Question about Mitsubishi VS-45607 45" Rear Projection Television
Big screen 45in tv
When i turn my tv on its a white screen for about 10-30 minutes before the picture comes in. and now the picture is blurre & red
  • 927 Answers
Good Day;
More than likely your TV has "COOLANT" (ethylene glycol) on the circuit boards. This fluid comes from the CRT's (picture tube) this fluid is used to keep the CRT's cool, such the name. This fluid from the CRT's leak when TV is on for long periods of time, the chamber expands and the seals leak.
One can remove this fluid by using "acetone" & small brush. The fluid is hard to see, use bright light, they spots can be smaller then a DIME. Also, the fluid can corrode the parts and traces on the boards. To protect the TV in future place heavy plastic or thick cardboard over affective area, make sure TV has proper air flow around TV.
If after the fluid has been removed and TV still does not work, call an Authorized Service Center to come out and repair TV after giving you an Written Estimate. The boards are not available.
Always try resetting the TV by unplugging it for one minute then plug back into A/C outlet and ALWAYS UNPLUG TV BEFORE ATTEMPTING ANY REPAIR ON THE TV.
Or you may have a picture tube going bad.
Good Luck, big IRISH.
Posted on Sep 26, 2008
Just the blue on my rca projection tv is blurred. on the auto convergeance it says it cant read the sensor. on manual the cross hairs for the blue are oversized and blurred. i tryed tuning in the focus but...
Have you try adjusting your focus/screen drive controls to Tube R/G/B you have a focus/screen drive control block to adjust each Tube 3 controls ontop 3under them top ones are for Focus bottom is for screen drive.Red/Green/Blue Tubes.You might need to replace convergence IC, what is your Model number printed on back of TV?
Mar 24, 2010 | Televison & Video
Redness in picture
The Convergence amps in this TV set will need to be replaced. This is a typical repair that has to be repaired in almost every tube type projection TV set ever made. Not really a hard job, but a knowledge of printed circuit boards and soldering will be needed and if you do not have the soldering and unsoldering skills, leave the repair to a pro. A repair such as this will run anywhere from 225 up yp 400 bucks. Good Luck and let us know how this repair worked out for you.
Dec 08, 2007 | Mitsubishi WT-42313 42" Rear Projection...
I have a hitachi rptv model #43FWX20B and the picture has a red tint to it. Opened back up and red green and blue bulbs light up. red bulb stays bright while blue and green go dim to bright as tv plays....
Since you don't have any white lines with the red screen/picture I would say that the red bulb (CRT) is conducting too much. There is an adjustment control for that. The 'sceen' control is behind the speaker cover and service cover. Turn red screen control slightly to the left until you get a good black and white picture.
Good Luck, Big Irish.
Nov 22, 2009 | Hitachi 43FWX20B 43" Rear Projection...
How do I connect a sony cd/dvd player to a onkyo receiver model Tx-SR600 to a Mitsubishi big screen TV model no. WS-65411 . I cannot get a picture for the dvd when I turn on the player I have sound coming...
If your using compsite cables, Yellow , Red and White cables the red and white is sound you connect to reciever, then yellow to the coposite in on the Tv Screen. If it is a HDMI cable connect to Tv Screen not Reciever. What cables are you using?
Nov 08, 2009 | Sony Televison & Video
Hello my name is steve
1. Make sure the Cable is properly connected to the back of the Xbox.
2. Make sure the Cble is properly connected to the inputs on the TV (Color coded if using component or composite cables).
3. Look on the large part of the cable where it plugs into the Xbox. There is a switch with two settings: HDTV and TV. If using the component cables (Green, Blue, Red + White Red), turn the switch to HDTV. If using the composite cables (Yellow, White, Red), switch it to TV.
4. If the problem persists, contact Microsoft at 800 4MY - XBOX . It's a toll free number but it isn't 24 hour.
plz Rate"
Dec 17, 2008 | Microsoft Xbox 360 Console
One side of blurryness
now one thing at a time. the picture that is blurr does it have red or blue lines on the rt or lt side it sounds like the convergence is out on the unit and that will cause the picture to be blurry. and is the big screen in warranty please let me know marty
Oct 09, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Red tint on screen
Good Day,
Try resetting the TV by unplugging from wall outlet for 3 to5 minutes then plug back in. If no fixya take front grill off and panel and adjust the screen controls, turn color off adjust for Black & White Picture. Good Luck, big IRISH.
Sep 13, 2008 | Hitachi 53UWX10B 53" Rear Projection...
RAC TV When I turn it on the red light starts to blink and then the light goes completely red yet the screen is still black. I can not turn it off. there is no picture but due to my sterio hooked up to...
Good Day, msteaz;
Not sure what the light is doing but try to reset the TV by unplugging from the A/C outlet for 5 to 10 minutes. If no fix come back with Model & brand.
Good Luck, big Irish.
Sep 01, 2008 | Televison & Video
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Blurr picture and very red faces
Open the front cover of the tv and try to adjust the screen adjustment thruogh the screen variable resistor.
Nov 17, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
69 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
