Question about RCA 32V550T 32" TV
My tv is having problems
I can watch my picture on my tv for about 10-15 seconds then it all shutts down, but i can still hear sound, what could be the problem?
    President:
  • 3,130 Answers
Jessi your problem sounds like could be a vertical sweep fault or crt drive voltage fault or maybe even a cold solder connection on the filment connections on the flyback transformer or on the crt pc board. I hope Im not talking over your head but if I am Im sorry. It time then if you feel the set is worth it to consult a repair shop for an estiumate as there are really no user serviceable parts inside youe set. Good Luck Ps Is that really your pictuer?? lol
Posted on May 24, 2006
TV PICTURE KEEPS SHUTTING OFF BUT CAN STILL HEAR SOUND
hi
there is somwhere disconnect(circuit) on tv main board that appear when tv get hot
if your tv is lcd try to findout the problem in high voltag board
Jul 18, 2010 | Sharp LC32A37ME 32 in TV
Mitsubishi 52'' TV Model WD52525
U restart the tv,u hear alots of clicking?That mean the Ballast is dead or have problems,that why ur picture lamp not sustaning the picture.Replacing the Ballast might or will sustance the picture.
May 18, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Have flat panel hdtv monitor 1080i samsung no picture or sound
Tv has no picture or sound; will go out while watching. The picture will go into a line and sound and picture will go out; shortly after that tv will turn off. Did this last nite and I did not turn back on until this morning, it worked no problem. On for couple of hours and now it's out again. What could be problem and how do I fix myself
Feb 27, 2010 | Televison & Video
Sony KLV-32M1 LCD TV switches off/on
in this situation autoshutt off in few seconds no sounds and pictures. you have to check the secondary power supply. check all capacitors. budged capacitors can make shutt off sytem. capacitors blown on top due to hot pressure inside tv.
Jul 08, 2009 | Televison & Video
Digital Television sound synchronisation
The pixel problem your having is signal strength related, the sound is always affected first. If your on cable, have them come out and check the signal strength first.
May 17, 2009 | Hisense LHD3206US Television
Toshiba cf32c50 tv will not turn on
This is a typical condition if the power supply has failed or a power-consuming circuit the supply services has exceeded a predetermined current draw. The relay you hear is preventing further damage or even fire.
You will need local tech help with this.
Sep 29, 2008 | Toshiba CF32F50 TV
Tv comes on and shutts off immediately
Did you change any of the 6.8 ohm 1watt resistors with the ICs? That chassis always blows at least two of the 6.8 ohm resistors often four of the 6.8 ohm. And you cant always tell by looking at the resistors , they have to have one side unsoderd and lifted from circuit. There are 11 of them 3149 - 3160 are the 6.8 ohm resistors that need to be checked.
Jul 19, 2008 | Philips 43PP9202 43" Rear Projection...
he was checking to see if the set stayed on with the ICs out if it did the ICs are shorted. Its easier to unplug the convergence yokes and try it but some techs do it differently
Apr 29, 2008 | Philips 43PP9202 43" Rear Projection...
No picture, but power light is on
THE POWER SUPPLY OF YOUR TV WAS THE PROBLEM,YOU COLD SOLDER THE MAINBOARD OF YOUR TV,AND THE CRT SOCKET CONNECT TO THE TUBE IS ALSO COLDSOLDER,.
Mar 13, 2008 | RCA 27F530T 27" TV
Picture goes blank
What type of TV is this unit? An LCD or Plasma?
If it's an LCD, take a close look at the screen with a Flashlight and see if you can see some sort of picture (Almost like a ghost of an image). If this is the case, the backlight has failed.
If it's a plasma unit, you're probably looking at a power supply issue to the panel.
Nov 25, 2007 | Televison & Video
RCA 32V550T 32" TV Logo
65 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
