Question about JBL PSW-D112 Speaker
No more thump
My sub powers on, but sounds like no signal is getting to the power amp. it has a pulsing buzz when music is playing. replaced 2200uf 100v caps. temp has efect around Q12 transistor and R15 resistor is missing. looks like R15 was cut out. no cold solders. any suggestions where to check next. nothing looks burnt or swollen. thanks, tboybad
  • 1142 Answers
SOURCE: JLB PSW-D110 Subwoofer Issues
Humming is always caused by low earth resistance so check the earthing.
Posted on Sep 09, 2008
SOURCE: JBL Sub 12 continues to make clicking noise
check the audio amplifiers of the sub
Posted on Jul 13, 2009
  • 5318 Answers
SOURCE: JBL Sub 12 going in and out of standby.
It sounds like a semiconductor device becomes faulty when it gets hot. Check around the parts you have looked at already for a transistor or IC etc. If you find anything wait till the sound acts up and then spray the suspect part with Servisol Freezer Spray. If the sound becomes normal again it's faulty. You can get the spray from Maplin (UK) or Radio Shack USA or that type of shop.
Posted on Oct 11, 2009
SOURCE: no sound from sub. fuse is good and the amp
having jbl speakers but no sounds at all
Posted on Dec 31, 2009
  • 382 Answers
SOURCE: I need a new power amp for a JBL PB12 Subwoofer
Alf, when there is no parts available you have to start looking at local non authorized repair shops that will inspect and repair the board instead of trying to source a replacement board.
This can be very difficult and could make for alot of expensive deposits. Running out of parts is an ongoing problem with all electronics and sometimes replacement is the most cost effective option.
Posted on Feb 09, 2010
I turn it on and at the volume set @ U or straight up(midway) nothing comes out. if you turn it all the way up of course you get alot of buzz and barely get any sound from a mic or mixer signal,etc. could...
Make sure you are using BALANCED line to this... XLR connections boyh ends. Make sure ALL interconnected devices are powered from the same receptacle or power conditioner. Test your cables... they do go bad. This unit REQUIRES line level input. Do NOT expect a mic to drive it directely. Make sure your mixer uses the XLR outputs and is powered from the same receptacle, even if you have to run an extension cord to it. This is a bi-amped speaker so there are independent amps for high and lows. With nothing out and known good in there is very little electronics before the signal is split to the separate amps. At line level, your volume control should probably be about 2 o'clock with the EQ's straight up flat.
Apr 25, 2011 | Mackie TH-15A Active DJ Powered THUMP...
I've had the B&W Zeppelin for about 2 yrs and
the power board has a known defect, contact b and w service as this is a known problem if you have not already.
Apr 29, 2010 | B&W Bowers and Wilkins Zeppelin iPod Music...
Rockford p8002 keeps pulseing. (not a ground problem)
for seeing a out of phaze speaker you would have to run like a 10 hz or lower signal to the amp you might be seeing a optical illusion if they were out of phaze or backwards the speaker would have cancled each other out so it would sound like **** as you said.but anyway it sounds like the amps power supply is bad.put it back in you car and see if it still works like it did befor you put it in your friends may have burned it up.find out how much the amp is worth and if can have it fixed for less then 60% of orignal cost then have it fixed
Mar 18, 2010 | Rockford Fosgate Punch P8002 Car Audio...
Humming sound in subwoofer after it's been playing for a while
It sounds like you are describing an earth loop problem. I won't go into detail in this post, but try an isolation test first. disconnect everything from the reciever except the sub and try connecting say a BATTERY powered mp3 player or cd player to minimise connections to the electrical mains earth. you could also isolate things by taking your sub to a friend's house and trying it on their system.
If it is an earth loop use a process of elimination to find out which two pieces of equipment causes the earth loop. then apply filtering.
you can buy earth loop isolation transformers for about AU$26 and I've used one on my sub myself. Theyhave RCA (phono)plugs on each end and they connect inline with the signal cable to the sub amp.
as for the thumping sound it might be the speaker protection circuitry cutting off the amp to protect the subwoofer speaker from damaged. This might be triggered if the earth loop sound is causing the sub amp to overload and clip.
Failing this there might be a dried out overheated electro capacitor in the amp circuit causing the hum. Hav a chat to your local electronics person, who should be able to spot it!
Hope this puts you on the right track
Happy Hunting!
Jan 07, 2010 | Sunfire Audio Players & Recorders
Loud buzzing from Kef PSW1000 Subwoofer
yes. A good idea. Kill power to the sub, then unplug and remove everything from the sub. go ahead and plug it in again and check for buzzzz.
That is test one. if you have buzz still, its the sub assembly. bad luck, but not impossible. If the buzz is gone its one of the signals to the sub. They can produce a buzzz without any signal coming from your stereo equipment. Replace the feed line, enjoy! BTW...Kef sure does sound clean. good choice.
Nov 09, 2009 | KEF Audio PSW 1000 Subwoofer
Sub making horrible thumping garbage sounds
you need an noise filter in line. It's been a few years since I've had a system but I had the same problem. High power amps like the one you have can actually pick up on the electric pulses from your ignition system. I think I got mine at walmart, or auto zone, somewhere like that. Their pretty cheap too. I don't remember how its hooked up, but If you know how to hook and amp up, this should be no problem.
Jun 23, 2009 | Hifonics Zeus Z400 Car Audio Amplifier
A pulsin sound from the subs
You don't give us much to go on...
Are your subs self-powered? Disconnect the Line In to see if that makes the pulsing stop. if it does there's some kind of signal coming from UPstream or a cable has poor shielding. If it keeps pulsing something's wrong in the sub's power amp(s).
Isolate that much and come back.
May 12, 2009 | Audio Players & Recorders
Only one thump when car is turned on. problem in amp strength or subwoofer?
try pluging in a diff, speaker to the amp see if u get sound.try powering the sub with a home radio just to see if u get sound at all if ur getting sound from the sub then its the amp but u could of damaged it when the amp over heated
May 03, 2009 | Kicker SoloX S10X2 Car Subwoofer
Subwoofer "thumping" w. no audio feed
You need to check your ground connection. If there is a bad ground there will be feedback to the amp and it will just sit there and loop back with the Thump, Thump, Thump sound. I had to wire my amp's ground all the way back to the negative battery terminal. It was a pain but I have never had a problem since :)
Feb 12, 2008 | JBL SCS125A System
JBL PSW-D112 Speaker Logo
37 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
