HTC Wildfire Cell Phone Logo
Posted on Sep 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i download ring tones for my phone and how do i delete phone contacts
vahid mahmoodi
Level 2:
  • Expert 35 Answers
  • Posted on Sep 10, 2011
vahid mahmoodi
Expert
Level 2:
Answers
35
Questions
0
Helped
7722
Points
105
For downloading the mp3 go to market place on your menu and connect to internet and download all application such as ring tone \ theme\ game and etc
for deleting the contacts you have to go to your sim contacts information and at that place find menu and frome properties try to delete which contact you want
How to remove ringtone from samsung galaxy mega 6.3
Hi . You can go into the google play store and download a free app called ring tone remover . I Have it on my phone . Once installed open then find the ring tone you want to delete and just delete it
Nov 20, 2014 • Cell Phones
2helpful
How do I make the phone ring/ Also how do I delete number's/
Activating Personal Ring
You can assign special ringer tones to anyone in your phonebook. When your phone gets a call, it looks up the Caller ID information in your phonebook. If you've assigned a personal ringer to that number, the phone uses it so you know who is calling. To turn the personal ringing on or off, follow these steps:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the PERSONAL RING submenu.
  2. Move the cursor to select ON or OFF.
  3. Press [Menu/Select]. You will hear a confirmation tone.
Selecting a Ring Tone (Handset only)
You may choose from four melodies or three tones for your phone's primary ring tone. Each handset can use a different ring tone or melody. The available ring tones are as listed:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the RINGER TONES submenu.
  2. Move the cursor to select a ring tone. As each ring tone is highlighted, you will hear a sample.
  3. When you hear the tone you want to use, press [Menu/Select]. You will hear a confirmation tone.
Adjusting the Speaker Volume
Handset Speakerphone: You can choose from six volume levels for the handset speakerphone. To adjust the speaker volume while on a speakerphone call, press the UP Arrow button (to make it louder) or the Down Arrow button (to make it softer).
Base Speaker: You can choose from ten volume levels for the base speaker. To adjust the speaker volume while call screening or playing messages, press [volume +] (to make it louder) or [volume -] (to make it softer).
Adjusting the Audio Tone
If you aren't satisfied with the audio quality of your phone, you can adjust the Audio Tone of the earpiece while on a call. Your phone gives you three audio tone options: low, natural and high; the default setting, Natural Tone, is recommended for hearing aid users. Audio tone adjustments only apply to the earpiece, not the speakerphone.
To adjust the audio tone:
  1. While on a call, press [Menu/Select].
  2. Move the cursor to select AUDIO TONE, and then press [Menu/Select].
  3. Move the cursor to select desired option (HIGH TONE, NATURAL TONE, or LOW TONE), and then press [Menu/Select]. Selected option appears in the display for two seconds, and then the display returns to normal.
Deleting Phonebook Entries
You can delete a single phonebook entry at a time or all phonebook entries at once:
To delete a single phonebook entry:
  1. When the phone is in standby, press the phonebook key.
  2. Find the entry that you want to delete and press [Menu/Select].
  3. Select DELETE. DELETE ENTRY? appears in the display.
  4. Move the cursor to select YES.
  5. Press [Menu/Select]. You will hear a confirmation tone, and DELETED! appears in the display.
Deleting Caller ID Numbers
  1. To delete only one Caller ID number, press the Caller ID button when the phone is in standby, and then find the number you want to delete.
  2. Press [Menu/Select] and select DELETE ENTRY.
  3. When the phone asks you to confirm, select YES.
  1. To delete all the Caller ID numbers, press the Caller ID button when the phone is in standby, and then press [Menu/Select].
  2. When the phone asks you to confirm, select YES.
Note: When you delete a Caller ID number, you delete it permanently.
Deleting a Redial Record
If you want to delete a phone number from the handset's redial list, follow the steps below:
  1. When the phone is in standby, press [Redial/Pause].
  2. Use the UP Arrow button and the Down Arrow button to scroll through the redial list.
  3. When you find the redial number you want to delete, press [Menu/Select] and select DELETE ENTRY.
  4. When the phone asks you to confirm, select YES. The redial number is deleted.
Resetting the Voice Message Waiting Indicator
  1. When you receive a new voice mail message, the new message LED on the top of the handset flashes and VM appears in the handset display.
  2. In the event your message alert tone gets out of sync with your phone company's voice messaging system, you can reset back to its original "no messages waiting" state.
  3. To reset, press and hold [find hs] on the base for five seconds.
  4. A beep sounds and the message alert tone is reset.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
How do i mute ringing on my e71?
To mute the ringing tone instead of answering a active call,select Silence.
or u can try the following
To set a mute ringing tone for a profile, select Options >
Personalise > Ringing tone. Select a ringing tone
from the list, or select Download sounds to open a
bookmark folder containing a list of bookmarks for
downloading tones using the browser. Any
downloaded tones are saved to Gallery.
To play the ringing tone for a selected contact group
only, select Options > Personalise > Alert for, and
select the option similar to none,etc...
1helpful
Where do I change ring tones? I don't want to
Press Menu
go to Settings and tools
then Sound Settings
then Call Sounds
then Call Ringtone
select the one you like.
Other way is on each contact, edit ringtone for that contact.
7helpful
5answers
2answers
On ring tone
is problem is very short u go to contact list and opsion press delet and again same number feed to another name is working any more [email protected] mail meeeee
Ring problem
I suggest that you download ringtones using a computer and using the mobile phones usb cable, transfer the downloaded ringtone to the mobile phone. It is much easier.
Nokia e50 wont notify me when i recieve a new text message
Hello there! thanks for using Fixya.com!
Try the following instructions, to personalize your Nokia E50!
Profiles
Warning: In the offline profile you cannot make or receive any calls, or use other features that require network
coverage. Calls still may be possible to the official emergency number programmed into your device. To make calls,
you must first activate the phone function by changing profiles. If the device has been locked, enter the lock code.
Select Menu > Tools > Profiles.
You can adjust and customize the ringing tones, alert tones, and other device tones for different events, environments, or caller
groups.
To customize a profile, scroll to the desired profile in the list, and select Options > Personalise.
Define the following settings:
Ringing tone — Select a ringing tone from the list, or select Tone downloads to open a bookmark folder containing a list of
bookmarks for downloading tones using the browser. To listen to the selected tone, select Play. If you have two alternate
phone lines in use, you can specify a ringing tone for each line.
Say caller's name — Activate the text-to-speech ringing tone feature. When someone from your contacts list calls you, the
device sounds a ringing tone that is a combination of the spoken name of the contact and the selected ringing tone.
Ringing type — Select how you want the ringing tone to alert.
Ringing volume — Select the volume level of the ringing tone.
Message alert tone — Select a tone for received text messages.
Or you may still go to this website for more info! http://nds1.nokia.com/phones/files/guides/nokia_E50
Feb 15, 2009 • Nokia E50
Need help
Address Book
Contact List
There are two ways to enter Contact List.
1. Tap the [ ] in the idle screen then tap Address Book - Contact List.
2. Tap the [ ] key in the idle screen.
This menu allows you to save and manage contact address information. The
Contacts’ functions allow you to add a new address or search saved contact
addresses by name.
New Contact
This menu allows you to add a new contact address. You can enter contact
address information including name, phone numbers, email addresses, group
information items, memos, ring tones, and image (photograph).
Favorites
This menu allows you to have your own favorite contact list. You can add and
delete it.
Caller Groups
This menu allows you to manage group information. By default, there are 4
groups: family, friends, colleagues and school. You can also configure a ring
tone for a group so that the group ring tone sounds when a call from a specific
contact address within that group arrives and there is no ring tone configured
for the specific contact address.
1helpful
Caller tones
it's in the profiler/contact of the caller
Top HTC Cell Phones Experts
NOEL
NOEL
john h
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
