Question about Samsung SYNC SGH-A707 Cellular Phone
CELL PHONE FELL INTO THE WASHER
My cell phone fell into the washer as I was loading clothes. Yes, there was water in the tub - it was filling up. Just my luck. Anyway, I took the battery out and the SIM card and I am blowdrying it on cool air. It is a flip phone, so when you flip it open, and look at the screen. you can see water. Any suggestions? I did take the four little screws out; however, nothing released when I did that so I don't know what the screws are for either.
  • tannounet Mar 20, 2009
    my phone went through the washer... i can still use it to call and receive calls.... but my screen is dark, it lights up but theres no image on it.. and sometimes ill have lines of color just comeup and dissapear again....
    what do i do ??
  • Anonymous Mar 20, 2009
    My husband's cellphone was washed in the washer.I callled the cellphone company and was told to buy a new.A co-worker who worked
    for a cellphone company at one time told me to take the battery out and let the phone dry out.Remembering not to try and dry it with a blow dryer.Will the phone still work?
If you have insurance, it will probably cover water damage. The warranty will not. If you want to try to fix it yourself, read on.
Taking the battery out immediately is essential in order to prevent short-circuiting between leads of delicate components or the components themselves. However, the common misconception of then drying all of the circuit boards and components without specifically cleaning out the moisture first will probably ruin your phone. Let me explain. When the circuits get wet, many unintended current paths are created through the liquid. That's why it is important to remove the battery ASAP and leave it off until the repair is finished. However, the most common type of damage occurs after the electronics dry off. Sure, the water is gone, but any dissolved solids in the water remain. These deposits (sugar, coffee, soap, minerals from tap water, etc) remain and dry on the electronics as a hard film that can't be removed. These deposits will affect the digital and radio-frequency circuits of the phone, rendering it junk.
The solution is pretty simple. If the phone gets wet (dropped in a toilet, soda spilled on it, gone through the washer, etc), remove the battery and keep the phone wet (put it in a ziploc baggie) until you can clean it with DISTILLED water. Distilled water has no minerals in it, so it will dry without any residue left behind. DO NOT USE TAP WATER. Disassemble the phone completely, and use a syringe to spray everything off. Pay special attention to the circuit boards, chip leads, ribbon cable connectors, and anything else that looks electrical. Don't be afraid to get the electronics wet. That's what we need to do. The idea is to ensure none of the original liquid is remaining. Once completed, shake off the excess water, and place all of the components in a warm dry place for 24-48 hours. Once dry, reassemble the phone and enjoy it.
I have used this procedure 6 times, and it was successful 5 times. One morning my wife called me and said my son's phone had just gone through the washer. I had her rinse it off under the faucet with tap water to get rid of the excess soap and put it in a baggie to keep it wet until I got home. That night i used this procedure to repair it and the phone worked fine. The 1 time it didn't work, some soda had already dried on the circuit board and I couldn't get all of it off.
Posted on Sep 22, 2008
    Problem Solver:
  • 16 Answers
Bro,
You need to take your phone to a GSM store to have the phone serviced (repaired), However don’t wait to long to do so because the circuit board can become corroded, Another method is if you have tool to open phone you can service the phone with the use contact t cleaner which displaces the water and clean with a tooth brush after this is done, lightly dry out with blow-dryer.
Posted on Sep 16, 2008
4 Suggested Answers
SOURCE: Broken flip
Hello, Verizon has to repair your phone for you!!! I had the same exact problem and they said it was a defective part and that they would fix it... Just go into the store and tel them they have to because it is a known default. I just had to get mad. After i did that i got alot more help. Good luck!!!
Posted on Jan 12, 2007
SOURCE: forgot SIM lock
i forget my sim lock number mobile no 3207647710
Posted on Sep 05, 2008
Ranglo
  • 1194 Answers
SOURCE: how do you remove sim card from a samsung knack?
This phone is CDMA, so it does not have any sim card slot as it has inbuilt system which is directly operated by the service provider.
No other service provider is compatible with this phone.
Good luck
Posted on Jun 17, 2010
Testimonial: "Thanks, now I can just forget this problem."
Lost clothes in Whirlpool top load SM 8525492
There is NO way that any clothing fell over the top of the tub into the sides of the washer, Emily. NO way. It's nearly impossible to believe that you even had enough clothing in there to spill water.
If you stuffed it enough to force clothing over the top of the tub, then the agitator could not possibly have functioned.
Just for the... impossibility... that clothing DID spill over the top, to get them out you would have to pull the dryer out and remove the back and/or the top. You'd see the spilled clothing immediately.
No - no, no, no. I CANNOT believe you overloaded it that much.
Aug 04, 2014 | Whirlpool Washing Machines
My Maytag Neptune MAH1 won't stop filling with water and won't switch cycles...
Your washer has a switch which requires an air tight hose from the base of the tub to that water level switch. As water rises in that switch ,air pressure builds. When the pressure gets just right the switch kills the power to the water valves and starts the motor. So what can go wrong? A hole in the tubing, clogged tubing, loose tubing, or the tubing simply fell off. ea432a0.jpg
Oct 24, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore top load washer 29822800 - washer-selector is set on one rinse- when machine starts the agitator starts immediately as water fills - then when machine stops after spin cycle in off position water...
if you are saying that the washer finishes the load of clothes and timer goes to off and water is filling the tub after this then you have a bad water valve on the back of the washer.disconnect the water lines and change out the valve
Aug 14, 2010 | Kenmore 24032\24036 Top Load Washer
LG Vu phone fell in water and touch screen is not working.
Really your only option is to get a different phone. Since there is water damage it voids your warranty so you would have to turn to insurance. If you don't have insurance you may be able to do an upgrade or you would have to buy one outright. If you can't do that than you can get a prepaid phone and put you sim in that and it will work.
Mar 14, 2010 | LG Vu CU920 Cellular Phone
A pin fell out of the bottom of the washer
The pin is just an alignment pin used during assembly at the factory. You need not worry about it. However the water leaking is a separate issue. The leak could be the pump leaking. But I suspect since that pin was knocked out of it's plastic holder during your move, the suspension traveled enough to damage the hose going from the bottom of the tub to the pump. Come of those hoses were a harder (read cheaper) corrugated plastic instead of rubber. It's an easy fix and I replace those plastic hoses with a rubber one.
Dec 31, 2009 | Kenmore 24032\24036 Top Load Washer
When checking out the lid switch on my roper washer as jsrock suggested in another post, i heard a screw drop from the inside of that area which caused the lid switch to become unmounted completely. also,...
Top lid pull up. Look in seam between top and front cover. On each side you will see where top clips to front cover. Put a screwdriver in there and lightly pry up till clip releases. Front cover will now pull up and be removed, so you could get what fell in.
Jul 26, 2009 | Roper RAS8445KQ Top Load Washer
Neptune washer tangles all cloths
the washer has a balance ring that hold water that is ok. as of the tangleing you may have a low water fill
Nov 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
My phone got wet in the washer machine
When that happened to my phone I was able to open it immediately and set it in an area near my oven to help dry it out. It worked for my samsung phone but not my razor. The samsung was in a front loading washer whereas the razor fell in a (clean)toilet bowl. That may be the biggest difference.
Sep 11, 2008 | Cell Phones
Maytag W-7 Washer water fill does not stop
Yes, I think that rubber tube measures water level. But I've never changed one. Good luck.
Aug 02, 2008 | Maytag Washing Machines
Kenmore 70 Series Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Samsung SYNC SGH-A707 Cellular Phone Logo
1,365 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
