Question about RCA MM36110 36" TV
Tv will not power up
I have an RCA tv mod.#mm36110jx1, s/n 041410125, Chasis # mmc101gce. tv was turned off(worked normally), attempted to turn on next morning, did not come on, remote no help, power switch on tv no help, power source ok, fuse on circuit board by power plug ok (has continuity), tv is 5 years old, and has been unpluged for about 4 days. is there a reset button somewhere on the chasis? if so where? would appreciate any assistance, Thanks Bill.
  • wilmot728 Jul 21, 2008
    have same problem, time to buy a new flat screen i guess. thanks, this solution was very helpfull and i'm sure it is correct.
  • Anonymous Mar 22, 2014
    TV will not turn on
    President:
  • 3,130 Answers
No reset button ,sorry. The problem you describe is pretty common with this model as its a fault in the horizontal drive circuit or in the main power supply and without the proper service manual as well as the prober tools and equipment this set its not gonna get fixed. there are no panels or user changable boards as it is a solid state set. ptscorp.com could repair this board or exchange it with a referbished board but it would still requir some adjustment that a user may not be able to handle. time to call the pro.. Sorry couldnet help ya more.. Good Luck.
Posted on May 24, 2006
RCA D52W20 HDTV TRIES TO TURN ON 3 TIMES BUT WONT POWER UP
remove all the electrical wire connections from the back of the tv .remove the power plug from the electrical outlet and wait for two minutes and replug the wire and then ckeck.it should work.
reply.
Oct 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Power light flashes 3 times then nothing
this sounds like the typical bad fly-back transformer that is also known as the high voltage transformer, n=-Not really a repair for a novice so unless you know all of the safety notices with this set please do not attempt this repair as why save 100 bucks for something that could seriously kill you!!!!!
Sep 10, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
61" RCA DLP won't turn on after power blip
Hi, thank you for visit fix ya.
Do you havve problems with power supply capacitors.
Replace this:
2200uf 25V, 220uf 25V ( bowed or vented). Located beside power transformer.
Thank you
Jul 26, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA F32650 production May 2003. Was working fine. Turned it on the next day, got no picture and a high pitched whining noise.  Please let me know what I should do to fix it.
If it weren't for the high pitch whining noise. I would say it probably is an internal fuse inside the chasis. It is rated at 1.5 to 2.0 amps. With the whining noise it sounds like a trouble shooting bench
job. Problems occur when a electrical/electronics device is turned on and turned off. Inrush voltage,
when it is turned on, can go up to three times more than normal. This also happens at turn off. Solid state components usually fail at this time. I don't feel that this is a problem that can be fixed in the home.---BBB
Jan 25, 2009 | RCA F32650 32" TV
RCA 36695BC wont turn on
I'm afraid this failure is not just a fuse failure in your TV since you still can hear the relay clicking. This fix might not be a DIY.
Where can I send you additional info on what could be wrong with your TV?
Jul 24, 2008 | RCA F36695BC 36" TV
Rca P52960 with the ptk chasis
It sounds like the flyback is actually defective. The set wont power up at all correct?
May 12, 2008 | RCA P52926 52" Rear Projection Television
Tv will not turn on
the rca itc222 chasis has a processor that shuts the set down when it detects a problem for Safety. it can be one of about 30 problems. the computer also records the errors in memory and a technician can interface with a computer to read these errors. after the set attempt to come on 3 times then the set locks up and you have to unplug to reset.
Jan 05, 2008 | RCA HD52W58 52" TV
Rca p52937sg
Try unpluging it for 15 min.and try it ,if it don't work it might have a leak in your button,it is a simple and cheap repair.I suggest to call your local repair shop.
Dec 23, 2007 | RCA P52937 52" Rear Projection Television
36" RCA TV Wont power up
IP030 Regulator part number 263567/ Regulator overheating
Nov 29, 2007 | Televison & Video
RCA MM36110 36" TV Logo
150 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
