Question about Frigidaire 13.7 cu. ft. / 388 liter Upright Freezer AFFU1466D
Frigidaire freezer not working
Had 4-6 inches of water in basement, now Frigidaire freezer does not work.
  • sbraden777 Jan 22, 2009
    I recently had flooding in my garage due to sump pump blockage. Now top freezer does not work but the main fridge works fine? Any suggestions?
  • 828 Answers
The thermostat may have shorted out so that it is no longer making contact to put power to the compressor. After drying out the components try bypassing the thermostat and see if it will start or make any sound whatsoever. If it does start and run with the thermostat bypassed replace the thermostat. 4-6 inches of water can also get to the relay on the compressor. Replacing the relay and over load assembly also be a good idea.
Posted on Sep 15, 2008
Frigidaire Freezer acting goofy
Make sure everything is clean of debris and I would personally see if you could cool the area around the unit. Maybe use a fan or turn the air down in that room. Humidity and hot temps kill a unit's sealed system.
Jul 24, 2012 | Frigidaire 21 cu. ft. / 595 liter Upright...
I had a flood in the basement where I keep my Frigidaire freezer, model FFU17FC5W3, which left 4 inches of water on the ground. The following day I drained the basement and dried it up and the freezer was...
Welcome to FixYa.
Likely just the start device, the compressor is a sealed unit so the water would not have affected it.
Here's what I'd suggest you try...
If you feel like you can trouble shoot further I`ve provided the following info to assist you or you may decide to call a professional appliance technician as I would suggest.
I don`t know the age of your fridge, but I should mention...
** Most of the manufacturers of fridges have 5 to 10 years sealed system warranty which would include the compressor but not the electrical starting devices i.e., the overload & relay. Check your owners manual, it is the ultimate authority on warranty no matter what anyone else tells you according to.**
If you have a multi- meter you can check the compressor to see if the windings are ok.
**First, Unplug the fridge**
Remove the panel at the back down at the bottom. This should gain you access to the compressor.
On the side of the compressor will be the start relay/overload assembly such as this image...it may be enclosed in a black plastic cover as well.
Pull off the relay & overload and you'll see 3 pins in the form of a triangle...
With a meter measure between any 2 pins at one time, going between each pin with one remaining on a "common" pin.
You'll want 3 measurement's, similar to this example- 6ohms, 3ohms, and 9ohms.
On some meters you may simply get a reading of "0" ohms, as long as the needle moves off of "infinity" which would indicate an "open" winding=not good !
If following that, the readings are good, purchase a hard start kit. Part # HS410 also known as a 3in1 starter kit.
i.e.
The above package contains info and hardware on how to connect it.
NOTE : the HS410 ( 3 in 1 ) should be considered just a temporary "fix" as opposed to an actual "repair" in should not be relied on for long term reliability or safety, but rather thefactory replacemnet, double check with your model number.
Hope that help`s move you forward if nothing else. If so please take a second and rate the reply and a testimony to your inquiry you received here at FixYa.
Thank you and good luck.
Regards,
Macmarkus :)
Mar 18, 2011 | Frigidaire 17 cu. ft. / 481 liter Upright...
Frost build up especially on top shelf all other shelves except one gets a 3 inch layer of ice in approx 4 months. The freezer is kept in a mod temp basement room and the freezer door is opened less than...
Things you can do to cut down on frost.
1.make sure all seals fit flush to frame.
2.use a thermometer and set freezer to -18c(beef will keep upto 12months).
3.wrap all food as airtight as poss.
3.do not overfill,leave space for air flow through drawers/shelves.
4.defrost every 2/3 months in humid conditions using clorine bleach to clean interior,and dry thoroughly.(leave door open to dissipate clorine gas.)
Aug 18, 2010 | Woods Upright Freezer V1613RW3
Basement flooded and chest freezer was down there. Any chance the freezer will work again or is it junk?
Yes it will work again. But I would not trust it. If you do want to use it you will want to let it dry out fre at least one week.
May 25, 2010 | Frigidaire 13 cu. ft. / 368 liter Chest...
Upright frigidaire commercial freezer has no power, we had a flood in the basement. I unplugged it now the the water is gone, it will not power back on. Is there a reset button or did the moror fry from...
Water damage is hard to remove because it could have goten to the electrical parts: motor, compressor, timer, etc.. while it was still running. you need a volt meter to test these parts out no reset sorry
if it was running with water then toss it out...
sorry
call a service guy and he will tell you the same for $80!!! save your money
you can try to raise your freezwer off the ground when you get your new one...
hope this was helpful
Mar 28, 2010 | Freezers
Frigidaire 17 CF upright freezer. We are getting Door Ajar light and beeping but the door is closing and sealing. Not sure what to do? Freezer seems to be operating as usual. Also, not sure this could...
It could be the button that the door hits on when you close the door. If you can take it out and clean the connections it may do the trick. If it really bugs you then you can twist the two wires to gether and it should fix the warning. This means the button switch may have went bad but if you know the door is closed who needs the annoying warning. Please leave a thumbs up. I can only try for you from way out here in the Raz Shack
Mar 14, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My Frigidaire upright freezer is only 4 years old & isn't working
freezers have safety devices to protect themselves. The compressor has an internal overload to keep it from overheating. some have external reset buttons and some do not. either way the cause must be corrected. if the freezer was low on refrigerant you would see signs of oil near the coils, tubing, or compressor. If there is no leak, it overheats when there is airflow restrictions(dirty coils) or a fan has stopped working. only a few screws keep you from seeing all there is to see. If it is clean and the fan is running, then the compressor may just be the culprit
Nov 24, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Freezer forming Ice on the bottom not draining water
pour some hot water in the drain if this does not work use compressed air
Aug 23, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Ice Maker in Freezer in side-by-side not working
CHeck to make sure your freezer is 0 to 5 degrees. If it is warmer than that the water valve wont open to the ice maker. Have you replaced the water filter?
Nov 15, 2008 | Frigidaire Freezers
Water does not drain from the Freezer during the defrost cycle
hi thanks for the question the drain hose goes to the underneath by the compressor thaw out the freezer and clean the drain hose this will solve the problem thanks the appliance doc
Sep 12, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Open Questions:
See all Frigidaire 13.7 cu. ft. / 388 liter Upright Questions
Frigidaire 13.7 cu. ft. / 388 liter Upright Freezer AFFU1466D Logo
335 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
