I have owned 3 Carver magnetic field power amps in the last 15 years and every one has developed the same problem - one channel cutting out at low and moderate volume ranges. Twisting the volume control back and forth solves the problem temporarily. It seems to this only while in the tuner mode of operation (or maybe it's just that I never listen to CD's or DVD's at low volume :) Any solutions or suggestions greatly appreciated - Leo
  • dsnr Sep 16, 2008
    This is the receiver model MXR 130
  • dtaylor91 May 11, 2010
    Hi, which model Carver are we talking about? One of the receivers?
  • 31 Answers
Ok, the MXR-130 has four power resistors on the tuner board that get EXTREMELY hot. The power connector for the tuner board is right under those resistors. The heat, constant expansion and contraction, and tarnish from heat may have worked the connector partially loose, or started some corrosion.
If you look through the top of the receiver, you'll see a big board that fills up most of the right side. That's the tuner. At the bottom (or front) left corner of that board, you'll se the resistors and connector. If it's like every other MXR 130 I've seen, it'll be noticeable that the board is quite toasted in that spot.
Cleaning that connector, and making sure it is seated firmly, may solve the problem. If not, let me know.
Posted on Sep 17, 2008
I have 2 Sonance Sonamp 260's and I want to bridge them to run two different channels. Although I am not sure on how to do this. I am using my Carver HR-742 and I will be powering 2 Infinity SM-155's. I...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/search?q=Sonance+Sonamp+260
It's not bridgeable according to the manual.
Who specs an amp at 3 ohms anyway? Your Carver might be just as effectively powerful.
May 01, 2011 | Sonance Sonamp 260 MKII 2-Channel...
Need a user manual for a Carver PM 1.5 Magnetic Field Power Amplifier
try this -> http://www.acousticpsychos.com/Files/Carver/carver-pm1.5-pwr-om.pdf
Mar 12, 2011 | Audio Players & Recorders
Carver amp started making a low fluttering sound.
I have a Carver amp which developed a "hum" also. As a troubleshooting step only (long term this is NOT a solution) you can use a ground plug adapter that removes the ground lug from the unit. This is an adapter that has THREE (Line, Neutral, Ground) female sockets for the amp to be plugged into, and TWO male plugs to go into a wall socket. If the buzz goes away, you've got a leaky capacitor in the Power Supply section of the amp. It will take some doing to actually fix the problem, but this will narrow down the cause.
May 27, 2010 | Carver PM950 Amplifier
My Carver M-1.5t is emitting a rapid pulsing sound on both speakers -- low but annoying. I bought it new in around 1983. Is it fixable?
this could be related to the power supply it is the
magnetic field variety that has a thyristor controlling its input check if the voltage supply to the amp outputs is varying when the pulsing is heard. if so
the control curcuit could be at fault.
Apr 25, 2010 | Carver PM950 Amplifier
Carver power amplifier Pm1.5, 110 acv accidentally plug in to 220
magnetic field supplies are different than conventional types, check that the thyristor is working properly
Feb 23, 2010 | Audio Players & Recorders
My turntable connect to Carver Preamp, I bought a
If you can hear music with the volume up, but like it was turned down low (from the power amp), then yes there is something up with it. If it's the same on both left & right channels, then it's something common to both. For instance the power supply, or an IC that has both channels going in it.
If however the power amp does produce sound normally with another device, then either the turntable has a fault, or the pre-amp has, perhaps on the pre-amp inside it for the cartridge.
Dec 16, 2009 | Yamaha P-2500 Amplifier
I have a Carver Magnetic Field Power Amplifier,I turned the power on and heard a pop and I thought I saw smoke?
Does your speakers correct connected? This amp Circuit, burned. Send for repair on Professional Audio Repair shop.
Nov 29, 2009 | Audio Players & Recorders
Best amps for bose 901
You need an amplifier with at least 200 wpc to get the most out of your BOSE. Look into getting a NAD, ADCOM or CARVER amplifier. I prefer CARVER myself. I am running a CARVER M-500T(251 wpc) on my 901's and they sound incredible.
Aug 25, 2009 | Bose 901 VI Main / Stereo Speaker
Right channel cutting out.
connect right channel speakers to amp left out if the problem fixed you will have a problem in amp itself.
if the problem remained you will have a problem in speaker itself test first with new cable and second with speaker cabinet,
Apr 14, 2009 | Audio Players & Recorders
175 people viewed this question
 Grubhead
Grubhead
