Question about Canon PowerShot SD300 / IXUS 40 Digital Camera
Lens I dropped my ixus 40 camera, and now the lens won't close. I turn it on and an error 18 comes up. The lens attempts to close back up when I switch it on but seems to be stuck... Should I send it away to be repaired? If so, can you recommend a repair shop?
    Scholar:
  • 116 Answers
Hi Meaghan, If it was me (and this did happen to my camera as well) I would take it to a camera shop. For about $50.00 they can put the lens back on track, and clean it as well. This is a great camera, and I would not risk taking it apart myself. If you tell me what city you live in, I can also suggest a close, and reputable camera shop. Best regards, nightdiver
Posted on May 26, 2006
  • 513 Answers
Tap the lens before and when turning on, it might help it jog loose. Very delicate mechanism, tiny wheels, easy to get it screwed. If you're feeling like an adventure, you can get a tutorial on how to fix it here(i'm not taking the blame if you kill it): http://www.fixya.com/problems-solutions/t102982,p293959/Canon-Digital-Cameras.aspx Good luck
Posted on May 24, 2006
  • 21 Answers
Hi: Your camera has the lens stuck. I sugest that you dissemble the camera and try to snap the lens gently back into place. ;) Regards
Camera says lens error and shuts down immediately. Lens won't close.
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Sep 05, 2011 | Canon PowerShot SD1300 IS IXUS 105...
The camera comes on then beeps about 4 times then turns itself off, the lens is out and wont go back in. I have put a new battery in but still wont work
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Sep 28, 2010 | Canon PowerShot SD400 / IXUS 50 Digital...
What can i do if my ixus 55 has been dropped on the ground and it can't work? i mean, i accidentally dropped it on the ground and after that, it could not be turned on again. i tried every thing. how can i...
Jun 18, 2010 | Canon Powershot SD450 / IXUS 55 Digital...
My canon IXUS 70 digital camera keeps coming up with message "Lens error, restart camera" when I turn it on, then it just turns itself off
Jun 14, 2010 | Canon Cameras
Here are some things that you can do to try to correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, or if repair costs close to the value of the camera, they're worth a try.
Jan 31, 2010 | Canon Digital SD900 / IXUS 900 Ti Digital...
Camera lens dont close
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 01, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Error #18 Lens will not close and camera shuts off
Hey louboyens,
According to the manufacturer error code 18 is a lens error code. What that means is something is obstructing the movement of the lens. I would make sure that your hands or anything else is not preventing the lens from moving correctly when your powering the camera on, and make sure the camera is powered off and not powering on while in your camera bag. Try turning it off and back on and after this the camera still displays the error code you should probably have it looked at by an authorized service technician.
Sincerely,
Allan
Go Ahead. Use Us.
May 15, 2008 | Canon PowerShot SD550 / IXUS 750 Digital...
E 18 problem
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're still worth a try. Good luck! :
Feb 13, 2008 | Canon PowerShot S500 IXUS 500 Digital...
E 18 problem
The dreaded E18 error happens to many Canon cameras.
This error occurs when the lens is mechanically stuck. Sometimes you need it to be serviced and most times you can fix it, but even then it's a good idea to have it serviced soon. The cause to this may be dust, dropping and other mechanical problems.
1. Check if the battery is full
2. Check for visible mechanical problems (obstacles, debris). You may notice the lens is not exactly straight - in this case this is the cause of the problem.
3. Turn the camera off.
4. This needs to be done with gentle force: Take the camera in one hand and with the other gently take each part of the lens and gently move it round in a circular movement. Do this with both sections of the lens. You will hear a little "click" as it pops back in place.
5. Power the camera on.
Hope this helps!
Jan 09, 2008 | Canon Powershot SD450 / IXUS 55 Digital...
Error 18
The "E18" error code indicates an error that involves the lens unit or lens cover. This error may appear where the lens is prevented from properly extending or retracting such as, for example, when pressure is applied to the lens or the area surrounding the lens while handling the camera. The error may also be displayed if the lens unit/camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera. Solution Check the following when you operate the camera to avoid applying pressure to the lens and surrounding area: - Hold the camera so that your fingers do not touch the lens unit when you are shooting. - Make sure the camera is off before you put it back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.
Aug 31, 2005 | Canon PowerShot SD300 / IXUS 40 Digital...
Canon PowerShot SD300 / IXUS 40 Digital Camera Logo
126 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
