Question about MSI K9VGM-V Motherboard
Not booting I have built a new pc, I turn it on and it does not boot up properly it gets to just before it should display login and then restarts over and over. The harddrive in it is from my old pc and has windows on it and all the drivers from my old stuff. Could that be why or is the motherboard faulty??? Thanks alot Kit
  • Kit Quint
    Kit Quint Sep 15, 2008
    Hi i have tryed using a brand new hard drive, As soon as i press enter to install windows the screen goes top half black and bottom half blue then after a few seconds the whole screen goes blue, After a random amount off time its brings up a red bar like the restart bar but no writing then the system restarts and goes through the whole thing again, Im really good with computers but im stumped the only thing i can think off is that there is a fault with the mother board or maybe even the processor.
    Any further help would be great.
    Thanks alot
  • 6,487 Answers
The problem here is you need to format and reload the operating system and all the software in order for the new motherboard to work with your old hard drive , because you cannot just simply put an old hard drive to a new motherboard without formatting the hard dirve and reloading all software, because a new motherboard needs a fressh installation and fresh operating systme on your hard drive so they will work together..
Hope that helps.........
Posted on Sep 13, 2008
  • Mark Gil
    Mark Gil Sep 28, 2008
    You can also try to reset the BIOS by doing the jumper settings to bring everyhting back to its defaul settings, and trying a different processor will also help so we can isol;ate if this is a problem with the motherboard or with the processor....
    Hope that helps..........
  • Daniel Bakewell Jan 06, 2013
    a reformat might not be required if you don't want to lose data, but usually you need to reinstall windows. you can always use a live cd of linux like Ubuntu to back up your data without effecting the hard drive. The actual cause of your fault is incompatible drivers.
Why I cannot login windows after installed MicrosoftFixit50588.msi
Shutdown your computer and the restart it. When it is starting up hit F12 or it may be F1 or F2 depending on your pc before Windows loads and it should as if you want to boot into safe mode. When it does let it boot into safe mode you will know because the colors and screen will have a very bad display. Login to your computer and navigate to Control Panel > Program and Features > View installed updates and navigate to the hot fix that was installed. Click on the update and then choose uninstall from the top Window and it will uninstall the update. Reboot the computer and it should come up. Cheers!
J the Guru
Oct 14, 2017 | Microsoft Windows XP Professional...
When i turn it on it says BOOTMGR is missing press crtl+ alt +del to restart.
Hello ronnie_fun41, for the CPU to: Find the OS!
Follow these instructions
To get the Computer to "Boot into the 'OS,' and Loading Windows."
  • Restart the Computer
  • Next, just before the [Page] that you mentioned, "Displays," {Press the F12} button.
  • This will open the "Boot Menu:" [Priority Boot Sequence] window.
  • There will be a "list" of (Devices), Optical Drive / CD, SATA / HardDisk Drive, or USB...
  • I do not know the "Configuration of your Operating System" or the Drive: that "holds the Boot [NTLDR] files.
  • It may also hold the "Master Boot Record" or Boot.ini file?
  • So, what you need to do is give the Drives a "Priority Boot Sequence," meaning , you will 'place' the Drives in the 'order' of Bootup [First] listings.
  • You will use the {Arrow buttons} to 'move the "Drives."
  • More than 'likely' it will be the (*Optical Drive / SATA or Hard Disk Drive}.
  • Try each, and hopefully the Computer will make it to "Windows," and you can "Login!"
"Please let me know if you 'need' further assistance; by posting a "Comment 'or' Rating the Solution." Thanks, your 'response' is important!"
Oct 01, 2011 | Acer Aspire One PC Notebook
My Lenovo 3000-N500(Type 4233-79G) (1.5 Yrs Old) will not boot from Battery or Power Adaptor. Both power sources are OK & when both power sources plugged on to this machine, this laptop displays...
Do any lights come on when you press the power button? If not, did you get all the cables reconnected properly? If lights come on or fans come on when you press the power button, then it sounds like the screen has gone bad. That is the symptoms you are describing.
Jun 26, 2011 | Lenovo 3000 N500 Notebook
Reboot and select proper boot device or insert boot media in selected boot device and press a key
Hello cdcrowley2, it seems that the "problem is the [Operating System] is not loading correctly." The CPU is trying to find or fix the 'loading' of the OS!
To get the Computer to "Boot into the OS and "Loading Windows."
If this information helped? Return and give a "Helpful Rating," please!
Thanks, paul7of9
Feb 27, 2011 | Acer Computers & Internet
When i login my system after booting automatically restart
plz boot into safe mode.
steps for safe mode
when you swithch on the pc hit the F8 key when bios screen is comming.
after that you will see boot in safe mode. select it and follow the instruction.
If the pc not restarting now then you have some driver problem.
you have to open device manager and disable one driver at a time and reboot normaly.
Untill you find the problemtic driver.
You have to reinstall the driver when you find it.
If you pc is restarting in safe mode also then try with a new ram.
Aug 18, 2010 | Computers & Internet
Cannot boot on any mode.
get a bootable xp cd boot from cd after booting press r key on the screen u get now xp will start in recovery console now login on it after type the command chkdsk and after completion chkdsk /p after that chkdsk /r exit recovery console restart pc if it doesnt work ur ram module has some problem
Jul 10, 2010 | Microsoft Windows XP Professional for PC
I am working on my friends compaq presario v5000 laptop. i installed xp on it. windows starts up, and after about 20 seconds the screen goes blue, not the dark blue screen with the white writing, a...
Hi
It might be the user profile currupted
try createing a new user and login in user and check it
to Create a New user
goto safemode - login as admin
goto control panal - user accounts
create new user
restart the system and check for the working in new user
Aug 26, 2009 | HP Computers & Internet
I guess it would be the windows one the when you turn it on
This solution will work provided your Administrator login has no password, by default computers will not have a password on the administrator account and typical setup will have you using a seperate login.
when booting up your comptuer after post (the beep) press the F8 key. you should get a display that says Safe mode boot normally ...
Select safe mode. when booted either Type in "Administrator" or select the Administrator login if you get the welcome screen.
from there goto your control panel and select user accounts.
from here you can remove the password for your typical login
Mar 12, 2009 | Acer Aspire 5920-6727 Notebook
HP lap top computer
ok this sounds easy when you were putting in your password in system registry bootup you hit the switch screen to use display video back paralel remove the password and reset the boot process parameters back to default this should relieve your problems
im here if you have any other questions about motherboard bootup
at 9pm arizona U.S.A. time ill be back
May 30, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Acer 3610
I THINK YOU NEED TO UPGRADE MEMORY AND RELOAD YOUR SYSTEM FROM YOUR RECOVERY DISC THAT CAME WITH YOUR COMPUTER.
IF TIS DOESENT WORK REPLACE YOUR HARDDRIVE
Jan 23, 2008 | Acer Aspire 3610 Notebook
MSI K9VGM-V Motherboard Logo
99 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
