Question about Dryers
Dryer runs for 2-5 minutes then shuts off.if you hold the start switch on then it runs but shuts off when you let it go
    Novelist:
    Champion:
  • 261 Answers
When you have to hold the start button to run the dryer you are doing the job of the motor centrifigal switch. Initially you press the button and the motor turns over closing the motor switch so it will run and heat to dry your clothes. These days that switch is not replaced, only the motor. So you need a motor and I will be happy to find you one if you can supply me with a model number.
Searstechtoo
Posted on Sep 13, 2008
Dryer won't stay running without holding down the start button
It may be the centrifugal switch on the motor. The push button starts the motor and as the motor spins up to speed the centrifugal switch closes to keep the motor running. Hope this helps.
Jan 02, 2014 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
My dryer will only run for 5-10 minutes
sounds like you have a bad motor,when it heats up it's stalling and when you go to restart it there are start windings and run windings in the motor it's not switching over to the run windings so when you hold the start switch in you're sending constant power to the motor,all it does is when you push the button it's a momentary switch power goes to the motor and hits the start winding in the motor should be just for a moment,then it switches over to the run winding and this keeps the motor running,your motor isn't doing this,
Dec 23, 2017 | Whirlpool Dryers
Kenmore dryer 70 series doesn't always start, sometimes it will just put out a buzzing sound after its been running and trying to restart, will start back up after 20-30 minutes.
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
Oct 02, 2011 | Kenmore 63942 Dryer
I have a Kenmore Elite Heavy Duty King Size capacity Quiet Pak gas dryer. The model # is 110.76922501 and the Ser # is MTO502806. The problem I am having is that the dryer sometimes does not start when...
the push to start switch holding coil is getting weak and can no longer either make contact or drop out shutting down the unit,there is a coil that energizes to hold the switch on and when the contacts or coil get weak the unit either wont start or start and drop out/quit,you can test this switch by bypassing it and if unit keeps running the switch is definitely bad then the unit is a whirlpool produced for kenmore by the 110# you provided so you need to order a switch either thru whirlpool or sears
Aug 22, 2011 | Kenmore Dryers
Dryer shuts off after 15 minutes
make sure the top is not bent down
Jun 15, 2010 | Whirlpool LGB6300 Gas Dryer
Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
Jun 21, 2009 | Dryers
Press start button and dryshuts off when start button is released
There is a switch assembly on the motor that activates when the motor is running. Centrifugal switch. It keeps it running when you release the switch. That is where to start. Eric
Jun 11, 2009 | Kenmore 74992 Gas Dryer
Dryer runs as long as you hold switch
You already know whats wrong. the switch is starting to go bad. replace and all should be back to the norm.
Jan 26, 2009 | Dryers
Starts with asistance then shuts off.
A centrifugal switch selects the start winding, but the run winding is always selected, according to the wiring diagram.
So, it could be a bad centrifugal switch, or a bad motor. You can test the motor by measuring the resistance between the blue and white-orange wires (the run winding), and between the blue and violet wire (the start winding). Both values should be under 4 ohms.
To continue running, the motor run winding must be OK, the door switch must be closed, the belt switch must be closed, and the thermal fuse must be OK.
All this assumes the electronic controller is OK, but this is the stuff a handy homeowner can check before calling in the big Sears guns.
Jan 18, 2009 | Kenmore Elite HE4 Electric Dryer
Roper Dryer not Drying
Get a thermostat and place it in the exhaust. The thermostat should reach 160 and then shut down and drop to 120 F and start back heating to 160 again on cotton setting. You should hear an audible click when the thermostat opens and closes. If the dryer is clear of lint and blockages then change the control thermostat which is mounted on the blower housing.
Sep 07, 2008 | Roper REX3614KW Electric Dryer
Dryers Logo
112 people viewed this question
Top Dryers Experts
