Question about Dynasty DGRSC 48-6G Gas Kitchen Range
Dynasty range - oven feature has stopped working
All 4 burners work, BBQ works, griddle works and even the broiler works.
I'm assuming it's a problem with the ignition system since the switch lights up but nothing happens inside - no gas comes out etc..
btw - We have mice occasionally... maybe one chewed through the ignition wire?
I live in Portland Oregon. If this required a professional repair, where do I find one?
Thanks - Bill
  • HBell Dec 16, 2008
    I have the same problem. It started with one of the two ovens and now is happening with both. All range, grill, griddle work just fine. I don't think a mice is at fault for us. I suspect it is Dynasty design issue.
    Sergeant:
  • 409 Answers
It's very possible that the mice may have gotten in but i would say it's the ingnition electrode.
i would have a technician come and take a look. check you local authorized repair shops. shouldn't cost you more than $150.00 to repair it.
Posted on Sep 13, 2008
Whirlpool electric range oven broiler not working
Hello. This is a common failure for this range. Replace part number
9762215, price varies but about $100 average.
Apr 07, 2014 | Kitchen Ranges
Broiler doesn't lite, no gas going to pilot
Most cases Broiler ignitor is out, after you turn on the Broiler, check the voltage on Broiler ignitor 2 wires, if you have approx. 110v, then change the ignitor, but you don't have 110v, then check Broiler safety valve and oven thermostat, but 90% of the time is the Broiler ignitor. Have fun.
Jun 29, 2009 | Dynasty DGRSC 48-6G Gas Kitchen Range
Magic chef gas oven range 6498xvs oven no longer works.
i have a magic chef gas range. broiler work, burners work, fan works when you turn the oven on, but oven does not get hot. could it be the electronic ignitor or does even have one.
May 20, 2009 | Ovens
Can grill be safely converted to griddle on Thermador PRG486GLUS?
http://www.instawares.com/add-griddle-top-2.133-1002.0.7.htm
try this.
If it doesnt fit your specs. then i would suggest u find a thermador parts place and begin to buy the parts for the griddle as replacement parts. find a model of the stove set up that you want and make a list of all the parts that go to the griddle attachment.
My guess is that the reason for the flat "No" on the retrofit was that griddles require a thermostat similar to the one on the oven and broilers do not. So if their is no room behind the face plate where the knob would go then you can't put in a griddle. The other issue might be that the burners for the griddle wont line up with the brackets that are holding up all the broiler burners now. The griddle burner looks exactly like the one from the over only smaller so it has to line up strait where a regular front and back burner have to line up offset. maybe since you have the broiler already that should not be an issue? Then the problem is finding the griddle top it self that is going to be spendy. I think the link i gave at the top is your best bet. good luck.
Leslie
Mar 19, 2009 | Thermador PRG484GGUS Gas Kitchen Range
Oven has stopped working
Bad oven ignitor, to check it, turn on the oven, check Voltage on 2 ignitor wires, it should have approx. 110v, if yes, change the oven ignitor, if not then check oven safety valve of oven thermostat, but 90% is the oven thermostat. also make sure the oven tube is not corroded at the ignitor area, if so, change the oven at the same time. Have fun.
Jan 20, 2009 | Dynasty DGRSC 36-4CB Gas Kitchen Range
DCS 4 burner plus griddle Range..oven doesn't heat
This happened to my DCS when the Hot Wire Relay went out. It isn't an expensive part, but finding someone that knows what needs to be replaced, and then can replace it is hard. My oven also did the opposite and continued to heat without shutting off, and it was once again the hot wire relay.
Jan 11, 2009 | DCS RDS-364GD-SS Dual Fuel Kitchen Range
Thermador Gas Range - Griddle ignition will not spark
I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven work fine. The griddle just stopped working, no spark. Turning on the griddle control, the gas valve opens(hear it), gas flows (smell it), but the ignitor will not spark (no loud or faint spark that I can hear). I got a replacement ignition device (mount at the burner) thinking it might be the problem, but still no spark. I checked the AC voltage at the terminal and measured 39 VAC between the terminal and ground. Not sure if that is the correct voltage. Any insights or advice would be great.
Dec 07, 2008 | Thermador SGS36GS Gas Cooktop
Gaffers and Sattler vintage stove oven pilot 1956 W54 series similar problem
My mother had the same problem with her Gaffers-Sattler range. No one could figure out what was wrong with it. Her local new appliance repair people said to contact J.E.S. Enterprises, Inc at www.theoldapplianceclub.net. Whew; thank God for that tip. They knew exactly what the problem was and repaired the unit for her. The stove is running again like a workhorse! Here is their number - 805-643-3532.
Bob Allen
May 07, 2008 | Garland H283 Gas Kitchen Range
Both ovens do not heat max heat is 150 to 200
good luck.  We have the same range and have had issues with the ovens since the range was installed.  The overn does not heat evenly on convenction or bake.  Thermadore doesn't stand behind the product and neither does the distributor.  They tell us that Thermador isn't standing behind the product so there isn't anything that can be done.  We spent $8000 for an oven that burns the back corners of everything we bake.
Mar 21, 2007 | Thermador PG484GGEBS Stainless Steel...
Dynasty DGRSC 48-6G Gas Kitchen Range Logo
489 people viewed this question
Top Dynasty Kitchen Ranges Experts
Ismael Rodriguez...
Sal DeAngelo
Are you a Dynasty Kitchen Range Expert? Answer questions, earn points and help others
