Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Machine stopped in middle of wash cycle.
The warsher stopped in the middle of the wash cycle with water still in the basin. I have tried to restart. It appears that no power is available, but power to the site is okay. The washer was purchased in 2001. Any ideas?
  • Anonymous Oct 11, 2008
    Tub fills with water but no wash, rinse or spin (motor inop. Can hear a little humming sound. Tried widgetting with the timer, no help.
I tried jiggling the handle and it worked after much effort. Doesn't work every time though.
Posted on Oct 17, 2008
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 11 Answers
Timer needs replaced try gigling your timer knob and see if you get any reaction dont be afraid gigle it up and down hard sounds like point in timer are burnt
Posted on Sep 17, 2008
Machine stopped in middle of cycle
When this happened to me, my machine needed a new water pump. This may not be your case, but you will need to call a repairman to check it out. I never was able to get my washer door open to get my wet laundry out. Perhaps there is a way to do an emergency unlock, but I do not know of it. Good Luck!
Aug 17, 2014 | Samsung WF328AAW Front Load Washer
Machine stopped in middle of cycle ,wash flashing something on screen, tried to restart wont't run water could it be out of level for it not to run water
It's probably flashing an error code. Write down the code and look it up in the owners manual or online to find out what the issue is.
Aug 17, 2014 | Samsung WF328AA Front Load Washer
How do you go about restarting this model of washers so that it does not stop in the middle of the cycle?
Does the Machine fill up with water properly sounds to me like the fill sensor is stuffed or an inlet valve issue . Try checking the level of your machine some will stop half way through a load because the machine out of balance switch is stuck on.
Jul 11, 2014 | Fisher and Paykel WA37T26G Top Load Washer
Washer does not spin. Tried to start cycle over
If you are getting this code it is because your washing machine has tried for at least ten minutes to drain the water out of the machine. The most likely cause of this problem is that you have a plugged pump filter or you have something stuck in the pump filter.Make sure that you unplug your washing machine.To clean out the pump filter you must empty the washing machine water. The best way to do this is to manually drain the water into a low bucket or basin. Then lay a towel down to catch to remaining small amount of water. Remove the pump filter, clean out any debris, and wash out the filter. Then plug your washer back in and restart the washing machine.Check that your machine is properly leveled. A washer that is too far out of level may not drain properly. Make sure that you are level front to back as well as side to side.This solution will solve your problem
Thank You !!
Jul 26, 2010 | LG Washing Machines
Kenmore warsher, Model num 110.14202300, not drain or spin
The clothes too wet after spin cycle tells me that the water ump is functioning. If it wasn't, there would still be lots of water in the machine when the cycle ended. These Kenmores have the water pump mounted on one side of the electric drive motor and the transmission, drive shaft, and agitator on the other side. The transmission is fastened to the motor by a "coupler", a three piece assy that often breaks. This common failure allows the machine to complete a cycle, however, because of the broken coupler, there is no drive to the tub and no spin or agitate. The clothes seem wet because the spin motion is supposed to provide the force to extract the excess moisture. Leave the lid open and verify that there is no agitate or spin.(During spin cycle use a pen to press down on the safety interlock, a small opening on the the of the machine, toollow the unit to spin with the lid open). If you verify this, flip the machine over and locate the coulper on one side of the motor. One side will be cracked along the shaft. Sears parts stores carry the coupler in stock. ($18.50) Hope this helps.
Jan 18, 2010 | Kenmore 22422 Top Load Washer
Washing machine stops in the middle of washing and then restarts. Machine fills and washes at the same time.
Could be that your discharge hose is causing the machine to syphon off water because there is no Air Break in the system
Test is to hook the hose into a basin and see if it does a full normal wash
Also could be problem with the pressure switch falsing due to a soap build up in the Air Bell on the side of the drum
Jul 08, 2009 | Kenmore Washing Machines
My Sears 500 washing machine stops in middle of wash cycle.
timer problem or maybe the lid switch is going bad. Im curious if the motor is getting hot and shutting down... go to whirlpoolpartssurplus.com call .. ask for mark
Jun 24, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
136 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
