Question about Cobra 200 GTL DX 4-Channels Base CB Radio
NO TRANSMIT ON ANY BAND... - Cobra 200 GTL DX 4-Channels Base CB Radio
  • JAYMIE5192 Sep 16, 2008
    Tried power mics and stock mic ... No amp draw when keying mic... COBRA IS WELL AWARE OF THIS PROBLEM and their stand is OH WELL...(I'm seeking legal help) If anyone is thinking about buying a COBRA product, I would give it some serious thought first. I was hoping that somebody found a way to fix this problem but it's really hard to find somebody to work on COBRA 200's. I am now looking for a RCI 2970 or at least a 2950 knowing these radios WILL LAST.
The sulution to the problem is simple, you call cobra and tell them you need part# 010-133 Description TRD-16HHF-CA TRANS RD16HHF1. This part costs only $10.00 not including shipping, It's the transistor for the output stage of the amplifier and is a known problem with the radio... It's simple to replace and only takes a very few minutes.. This will fix the problem and get your radio up and running again.
Posted on May 10, 2009
  • 463 Answers
Are you in the USA? Cobra isn't going to care because if it has multiple "bands" of Channels (as described), it is not FCC type accepted for CB use in the USA Therefore, you are running an illegal radio, and griping about "warranty coverage" stands a snowball's chance in hell...
Posted on Mar 24, 2009
Check mike first
Posted on Sep 15, 2008
How come my icom 756 pro did not transmitting on 8000 frequency
You have to modify this radio to operate outside of the HAM bands. You will likely find the modification at www.mods.dk. This is a pretty common and easy modification for HAM radios. Your performance may not be as good as in the HAM bands.
You do this MOD at your own risk. If you are not licensed for operation on ANY frequency or band, you are not legally allowed to transmit. Heavy fines may be levied against you.
Jul 14, 2016 | Icom IC-756PRO Transceiver 002896
I am getting a "Err" message when trying to transmit
Almost always a programming issue. Somehow, the transmit frequency is not enabled or programmed correctly. Always include all the zeros when programming these. The decimal point is critical also.
May 24, 2016 | Yaesu Radio Communications
I have a tk -250 and I can hear everyone talking but when I try to respond to them all it does is beep
Are you sure the people you hear talking are in the band limits of the radio. Generally, when they beep on transmit it's because you're trying to transmit out of band. If the stations you're hearing are near the band edge it's possible you have the "offset" wrong and when you hit the PTT, the shift (offset) in the wrong direction is taking the radio out of band.
Sep 16, 2013 | Kenwood Radio Communications
I have a tk-250 I can receive calls but cant transmit when I go to talk and all it does it beeps what do I do
You may have the "tx offset" turned on and may be trying to transmit on a frequency that is considered "out of band" for the radio. Or the frequency you're attempting to transmit on is simply out of band for that radio. It depends on where in the world you're using the radio. If it was a Euro or Japan radio and you're in the US or South America, the bands are different.
Sep 16, 2013 | Kenwood ProTalk XLS TK-3131 (15 Channels)...
Baofeng UV5RA WILL NOT TRANSMIT
First, it's illegal to use that radio in the FRS bands. Also many of the Baofeng radios have very "dirty" output (spurs, frequency drift, bad modulation, etc). Your best bet is probably to buy another radio. With these radios about 3 of 10 I've tested have been bad.
Jul 21, 2013 | Radio Communications
Baofeng UV5 RA WILL NOT TRANSMIT IN 146 MHZ or 440 mhz bands
It's not programmed right. You can probably find more intelligible programming instructions on Google. Their manuals are not great.
Display says OFF
You are on a portion of the 2 meter band that the radio does not allow you to transmit on. You need to get within the legal band portion and transmit there. The IC-V8000 only transmits between 144.000mHz and 148.000mHz. You likely have the radio outside of that range.
May 17, 2012 | Icom IC-V8000
Will not receive and transmit on 15mtrs and 17mtrs
Hi Seamus,
Is this only on those bands, not an issue with other bands?
If so, then your radio may not be fitted with the correct frequencies to transmit on those bands, they are after all allocated in part to the Amateur operators, which requires licensing to operate.
The fact you can't Tx/Rx, indicates this to be the issue.
I can't help you if you are not a licensed HAM Operator, sorry...
Enjoy the other bands available for your radio.
Cheers,
Peter
May 06, 2012 | Yaesu FT-1000MP Owners Manual
How can i modify the midland 75-822 for more channels?
Modding your CB for more channels puts the radio into Ham bands which you need a license to transmit on, also modding a CB violates FCC part 95 rules and is therefor illegal to transmit with and the hams report most illegal transmitting on there band
Jan 30, 2011 | Midland 75-822 40-Channels Handheld CB...
How do i get expanded freqs on my ft1802 yaesu tranceiver
The FT-1802 is a 50 watt 2 meter FM transceiver. It can transmit anywhere between 144 - 148 Mhz (the FM portion) of the 2 meter ham band. It can receive anywhere between 136 - 174 Mhz without any modifications. There is a modification to enable transmit "out of band" below:
http://www.ham.dmz.ro/yaesu/ft-1802-extended-transmit-modification.php
There are few details about the results of this mod - typically these provide for transmitting on frequencies outside (above, below or both) of the 2 meter ham band. Transmitting outside of the ham band without a proper license for the frequencies in the U.S. is a violation of FCC rules.
Sep 08, 2009 | Yaesu Radio Communications
Cobra 200 GTL DX 4-Channels Base CB Radio Logo
459 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Iron
Iron
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
