Question about Refrigerators
Fridge is freezing up. not going thru defrost cycle
Frezer froze up we defrosted it. it ran for a few days and same thing happened. it i think is the defrost timer or thermostat
Posted on Sep 14, 2008
  • bev213 Sep 14, 2008
    help
  • 958 Answers
It is one of these 3 parts..
one, defrost heater,
two, defrost timer,
three, bi-metal or thermodisc.
tnx 4 using fixya,
drcool
Posted on Sep 13, 2008
4 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: ice maker making hollow cubes
check your incoming water pressure, change the water filter recently? hollow ice cubes is a sign of low water pressure
Posted on Mar 06, 2008
SOURCE: Fridge freezes contents
Check the door seal is not split,it may be letting air into the compartment
Posted on Nov 14, 2008
SOURCE: evaporator coil freezing over
You are probably correct, the auto defrost sub-system is faulty -- and probably the timer. You'll have to take the back panel out of the freezer to see the defrost timer.
Posted on Apr 29, 2009
Fridge portion doesn't get cold
The defrost circuit is not working, there are usually 3 things that normally go bad, defrost timer, defrost heater, and thermal switch. Would have serviceman check it out as cooling fins on coils will cut you like a razor.
Jul 24, 2017 | Whirlpool Centralpark 25.6 Cu. Ft....
Hi I have a very old KIC fridge freezer the freezer is cold and works well the fridge is not icing up on the back board in the fridge everything going off in the fridge what could be causing this?
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Nov 01, 2011 | Refrigerators
Fridge won't cool but freezer working fine
Oct 31, 2011 | Refrigerators
Freezer cold, fridge not cold enough on high setting
Your refrigerator is not defrosting.
Oct 10, 2011 | Refrigerators
The freezer & refrigerator will either turn on & cool and or freeze but won't shut off. Or they will not come on at all and get warm or thaw.
The newest defrost feature in modern fridges is the electronic adaptive defrost control board. *Maytag has one version, to put this adaptive defrost style of fridge into defrost, short with a small screwdriver between L1 and test on the adaptive defrost board, wait 3 seconds and you should hear a "click" noise from the relay and the fridge will shut off and go through a defrost cycle.
Nov 18, 2010 | Maytag Refrigerators
Coil frozen over, freezer not freezing and fridge inefficient. msd2758gew
The newest defrost feature in modern fridges is the electronic adaptive defrost control board. has one version..to put this adaptive defrost style of fridge into defrost, short with a small screwdriver between L1 and test on the adaptive defrost board, wait 3 seconds and you should hear a "click" noise from the relay and the fridge will shut off and go through a defrost cycle. .
Nov 01, 2010 | Maytag MSD2758GEB Side by Side...
Maytag msd2454gr side by side. The evaporator coils freeze up and the fridge gets warm. This happened about a year ago and I thawed it out and everything was fine. It happened again about a week ago so...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 30, 2010 | Maytag MSD2454G Side by Side Refrigerator
Fridge is freezing up. not going thru defrost cycle we have a side by side ge fridge and it freezes up and we unplug it letit defrost and it will be fine for few days.& then is does it again; we...
The defrost heater must be replaced when the defrost T-stat is replaced.
The main control board located on the rear of the fridge controls defrost sequence.
May 15, 2009 | General Electric GSS25JET Side by Side...
Nov 12, 2008 | Candy CPCA240FFK Bottom Freezer...
Refrigerators Logo
94 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
