Question about Worx 10" 18v 2 In 1 Grass Trimmer/In Line Edger
Line continues to advance and wrap around axle
Recently, my Worx grass trimmer is not operating. The line continues to advance and gets wrapped around the rotating axle and becomes tangled. I've tried to re-wind the line but nothing seems to work. The unit will not work in its current condition. Can you help?
I used a file to sharpen the line cutter which controls the amount of line. After sharpening the small cutter on the trimmer, the length of the line is now under control and now my trimmer works just fine.
Posted on Sep 14, 2008
Pineapple leaf jammed under spool housing. How to remove housing to clean out?
Usually the cutting heads have a couple of plastic tabs you push in to release the spool from the head
Mar 06, 2016 | Worx 10" 18v 2 In 1 Grass Trimmer/In Line...
I used it yesterday and today it will not start. Battery is full charge. Button key is in place.
I would first take a meter and test that the battery actually charged. If that tests out fine ( should read at about 12.8 to 13.5 Vdc), I would then check all the wired connections to make sure they did not come loose.
Jul 19, 2015 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
Cutting line either does not advance or it advances to much.
Are you using the correct gauge line? Is the spring properly installed?
Jun 04, 2014 | Worx GT (10") 18Volt Cordless LithiumIon...
Flymo electric power trim..dual auto feed line keeps getting wound around the drive shaft...bloody annoying any suggestions.. Ian (M)
Most trimmers have a cutter on the shield by the spool. This cuts excess line off to prevent it from wrapping around the shaft. If the shield has been removed or the cutter is dull it will allow extra line to wrap around the shaft.
Aug 03, 2011 | Garden
WEEDS ARE WRAPPING AROUND THE MOTOR SHAFT ABOVE THE TRIMMER LINE DISPENSER CAUSING THE MOTOR TO SHUT DOWN AFTER 30 SECONDS OF RUN TIME DUE TO INCREASED FRICTION ON THE SHAFT
That is a common problem with many trimmers... not much you can do about it...except be more carefull and go slower so the weeds fall down before getting caught by the line and getting twisted around the shaft...
heatman101
May 11, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
The moter starts and the line wraps around the head before I can start trim.
Did you wind the string backwards? Check the head it should show which way the string shold be wound.
Jul 02, 2010 | Tanaka Commercial Grade "Inspire" Design...
Grasshog trimmer line wont stop coming out and it won't break off
Rewind your string in the opposite direction than it is wound now.
If it is wound in the wrong direction it will cause the line to continue to feed out.
Good Luck, I hope this helped
Please do not forget to rate me,
Thanks
Apr 29, 2010 | Black & Decker String Trimmer Cordless 12"...
Worx 10" 18v 2 In 1 Grass Trimmer/In Line Edger Logo
494 people viewed this question
Top Worx Garden Experts
Tim Whalen
ray gallant
Wayne McNeil
Are you a Worx Garden Expert? Answer questions, earn points and help others
