Question about Pioneer PL-990 Turntable
Cartridge replacement How do I remove the needle cartridge from my turntable?
  • 1 more comment
  • emerysace Sep 13, 2008
    How does needle come off of the head shell? Pull down or straight outward?Tried these two solutions,but didn't want to break anything!!!
    Still did not answer my question!
  • emerysace Sep 14, 2008
    Thanks,Your info helped alot!!!!Emery.
  • 4,472 Answers
You only change the needle on this unit not the cartridge. Needle is about 16$ if you need any other assistance please let me know.
Thanks,
Lee
Posted on Sep 13, 2008
RCA Lawton 841.662 Turntable. How do i get to replacment needles to put a needle on? Can't find any videos on you tube or instruction manual.
The bit in red in your photo is the stylus cartridge and holds the needle/stylus. This part should come off and you replace the whole red cartridge with the new cartridge. In your photo it looks like the needle is missing. See here for replacement:
http://www.lpgear.com/product/RCAS841662.html
Feb 05, 2016 | RCA Audio Players & Recorders
Looking for cartridge/needle/stylus...
If you type Crosley Cartridge into Amazon, the type you need will turn up. Price around $20.
Apr 24, 2014 | Crosley CR6007A Turntable
Numark needle broke
Generally yes. Just type the cartridge number into Google and it should find the right stylus - not needle!!!
Dec 28, 2012 | Numark ttUSB Turntable
I have new belt and needle for kenwood 38r turntable how to install them
Belt is easy, Just remove the base, and change the belt.
Needle change is done by cartridge change. remove the old cartridge and insert the new one with the new needle.
Mar 18, 2011 | Kenwood Audio Players & Recorders
The needle is broken off can it be fixed for less then the turntable cost?
Yes it can. On the head of the arm if you look carefully where the needle (to give it's correct name -stylus) is. What it fits into is a cartridge. If you can see letters or numbers on it that will be the type. If you put that into Google it should find it. You should find if it is possible to buy the stylus with or without the cartridge. Though it's often cheaper to buy both. The cartridge will either be screwed onto the head or just clipped on someway. You will find four wires attached to the cartridge. These will have to be removed if you have to replace the cartridge. Make a note of how each wire attaches to the cartridge. As long as you can get a cartridge to fit the headshell you can use any magnetic cartridge for the job. All you would need to do with a different cartridge is adjust the weight to apply the correct pressure to the stylus.
If the cartridge doesn't have any number etc on it, put the make/model number of the turntable into Google adding cartridge/stylus.
Jan 05, 2011 | ION Audio Vinyl Recording Turntable
Teac P-988 turntable Need to change needle
http://www.turntableneedles.com/search.asp?keyword=211-d&search=GO
don't replace the cartridge. it is "built-in" (not user-replaceable) needle options are at above links. The different prices of the "211" needles are different quality levels. All of which will fit in your cartridge.
Apr 06, 2010 | Teac P-988 Turntable
Can i purchase a needle for the ION ITTUSB ?
Yes but it is not the needle you would buy (ah in the old days it was a needle) but a cartridge
The user manual available here gives you a little more detail.
It is sometimes possible to get the needle assembly for the more expesive cartridges but yoy would need to know the cartridge make and model for that.
If you unscrew the headshell locking ring on the tone arm you can remove the cartridge by pulling it out (hold the arm and the headshell doing this)
This would give you a better idea of the cartridge make and model and also allow you to see how it is mounted (2 screws) to the headshell.
If this information was useful please click
Aug 17, 2009 | ION Audio iTTUSB Turntable
Turntable arm slides across record, Am. D.J.-1500
See what type of cartridge is installed in the arm. Manufacturers use common cartridges in turntables, such as Stanton, Shure etc. Detach the head shell from the arm (it usually slips right off via a locking ring and four-pin mini plug) Look for the manufacturer and model number on the cartridge. No need to remove it from the head shell. On most modern cartridges, the stylus (as they are called, rather than the needle) simply slips off and on. No need to remove the entire cartridge (via screws) and re-align it. In fact, many DJs bring a set spare cartridges and styli on a gig, already mounted in head shells, and simply interchange them as needed. When you have the make and model of the cartridge, go to Radio Shack or use their website to order a new one...or  two. Or go to Google and enter "phono stylus" as your search term. You will find reasonably priced styli for nearly every cartridge imaginable. I operate 50 year-old turntables and am able to find replacement cartridges and styli on line. Ebay also has a number of listings, by make and model of the cartridge. When the new stylus arrives, observe how easily the old one comes out of the cartridge- usually pull and slide - and slide the new one in. Re-insert the head shell on the arm, tighten the locking ring, and you're good to spin!
Jan 06, 2009 | Audio Players & Recorders
REmoving needle from my P-A688 Teac Turntable
THe stylus should just pull forwards out of the cartridge, but with care.
Dec 23, 2008 | Teac P-A688 Turntable
Pioneer PL-990 Turntable Logo
499 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Dennis McCollum
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
