right direction.The main control board is most probably the cause of problem.One more important thing.There are many other users too facing same problem with there ge side by side refrigerators.This problem occurs in many ge model refrigerators. There was service letter released by Ge for this problem.Click this link, to read the letter:--- http://howtobyme.blogspot.com/2011/07/ge-side-by-side-refrigerator-wont.html -----------
You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.
----------- This should help. Thanks.Helpmech.
Jul 28, 2011 | Refrigerators
Ice maker quit qorking
The chute where the ice drops through could be icing up, try removing the I bin and cleaning the ice build up out.
Jun 16, 2009 | Maytag MSD2456G Side by Side Refrigerator
Ice maker not getting water after changing filter
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
The ON/OFF switch is located on the top right side of the freezer
compartment.
To turn the ice maker on, slide the control to the ON (left) position.
To manually turn the ice maker off, slide the control to the OFF
(right) position.
NOTE: Your ice maker has an automatic shutoff. The ice maker
sensors will automatically stop ice production, but the control will
remain in the ON (left) position
REMEMBER:
 Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
 The quality of your ice will be only as good as the quality of the
water supplied to your ice maker. Avoid connecting the ice
maker to a softened water supply. Water softener chemicals
(such as salt) can damage parts of the ice maker and lead to
poor quality ice. If a softened water supply cannot be avoided,
make sure the water softener is operating properly and is well
maintained
The Dispenser Lock (on some models)
Your dispenser can be turned off for easy cleaning or to prevent
unintentional dispensing by small children and pets.
NOTE: The lock feature does not shut off power to the product, to
the ice maker, or to the dispenser light. It simply deactivates the
dispenser levers. The ice and water dispensers will not work.
Style 1: Press the LOCK BUTTON to lock the dispenser. Press the
UNLOCK button to unlock the dispenser.
Style 2: Press and hold the LOCK OUT button to lock the
dispenser. Press and hold the LOCK OUT button a second time to
http://www.ajmadison.com/ajmadison/itemdocs/2261717.pdf
May 15, 2008 | Whirlpool GS5SHAXN Side by Side...
Open Questions:
See all Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with Questions
Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water Logo
445 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
