Question about Refrigerators
Ge artica model PSI23SC error code hr
My fridge is making a clicking noise, compressor is not running, displaying error code hr. it began working again after 24hrs and then began this cycle 2 weeks later.???
  • 1 more comment
  • msargent76 Nov 07, 2008
    I have the same problem with my GE Profile Refrigerator. The electricity in the refrigerator is pulsing and the compressor is not running. Also there is a light on the control panel display the is flashing "hrs". What does this mean?
  • dlcohen Dec 25, 2008
    I also have the same problem currently. The HRS is flashing inside on the temperature panel and the lights flashing on the water dispenser. Did anyone actually get this issue resolved (and yes, a sub 4-year old appliance)?
  • Anonymous Jan 22, 2009
    me too have the same problem today! flashing water green light at the front and flashing HRS inside the fridge.
    Rang the warranty insurance company this morning, promise that the repairer will ring me within 48hrs. Still waiting...
    My side-by-side is under 4 years old!
  • 87 Answers
SOURCE: Samsung Fridge side by side
It sounds like you have a defrost problem. This will either be the defrost heaters the defrost thermostat or defrost timer. In order to check the heater if you are competent enough you can check that you have resistance across the heater. Alternatively you can rotate the timer (normally in the fridge section abov the thermostat control) around to a defrost cycle (you will normally hear a click) and check to see if the defrost heater kicks in. Please note the cabinet has to be cold in order for the heaters to work. The defrost sensor should also have zero resistance across the terminals when the coil is cold. Please do no attempt the above unless you are practically skilled. A good fridge guy should be able to quickly identify the problem and remedy it. Defrost heaters are generally the first part to fail. Hope this is of some help.
Posted on Sep 11, 2007
  • 23 Answers
SOURCE: ice maker not working
check your owners manual for a water filter, make sure trip arm isn't stuck closed and not letting water in to freeze.
Posted on Dec 08, 2007
SOURCE: ice maker broken
Our is broken as well. Water dispenser works.....
Posted on Feb 24, 2008
  • 74 Answers
SOURCE: GE Profile Artica
The main PCB at the back of the appliance has failed
Posted on Aug 28, 2008
SOURCE: ge ref. making clicking noise not running display not working
Replace the main board on the back my was about a $130 at a wholesale parts store and i put it in
Posted on Mar 06, 2009
The compressor of my GE PFE 29PSDASS floor model comes on for a few seconds then goes off. The lights remain on. What is wrong?
Refrigerator Repair Help ' Appliance Aid
www.applianceaid.com > ... > Refrigerator Help Section
I heard a sizzling noise inside my freezer section and it looked like something ... Myfridge makes a bang noise when it shuts off; My Frost free fridge will not run at all; Myfridge is making screeching/squeak noises; My GE SxS fridge door has ... an amp meter, each compressor is rated in running amps ( see model/serial tag ...
GE Refrigerator Repair Online Manual ' General Electric ...
www.appliancerepair.net/ge-refrigerator-repair.html
FREE ONLINE GE refrigerator repair manual - Diagnose and troubleshoot ... to know basically how the bloomin' thing works, and then get on with fixing it? ... Chapter 5: GErefrigerator problem: Refrigerator is not cold and compressor is ... Do you have somequestions that you would like to ask a professional GE repairman.
Dec 17, 2015 | GE Refrigerators
Have a GE GSS25QSTA Fridge and tonight, smelled weird smell coming from that and then making a sizzling noise?
Sounds like either your motherboard or compressor start relay may be having trouble. For a location Click Here=>
GSS25QSTASS Rear Section, Motherboard and Compressor Components
In this photo you will see location # 801 and 735. Part number for the 801 is=> WR55X10942 and part 735 is=> WR09X10107 Click Here for=> GE/Artica Technical Information and here for a=> Service Manual I will be here to see if the smell and sounds were coming from another location but if for some reason the refrigerator has stopped cooling I believe I am on to the problem. Please rate if correct or if you need assistance and advice on what to do to solve this completely let me know, Thanks, Sea Breeze
May 01, 2011 | GE GSS25QSTSS Stainless Steel
GE bottom freezer began making a clicking noise, will not run
The clicking could be the start relay.If the start relay is bad, the compressor will not start and you will hear a clicking noise in 2-5 minute intervals. The clicking noise is the overload cutting the compressor off when it overheats from trying to start with a bad start relay. To find out if this is bad first unplug the refrigerator. Remove the lower cover from your refrigerator. Then take the cover off that is on the side of the compressor,you will see wires going to this. Now you should be able to see the start relay plugged on to the side of the compressor and unplug it. Now the best way to tell if it’s bad is to shake it. If it rattles, it’s bad and needs to be replaced. If not, most of the time it’s ok. But rather than saying the compressors bad, you might want to replace it anyways because it don’t cost much in most cases (less than $25). If you replace it and it doesn’t work then the compressor is bad and you’ll need you call a repairman. (Note that compressors are very costly and are normally not worth fixing). You can also enter your model # at www.appliancehelponline.com for diagrams and illustrations.
Apr 09, 2010 | GE GDS20SBS Stainless Steel Bottom Freezer...
Clicking noise coming from my fridge, why?
Depending on model number and location of noise I believe with any refrigerator that clicking will come from compressor overload when the compressor tries to start. Certain GE Models that fall into the category of Profile/Artica have motherboards that make the same clicking sounds when they go bad. If coming from compressor then it tells me that the compressor is trying to start. If so and the clicking continues the compressor could be damaged. If you need someone to assist you in repair I will gladly assist you. Sea Breeze
Mar 20, 2010 | GE Refrigerators
Making a clicking noise and not cooling
This could be a relay on the control board or the compressor is short cycling or both. You can use my assistance to help you resolve this or call a technician, this depends on you. I am very familiar with the Artica/Profile and know that if you can follow instructions and use a test meter we can get this fixed. I would like your complete model number so I can refer to the exact model you have. I will leave you contact information and a service manual and a web page to use with the diagnostics. This problem will not get better, Sea Breeze
Jan 26, 2010 | GE Profile Arctica Stainless Steel Top...
GE profile TFHW22R side-by-side fridge compressor issue
Most times replacing the start relay part=> WR07X1001 start capacitor=> WR62X80 and overload=> WR8X97 will resolve the problem. Click here to downlod the Service Manual=>PROFILE ARTICA SERVICE MANUAL CLICK HERE and go to this page to use he Tech Sheet> GE Artica Profile Technical Information If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
Jan 26, 2010 | GE Refrigerators
Ge profile artica not cooling
  • Is the thermostat knob turned to the proper setting? If not, reset it.
  • Next, see if the compressor motor is running
    The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
    If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
    • The compressor
    • The Thermostat
    • The overload, relay, or capacitor
    • The defrost timer
    • The condenser fan motor
    Aug 16, 2009 | GE GSH25JFR Side by Side Refrigerator
    GE refridge temp control makes clicking noise
    probably a few loose ends causing the rattle sounds it does it for most fridges.
    May 11, 2009 | GE GTS22KBP Top Freezer Refrigerator
    Temperature Display, Clicking Intermittent, Lost all Cooling
    unplug the fridge and turn it around so you can see the compressor, does it have a capacitor located on the compressor (a round cylinder with wires comming out of it going to the compressor) it sounds like that could be your problem. They are pretty easy to change just a couple of wiers, just take note of where they go when you take it out. Make sure its unplugged from the wall before you do anything!
    Feb 20, 2009 | Refrigerators
    Refrigerators Logo
    419 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
