Question about Nikon D70s Digital Camera
NIKON D1X Hi I just bought a D1X nikon, in the full manual mode when I change the shutter speed, I can hear no change in the sound it makes when going from 125    to  16K.  However the image gets darker  as I increase the shutter speed.   Is it electronic shutter? Hence no physical increase in shutter speed? Thanks for help.
  • Anonymous Jan 31, 2009
    my d1x also same proublem,cannot go to full manual function&shutter,just use A(f)only.....
  • 62 Answers
The shutter is a copal shutter and it does change . Try 125th speed haer the sound and then change to 1/15th . Also you can tell on your histragram inthe camera or the image on your display .
Posted on Nov 29, 2008
How to change the shutter speed on my nikon n65 film 35mm slr camera
In the manual and shutter-priority modes (set the dial to "M" or "S"), turn the command dial to change the shutter speed. In the aperture-priority mode (set the dial to "A"), turning the command dial changes the aperture and the camera will set the shutter speed appropriately.
If you need a manual, you may download a copy from here.
Oct 13, 2012 | Nikon N65 35mm SLR Camera
Nikon D3100 shutter "problem"?
Are your pictures properly exposed and are they sharp or are your pictures degraded? Is that 1/3-second you describe a delay between the time you push the shutter release and the time the picture is taken or somthing else? Check to make sure you're in the proper shutter release mode (slider switch to right of the mode dial). Also, your self-timer may be turned on. Your camera allows you to set a 2 or 10 second delay from the menus. If it is set to 2 seconds and turned on, it might seem like a 1/3-second delay. If that doesn't help, you camera is covered by Nikon's warranty. Contact Nikon Service at 1-800-NIKON-US (1-800-645-6687) 9AM-8PM EST, Monday to Friday.
Aug 27, 2012 | Nikon D3100 Digital Camera
My nikon d60 just started giving out blurry pictures no matter what setting it is on. The subject must be completely still to get any good shots. It use to not do this, what can I do?
A few basic checks Are you in full auto mode or some other shooting mode? Try different modes and see if any work. Does the shutter speed seem slow - like you can hear it cl - ick. When photographers want a blurry effect, slowing down the shutter is often used. Change mode or set a faster shutter speed. If none of these lead you anywhere, the imaging system that scans the imaging chip may be faulty. that's not a home repair.
Oct 26, 2010 | Nikon D60 Digital Camera
I set this "Nikon 105mm f/2.8G ED-IF AF-S VR Micro-Nikkor Lens" or tried to set it to F2.8 in full manual mode. the F-Stop wandered from F2.8 to F3 / F4.5 depending on where i pointed the lens. I...
You have described Aperture priority mode: you set the f/stop and the shutter speed changes to make the exposure correct.
Full manual mode requires you to set both the shutter speed and the f/stop. You are seeing the recommended f/stop for the shutter speed you have selected.
Sep 25, 2010 | Nikon 105mm f/2.8G ED-IF AF-S VR...
How do you change the shutter speed on a Nikon Coolpix s210? The manual says the shutter speed can be changed, but I can't figure out how. Also, how do you get to "panorama assist" mode?
I can't find in the manual where it says you can manually change the shutter speed. It will change as you select different modes or change the ISO but, I don't believe you can manually change it.
Sep 21, 2010 | Nikon Coolpix S210 Digital Camera
How do you set shutter speed on a nikon n70
In Manual exposure mode, you can change the shutter speed by turning the command dial on the back of the camera.
If you need a manual, you can download one from http://butkus.org/chinon/nikon/nikon_n70/nikon_n70.htm
Jun 14, 2010 | Nikon N70 35mm SLR Camera
Hoe do i set different speeds
In S and M modes you control the shutter speed directly by turning the command dial on the back of the camera. In A mode the dial controls the aperture which indirectly affects the shutter speed. In P mode the dial shifts the exposure to another equivalent exposure, which also changes the shutter speed.
You can download a manual from http://www.butkus.org/chinon/nikon.htm
May 02, 2010 | Nikon N55 35mm SLR Camera
Shutter speed
When you set the camera to "Full Manual" mode, you should be able to dial in your shutter speeds, for most film cameras, including the N55 30 Seconds is the slowest shutter speed. If your camera features a "Bulb" mode, then the shutter stays open as long as you are holding down the shutter release button.
Apr 12, 2009 | Nikon N55 35mm SLR Camera
Problems taking pictures on nikon d1x
There may be something wrong with the camera. Make sure it is set to Single Exposure setting and not Multiples. There should be a control on the top left to change this. Look for an "S". this is what you want. If that doesnt help, you may need to get it repaired.
Mar 01, 2009 | Nikon D1X Digital Camera
Nikon n55 manual mode f.stop and shutter speed controles
There is a downloadable PDF format Nikon N55 manual from http://nikoneurope-en.custhelp.com/cgi-b...  . Thanks to Ands for this tip.
Sep 25, 2008 | Nikon N55 35mm SLR Camera
Nikon D70s Digital Camera Logo
190 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
