Question about Intel Motherboard
Display standby motherboard U8588 Via chipset I install winxp O's when windows open it takes seconds and then the monitor gets blank.what wud be the possible cause....
    Master:
  • 763 Answers
It must be the memory or the RAM. try to remove it and insert it on the other slot. if still happening the same problem then try to use windows xp service pack 2 (thats what im using right now). format it again. hope that helps!
CHARCOIS
Posted on Sep 13, 2008
When i turn on laptop screen goes all black no display
A) Shining a flashlight at the screen at various angles, do you see faint images?
No? Go on.
B) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port on the laptop.
Compaq Presario v3000? Left side towards the rear.
This is an example of a VGA connector (port), and VGA Cable,
http://en.wikipedia.org/wiki/VGA_Connector
Scroll down a little for VGA cable example. Note color of connectors does Not matter.
You can use a CRT type of monitor (Looks like a small TV ), or a flat LCD screen monitor if it has a VGA cable.
http://www.wisegeek.org/what-is-a-crt-monitor.htm
Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By factory default settings, the display should show on the external VGA monitor.
IF not;
There are at least 3 display options;
1) Internal display of laptop monitor ONLY.
2) Internal display of laptop monitor AND external VGA monitor.
3) External VGA monitor ONLY
Press, and hold down on the Fn key, and at the SAME time tap once on the F4 key.
The F4 key is the Display Toggle-Over key.
Still no display on external VGA monitor? (It takes a second)
Hold the Fn key down again, and tap once more on the F4 key.
NO display on the external VGA monitor, suggests a problem with the graphics chipset.
Most of the time it is the Mounting, of the graphics chipset TO motherboard.
The graphics chipset is mounted to the motherboard, with a BGA surface mount.
Ball Grid Array,
http://en.wikipedia.org/wiki/Ball_Grid_Array
Nvidia GeForce Go6150 graphics chipset,
http://www.ebay.com/itm/HP-COMPAQ-PRESARIO-V3000-V3200-LAPTOP-MOTHERBOARD-/390287984982?pt=Motherboards&hash=item5adefa0956
http://www.ebay.com/itm/1PCS-nVIDIA-Geforce-NF-G6150-N-A2-BGA-chip-north-bridge-Chipset-for-laptop-/190695516885?pt=LH_DefaultDomain_0&hash=item2c6656aad5
View an SMT/BGA Rework Station at work, and learn more about the Solder Balls, and BGA surface mount,
http://ersa.com/art-ir-pl-650-346-1472.html
Scroll down a little, and click on the Red -
Take a few minutes to view the IR 650 demo video.
http://www.youtube.com/watch?v=JEpnqhRYGLw
Uploader comment;
"HP Pavilion DV6000 Blank screen fix BGA rework video problem
This BGA rework fix also works on the HP DV2000, DV6000 and DV9000 there are a couple more HP's with this BGA video issue.
This is a design flaw that we solved with our upgraded copper heat sink and thermal compound.
Also effected by this issue are a couple Compaq models. The Comaq Presario V3000 V6000 and a couple of the Pavilion models."
Not showing for advertising of repair. Showing for adding extra copper sheeting material, to the graphics chipset.
A BGA Rework Station is the best method.
The problem, is inadequate cooling for the graphics chipset.
Bad design by HP.
As you can see in the above information, the bottom of the graphics chipset has Solder Balls.
These Solder Balls match up with Copper Pads on the motherboard.
(The Copper Pads are also gold plated)
The graphics chipset is set into place on the motherboard, with the Solder Balls lining up on the Copper Pads.
Heat is then applied at a specific temperature, and length of time.
This action melts the Solder Balls, and solders the graphics chipset TO the Copper Pads.
Which in turn of course, solders the graphics chipset TO the motherboard.
The solder connections made are called Solder Joints.
When the graphics chipset repeatedly overheats, the solder connections partially melt again.
Then the laptop is turned off, and the graphics chipset cools down.
This causes Cold Solder Joints, and a bad contact of graphics chipset TO motherboard.
If this is a problem with your laptop state back in a Comment.
Going on............
IF, the display shows on the external VGA monitor, and is good; the problem is the Video Cable, or inside the Display Assembly.
(screen Inverter or LCD screen)
Let me know after your diagnosis what the outcome is.
1) NO display on external VGA monitor.
2) Display on external VGA monitor.
Post back in a Comment.
Regards,
joecoolvette
Service Manual,
http://h10032.www1.hp.com/ctg/Manual/c01035667.pdf
(The above is a direct link to a PDF file.
The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the link it may take up to 30 seconds, before the first page comes up.
The PDF file will not show until the file is fully downloaded.
IF the link does not work let me know in a Comment.
I will link you the HP Support page it came from )
Mar 03, 2013 | HP Compaq for Presario V3000 Motherboard
P4m80-m4 usb giving 1.0 instead 2.0
You have not mention your Operating System(OS) on your PC System.
To get USB 2.0 support for VIA Chipset Mainboard
1. For Win 98 OS, you have to install "VIA chipset USB 2.0 driver"
2. For WinXP OS you must install, at least Service Pack 1, (recommended you install the lastest Service Pack 3) to to get USB 2.0 support.
3. Install the VIA Chipset drivers for your Mainboard ie "VIA Hyperion 4-in-1 driver v5.12A".
Hope it helps.
Jun 01, 2011 | Biostar P4M80-M4 Motherboard
My computer was working fie. i closed it for a second and when i opened it again the screen was black. the back light still worked but the screen was blank
Try testing it out through your external ports like the vga, svideo (hdmi if you have one) port to a external monitor, or a tv and see if you get anything there. If you are able to get display to a tv, or external monitor through your external port, then you might have a issue with your screen inverter, or loose connection somehwere between your screen and your laptop base. Secondly if you can't get a display to a tv or external monitor using the external ports, or you get the same display like your screen, then your vga chipset is screwed, and you motherboard will need replacement since the vga chipset is solder onto the motherboard. At this point you can either try to replace the motherboard, (which is going to cost you almost or more then a brand new laptop) or decide to go ahead and get a new laptop.
Feb 01, 2011 | Compaq Presario CQ60-220US PC Laptop
Screen goes blank after booting with WinXP SP2 CD.
Hi, your will need to delete your windows XP re format that part of your hard drive, then re install XP
Jul 04, 2010 | Microsoft Windows XP Professional SP2
Usb ports on processor does not work
Click Start
Click Control Panel
Click Classic View
Click System
Click Hardware
Click Device Manager
Expand the "USB Serial Bus Controllers" branch.
Any "yellow" or "red" icons indicate that the device-driver software for your USB ports is not installed, or it is incorrectly installed.
Since your Shuttle motherboard uses a VIA chipset, VIA says:
For Win2K and WinXP, due to licensing agreements, a VIA USB2 driver package cannot be distributed online. Driver support for VIA USB 2.0 controllers requires Windows XP SP1 (Service Pack 1), Windows 2000 SP4, or system upgrade through Windows Update.
So, just run Microsoft Windows Update, and look in the "Optional Hardware" section for available downloads for the USB 2.0 ports on your motherboard. Select and download and install the update.
Dec 10, 2009 | Shuttle MV43VN Motherboard
ASUS P5KPL-AM VIA HD Audio Device not found
I would try the realtek audio driver instead. there are two different audio drivers for that board. Here is the link:
http://support.asus.com/download/download.aspx?SLanguage=en-us
select the socket 775 then look for the p5kpl board then look in the audio section and select the realtek driver
Jul 15, 2009 | Computers & Internet
Computer Does not work correctly with Radeon 9250 Graphics Card
Hmm? Everything except replacing the motherboard, sometimes it does not get any better, but...go into your BIOS and turn off the Gateway splash screen. It will be an option in maybe the first or second menu choice. Make sure your on board video device is disabled and save your options when exiting. Good luck and let me know how it turns out.
Jul 02, 2009 | MSI MS-5185 Motherboard
Getting my video card to work
Hello , Pleas don?t Change any setting in your VGA port Adapter Windows will automatically disable your old or integrated Graphique Card, so set default setting in your configuration then reboot your pc
Jun 12, 2009 | HP Computers & Internet
Problem in install winxp
Your upgrade options
If you want to upgrade your system to Windows XP, the first thing you need to do is verify that it meets the system requirements for the newer operating system.
You will need:
  • Windows 98 or later version of Microsoft Windows operating system.
  • At least a 233Mhz processor. Any manufacturer (AMD, Intel, IBM, VIA, etc.) will do.
  • At least 128MB of system memory.
  • 1.5 Gigabytes of free hard drive space (note that you should have at least 3 gigabytes if you want to do any meaningful work with your system after the upgrade).
  • A CD-Rom or CD/RW drive.
  • Mouse and keyboard (either USB or PS/2).
  • A video adaptor and monitor capable of displaying 800x600 resolution. If you are not sure about this, change the resolution within Windows 98 by right clicking on an empty area of the desktop and selecting 'properties' then going to the 'settings' tab. The resolution slider is at the bottom left. Set it to '800x600' and click 'apply.' If your screen is still legible, you are fine. If the 800x600 option is unavailable, you may need to upgrade your video adaptor before upgrading Windows.
Note that if the screen becomes scrambled, blank or unreadable, you will probably need a new monitor as your current one cannot handle the required resolution. If your system meets the minimum requirements for Windows XP, it's time to find out which version of the operating system you can upgrade to.
This is Microsofts recommendations
Sean
Dec 11, 2007 | NEC PGA370 SIS620 ATX Motherboard...
Still got driver problems ...i guess
hi, this what i think is the problem the operating program your using now is wrong for the monitor coz to my expirience some monitors can't handle winxp,winvista or the other thing is that you have not found the right software for the monitor . Do research good luck
Jul 17, 2007 | Intel SYNTAX S651M SIS651 mATX (SYNTAX...
Intel Motherboard Logo
93 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
