Question about RCA RT2500 System
Powers on and off
The receiver powers on and off on its own. Its irregular. Can be every couple days, hours, or minutes. I've replace the speaker wires with better cables and tried all the connections and different outlets and also other DVD players and televisions. Not too sure what the problem could be. Thank you.
    President:
  • 3,130 Answers
Could be an intermittant problem with the systems remote control. take out the batterys and see if the problem persist. If it dosent then you found your fault and can get another remote at http://www.remotes.com Good luck
Posted on May 24, 2006
My STR-DE945 5.1 channel, works "fine" just a small issue that started to bother me... when i start the thing the 5 speakers have sound (also the bass), but after like 5 or 6 minutes, i hear a...
Commonly your problem is a result in bad thermal connectivity on the power transistors.
Each power transistor is coupled to a heat sink with thermal paste / thermal conductor. When they run hot, they **** more power. There is commonly a thermistor which acts as a protection from blowing out the transistors.
There is probably a transistor that is nearing the end of its life. It will work for a while (when you power up the system) but after a couple of minutes, it starts to **** power, heat up, and trigger an thermistor up stream of the transistor, and it shuts the power stage of the amp off.
This is unfortunately a problem for a technician, or you would need to be armed with a schematic to be able to work with this problem effectively.
Mar 17, 2011 | Sony STR-DE945 Receiver
Receiver fading in and out.
I want to think about this for awhile but first I want to caution you to NEVER turn the volume all the way up and then place your ears near the speakers for diagnosis of an unknown problem. If you inadvertently affect it to come back you can kiss your speakers (and maybe your ears) goodbye.
I'd agree that it is none of your hardware if it affects all inputs, two receivers and multiple speakers.
This sounds like a good one.
The simplest source to use for further trouble-shooting would be FM as it has no external connections, and it's vanilla stereo. Keep It Simple.
"Power bars"? Do you mean like a power strip with multiple outlets and maybe some kind of surge protection? Pare the system down to its most basic form - receiver, front speakers, one power source direct from the wall. What happens? Add components and complexity until the problem returns. Good luck.
Jan 22, 2010 | Audio Players & Recorders
Yamaha HTR-6130 Receiver will not stay on! Shuts
One last try with everything disconnected!
Other than that I suspect internal surge damage.
Aug 04, 2009 | Yamaha HTR-6130 Receiver
MySony str-da5000es is showing error code 11 and shut off by itself after few seconds.check and disconnect all speakers, unplugged power from wall and still showing error 11. am missing something in here...
error code 11 (protector) - According to the manual, 11/PROTECTOR means, "Irregular current is output from the speakers. Turn of the receiver, check the speaker connection and turn on the power again." Most likely, a strand of speaker wire is shorted to the chassis at one of the speaker terminals.
Hope this helps !
Jun 17, 2009 | Sony STR-DA5000ES Receiver
Audio protect keeps turning off my receiver (sony STR-DE597)
That is the common symptom of the defected STK-IC in power amp.section that busted already or just a loose connection.First try to resolder the pins of STK-IC and also all component parts joint in power amplifier section if its works! if not that is the time you replace it, so it works normal again.
Hope it may helps you...
Jun 08, 2009 | Sony STR-DE597 Receiver
Sound turns on and off intermittantly through unit
You may have a bad protection relay or solder joint at the relay mount position. This relay prevents power supply "thumps" when the unit is first turned on, and also shuts the amp down when there is an overload problem....accordianman
May 29, 2008 | Yamaha RX-V661 Receiver
Denon AVR-1905 Receiver
Hi again,
Any new developments?
May 25, 2008 | Denon AVR-1905 Receiver
Altec Lansing M604- Zune is not charging while connected?
I had this problem also...I unplugged the power from the dock for about a minute, plugged it back in, turned it on, placed my zune in the dock and it's been working ever since. Hope this helps someone.
Aug 14, 2007 | Altec Lansing M604 Computer Speakers
Audio suddenly died on my TX-NR1000... but the receiver stayed on
Do you have standby light?If it is not,it is working like PC power supply.If itis notyou have a +13V AC problem (2 gray wire).Check this first.If you dont have it ,Give +13 DC to C9103.You will get standby light.
Aug 12, 2007 | Onkyo TX-NR1000 Receiver
No audio coming from my receiver
my speakers call creative on my computer wont work they use to,i hear sound but not audible
RCA RT2500 System Logo
52 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
