-   i have tried this several times. the bluetooth headset is paired and appears to connect, but it still doesn't work. i believe there must be a problem with the blackberry device because i have paired it with another headset and it still wont work. advice?
-   enm0527
a) Options->Bluetooth->Enable Bluetooth
b) switched on the Moto headset (blue light blinking)
c) options->bluetooth->add device
d) searching for devices....---> here it should find the headset and pair....
If it does not work do the following
After doing the above, do the following:
e). Start the headset. Start with the headset powered off, and hold
the Call button for 10 seconds or so, until the light stays on.
(Initially, the light will flash a few times before getting steady.) If
the light is flashing, or if the light starts flashing anytime during
steps f) through g), the headset is not in pairing mode, and this step
(step e) must be repeated, again starting with headset powered off.
Select the Headset:
f.) Go back to phone, and select "[Look for Devices]." The phone starts searching for Bluetooth devices.
g). Once phone is finished searching, you get a list of one or more devices
under the heading "Scan Results." Select the headset.
h). The next screen will read "Bond With ..headset." Select "Yes."
i). The next screen will be "Enter Bluetooth Passkey." Enter
0000 and select "OK." A screen will confirm pairing and connection. When the pairing is complete, the light on the headset
will flash.
I'm trying to get some Pictures out of my LG CG300 phone onto my comouter. I have a USB cord but I...
(More)
I'm trying to get some Pictures out of my LG CG300 phone onto my comouter. I have a USB cord but I don't have the right driver. I tried Bluetooth, but the pass code "0000" doesn't work. I need help.
I purchased a Gomadic wasll and car charger that says it's for a ZEN MX. When I plug it into the...
(More)
I purchased a Gomadic wasll and car charger that says it's for a ZEN MX. When I plug it into the wass charger I get a blank white screen and then the player is non functional. None of the buttons will work. I had tou use the reset button. Luckily everything came back, but now I'm afraid to even try it the car charger. Is there some problem with using non-Zen chargers?
