Question about Electrolux EW1200i Front Load Washer / Dryer
Electrolux washing machine xc6 aquacycle 1400
We are getting 4 beeps which indicates in the manual that the door is not shut , and yet the door is seemingly shut this was after a fuse blowing and tripping the fuse on the mains board, we have changed the fuse and when the mains switch is on we get the four beeps plus flashing green light non eof the programmes seem to function .
PLS CHECK THE WINDING OF THE DRAIN PUMP THIS MODEL IS A FULLY AUTOMATIC WHEN U SWITCH ON THE MAIN POWER AND STARTS IT ON ANY CYCLE THE PUMP WILL BE THE FIRST ONE TO FUNCTION SOMETIMES THE WINDING IS SHORTED AND IT IS THE CAUSE OF BLOWING OF YOUR MAIN FUSE.ISOLATE THE LINE OF THE PUMP,START IF THE LIGHT JUST BLINK,REPLACE THE PUMP
Posted on Mar 14, 2008
  • 4 Answers
Your retarded... dont talk about a door
Posted on Feb 14, 2008
  • 641 Answers
Maybe that the door is shut "mechanically" but the micro-switch that indicate the control unit that door is shut,is faulty.
Posted on Jul 25, 2007
What could cause Ignition 1 no 2 fuse to blow intermittently
aI dont recommend it but you can try a higher amperage fuse to see if the problem happens. Fuses are really not currently limited, they are there for short circuits, if yours is blowing intermittantly, you might have a connection probelm etc.
Jun 25, 2014 | 2003 Toyota Land Cruiser
Beeping after turning the car off
Check the fuses one may be shorting out. Also check wiring to fuse box.
Sep 08, 2017 | Cars & Trucks
Boards beeps 6-4-4 and nothing happens.
The manual is here:
http://download.intel.com/support/motherboards/server/se7520bd2/sb/se7520bd2_server_board_tps_r23.pdf
There is detailed troubleshooting information within the document.
6 seems like a Keyboard controller BAT test error.
It sounds though that your motherboard may be defective :( Going to have to get a new one most likely, sorry :(
May 19, 2012 | Intel SE7520BD2 Motherboard
I have a Chamberlain Whisper Drive and it started beeping. Reading the manual, it seemed that I needed to replace the battery. It is about 5 years old. Replaced the battery and the LED is no longer red but...
On the back of the garage door opener there is a red button. Depress this button and sync your keypad to the opener. This will re-establish the code and reset the remote.
May 27, 2011 | Sears Craftsman LiftMaster Chamberlain...
My kenmore elite 106.59966803 beeps every two minutes. Doors are shut and the unit seems to be working fine. Any suggestions?
if the refrigerator is beeping -- then this is a sign that the door switch is not working properly,loose or broken.
to stop the beeping --- press and hold the "lock/alarm" button on the control panel until the indicator light turns off. ( this turns off the 'doors open' alarm ) --- now if you get the door switch fixed and you want to turn the 'door open' alarm back on, then press and hold the " lock/alarm " button again until the indicator light come back on.
c...
Feb 15, 2011 | Kenmore Refrigerators
I have a Kia sportage 2000 4x4 the indicator fuse keeps blowing, unfortunately this cuts out the motor. The fuse needs to be replaced to re start the engine. The fuse lasts for a while then blows...
the problem could be coming from the indicator relay as doesn't blow fuse instantly, try with the 4 way flasher on and see if relay get over heated , electronics work in weird and varied ways ,most fuses supply power to more than one function , check what the other function's run from the problem fuse , this will , hopefully explain why the engine cuts out,
Jun 03, 2017 | 2000 Kia Sportage
The door indicating bell will not shut off!
find the fuse panel for your car. look for the relay for the doors. if you are not sure it will be the one that is very hot. remove it and replace it. that should fix the issue
Dec 01, 2009 | 1987 Volvo 240
MAYTAG MAH5500BWW
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
May 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Electrolux EW1200i Front Load Washer / Dryer Logo
415 people viewed this question
Top Electrolux Washing Machines Experts
tom wright
tom wright
jimorris77
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
