Question about Canon PowerShot SD870 IS Digital Camera
Cannon PowerShot SD870 IS Digital Camera
I haved installed the software, but my camera will not connect with the computer. I have it connected to the USB and the camera. A message say Camera is not connecting.
  • 1 more comment
  • mscbh Sep 16, 2008
    My camera has worked before but now it does not recognize the camera on my mac. HELP!
  • Anonymous Nov 04, 2008
    Loaded the software, but when I try to connect the camera, I get a Windows error saying that the USB device is not recognized. Looks like I'm not alone, and the re is no real solution :-(
  • Anonymous Dec 13, 2008
    same thing it used to work but no longer
  • 489 Answers
I don't know what operating system you are using, and I don't know how to make it work with a MAC sorry.
If your camera won't connect when plugged in via USB cable, then try a different USB port, and a different cable if you can. I have a USB mouse that quits on me sometimes, then I unplug it and plug it back in a few times and it works again.
If that doesn't work, your computer may need a driver for the camera (if you have an older version of windows) or your USB might not even be working... try another USB device in that same slot, does it work?
This could be a computer problem.... hard to say without testing a lot of different things sorry, hope the information above helps.
Good luck from Darntoothysam com (a digital camera repair business)
Posted on Oct 12, 2008
How to transfer pictures from my cannon pc 1249 to computer
try again and do not turn camera on first .
Feb 16, 2015 | Cannon Cameras
"cannon powershot sd870 wont turn on when memory
Please check the memory card with your PC and check if there are any corrupt files within. If so remvoe and format the card , Also so a virus scan and confirm that the Sd card is clean.
Now insert and check. If however the card is found in good condition in the first place then there are errors in the interface to the processor in the camera which might need a technical help from the Canon-service center.
Jan 22, 2011 | Canon PowerShot SD870 IS Digital Camera
When I turn on my Cannon it says that the card is locked. What does this mean and how can I turn it off?
under the camera settings (maybe) or you could plug it into your computer and see if somthing comes up or if there is a lock/unlock button.
Aug 10, 2010 | Canon PowerShot SD870 IS Digital Camera
New cannon powershot driver for snow leopard
Do you really need a driver?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo management program.
Nov 20, 2009 | Canon PowerShot SD870 IS Digital Camera
Camera will not connect with computer to download pictures. I always download my pic with the transfer cable and cannon software-zoombrowser. for some reason the computer and camera will not connect. can...
If you got the Cable and Software CD, you can try to Uninstall the Software and then Install it again, as it may be some software/Dirver fault.
Aug 19, 2009 | Canon PowerShot SD850 IS Digital Camera
I have lost my Digital Camera Solution CD ROM for canon power shot SD1100 IS - is there anywhere on the web that I can download this?
You can download it from Cannon, support,downloads, choose model. This is horrible software by the way. Once you have the basic driver for your model installed(Windows has many drivers pre-installed for many cameras), you are better off using MS picture and fax viewer. It does not have the lengthy and overly complicated stuff that comes with the camera. Anything that comes with the camera for free is usually junk written by grad students to practice their software engineering.
Jul 19, 2009 | Canon PowerShot SD1100 IS Digital Camera
I have a cannon sd870 and every time I take a
Have you tried formatting the card in your camera? Normally for Canons to access this function, first press menu, then select the tools menu, scroll down to the item that states your card's memory capacity and select it. Then follow the on-screen prompts for a "low-level" format.
May 03, 2009 | Canon PowerShot SD870 IS Digital Camera
Not acquiring pictures with any software
don't think it was the cable, they are a standard usb interface cable.
Had a similar problem, when I installed software for a new camera interface.
you can manually open the cannon software once the camera is hooked up to your computer. Its called "camera window" default install is start>all programs>cannon utilities>camerawindow>poweshot>camerawindow
Oct 17, 2007 | Canon PowerShot S500 IXUS 500 Digital...
Canon PowerShot SD870 IS Digital Camera Logo
119 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
