Question about D-Link DP 300U (DP-300U) Print Server
Configuration of DP300u in a LAN over Windows 2000
Dear
I have recently brought one DP300U printer sharer to be used for network printers. The Installed system in PCs in the LAN is windows2000. Kindly advice how to configure.
    Problem Solver:
  • 15 Answers
You just need to installe the . Inset the Printer Driver CD. It will Autoplay. Click on install the Driver.
After successfully installation of Driver, Go to Start-->Setting--> Printers and Faxes
You can find your printer here.Right Click on Printer --> Click on Sharing --> Give the Printer Name in Share Name.
You can installe the printer on client Machine by following way:
Go to Start-->Setting--> Printers and Faxes--> Click on Add Printer --> Check mark on Network Printer-->Clickn on Browse printer. It will Automatically discover your printer. Just Right click on it and clickon connect.
Posted on Oct 03, 2008
Printer network light is blinking. I can't print to it.
If the network light is blinking that means it not properly associated with your network, possibly a change were made on your router's configuration. Press the report button on the printer to check the current configuration. If the printer is configured wirelessly through your router you may need to temporarily hardwire the printer to your router(using a LAN cable) or to your computer(using USB cable) to update the configuration on your printer. For a more detailed instruction on how to re-configure your printer please open the link below:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=115&prodSeriesId=468002&prodTypeId=18972&prodSeriesId=468002&objectID=c01943577
Oct 28, 2010 | HP Deskjet 6980 InkJet Photo Printer
I am trying to install my bizhub c250 through network cross cable with my computer. I adopted almost all the instuctions available for the configuration of the same but could not get a print through...
What you have done should have worked.
You may need to enter the IP address into the printer using the printer console not via the computer printer properties.
If it still does not work check the IP address range of your network card, the printer's Ip address needs to be in the same range, ie the first group of numbers must be the same, only the last group of numbers are different.
You may need to use a LAN hub with normal LAN cables and not a crossover cable.
Jul 23, 2010 | Office Equipment & Supplies
I want to update the firmware on my d-link dp300u print server to version 2.2, how do I do it?
Your type of d-link the highest version is 1.20 which can be downloaded from ftp://ftp.dlink.com/Printserver/dp300U/Firmware/dp300u_firmware_120.bin and updated on your d-link administrator page.
Jul 17, 2010 | D-Link DP 300U (DP-300U) Print Server
Epson sx510w prints using a cable but can't get it to print wireless
The specs for your model Epson allows you to connect the you network by wireless and by LAN cable.
The specs are as follows :-
Wi-Fi Wireless LAN IEEE 802.11b/g – compatible with 802.11n*
*Transmission rate will be limited to 802.11g and will operate in the 2.4 GHz frequency band
Ethernet Wired LAN IEEE 802.3 (100BASE-TX, 10BASE-T)
Other PictBridge
Wireless security
WEP – 64bit
WEP – 128bit
WPA – PSK (TKIP) – compliant with WPA2
WPA – PSK (AES) – compliant with WPA2
To connect the printer by a LAN cable you need to configure the Epson for an IP address that suits your network configuration and connect the LAN cable to your wireless router/hub.
The reason why you cannot print using wireless is because the wireless configuration in the Epson is not setup with the router's wireless configuration ie. SSID WPA encryption etc.
For instructions of setting up a LAN network printer, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3668797-setting_up_shared_network_printer
For instructions on setting up a wireless printer, the Epson wireless settings need to be configured with the router's wireless settings. Go into your router's wireless and note the SSID, and encryption settings etc and configure the Epson's wireless settings with the router's wireless settings. This will allow the Epson to connect to the wireless router. Please click on this link for instructions to secure your wireless network, configure the wireless router (if you have not already do so) and configure the wireless card in the computers and wireless printer (the instructions for configuring the wireless card in the printer is the same as for the wireless card in the computers via the printer's menu screen).
http://www.fixya.com/support/r3559128-wireless_router_security
Feb 07, 2010 | Epson Office Equipment & Supplies
How to connect to network printer hp laserjet 2015 PCL5
I cannot connect to hp laserjet 2015 PCL5. wia network...
im using 64 bit windows 7, and tell me that Windows cant find a driver for HP.........i install driver and nothing........
Jan 18, 2010 | HP LaserJet P2015 Printer
Zebra Z4m+ won't print from Bartender 9.01
BarTender uses its own drivers for each model of printer you must install the correct driver, because there are differences in some commands a printer to another.
Mar 09, 2009 | Zebra Z4MPlus Printer
HP 4550 PRINTER PROBLEM
Go to Control Panel\Hardware and Sound\Printers and add a printer. Select it as a network printer, and stop it searching (unless it finds it of course - which sounds unlikely!) Then click on "The printer that I want isn't listed"
Choose to add a printer using the IP or hostname, and click next.
Type in the IP address of the printer. This can be found by printing out the network configuration page from the printer. The port will be filled in for you. Click next.
The printer should now be added.
Dec 10, 2008 | HP Color LaserJet 4550n Printer
Plz help me am in trouble
Network Configuration page
NOTE The Network Configuration page is only available on the HP LaserJet p2015n,
HP LaserJet p215tn, and HP LaserJet p215nw printers.
A Network Configuration page prints whenever a printer configuration page is printed. You
can also print a Network Configuration page by pressing the network Reset button at the
back of the printer
The Network Configuration page provides information about the network configuration,
including the IP address, firmware revision, network statistics, protocol information, and so
on. The Network Configuration page automatically prints when you print a configuration
page from the control panel.
ENWW Printer information pages 37
Using the HP Toolbox
The HP Toolbox is a Web-based program that you can use for the following tasks:
● Check the printer status.
● Configure the printer settings.
● View troubleshooting information.
● View online documentation.
You can view the HP Toolbox when the printer is directly connected to your computer or
when you are using a supported network connection. You must have performed a complete
software installation to use the HP Toolbox.
NOTE You do not have to have Internet access to open and use the HP Toolbox. However, if you
click a link in the Other Links area, you must have Internet access in order to go to the site
associated with the link. See Other links for more information.
To install the HP Toolbox, you must install the TCP/IP protocol and the most recent version
of the Java™ Virtual Machine on the computer. You must also install the DOT4 protocol for
all USB connections, LPT connections for Windows 2000 and Windows XP, and LPT1
connections for Windows 98 S.E., Windows Me, and Windows NT 4.0. See the system
administrator or computer manufacturer's documentation for more information about
installing the TCP/IP protocol and the DOT4 protocol.
Jan 22, 2008 | HP LaserJet P2015dn Printer
How To Configure FM114P or FR114P for an Internet Connection and Printer Sharing
There are three steps: 1. Configuring the router for Internet access 2. Installing and configuring the print server 3. Adding the printer to the Windows configuration To Configure the Router for Internet Access 1. Connect the modem to the router's Internet port and your LAN computers to the router's LAN ports. 2. Shut down your LAN computers. (Power them off.) 3. Power off the router. 4. Power off the modem. 5. Power on the modem. 6. Power on the router. 7. Start the LAN computers. 8. Enter 192.168.0.1 in a Web browser's address. 9. Type username and password (by default admin and password). 10. Click Setup Wizard to configure the router's Internet access. To Install and Configure the Print Server 1. Install the Printer Server Driver program on a computer. 2. After installation, make sure to select the Run Print Port Setup now box. 3. Click Finish. Print Port Setup runs, showing you the firewall and the printer. 4. Click Port 1. 5. Click Add. A pop-up message says whether a port was created, then the Add Printer wizard starts. To Add a Printer With the Windows Add Printer Wizard 1. Continuing from the last section (or clicking Start > Settings > Printers > Add Printer), click Next. 2. Select Network Printer, and click Next. 3. Click Next again (leaving the port as LPT1). 4. Select the manufacturer and printer model of your printer. (If your printer does not appear, you need to get the CD or floppy that came with the printer, and use Have Disk to specify the file location. Note that it is looking for a file that ends with .inf.) 5. Click Next. 6. Change the printer name to something users on your LAN will recognize easily. 7. If prompted by the Add Printer Wizard about sharing: DO NOT enable sharing! Now test the printer. Other information about Windows configuration is available in Windows help in the article "To connect to a printer on a network".
Feb 19, 2006 | NetGear FR114P Router
Feb 19, 2006 | NetGear FM114P Cable/DSL ProSafe 802.11b...
D-Link DP 300U (DP-300U) Print Server Logo
397 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
