Question about Samsung CXJ1964 19 in. TV/VCR Combo
TV shuts off when VCR tries to eject cassette
There is a cassette tape stuck in the VCR part. When the TV is turned on, it automatically tries to eject the tape after a few moments, but it won't come out. How can I fix this?
  • 7 more comments
  • Chris Pollard May 23, 2006
    Just wanted to add that when the TV tries to eject the video cassette and fails, it turns off.
  • Anonymous Nov 18, 2007
    I have the same problem w/ mine as well....basically, this unit sucks...any way to fix it?
  • Grandma12 Jan 11, 2008
    I HAVE THE SAME PROBLEM BUT THE TAPE IS NOT IN THE SLOT. THE TV THINKS IT IS SO IT SHUTS OFF. MINE IS AN OLDER MODEL...(APRIL 1998)
  • lovealice May 12, 2008
    my tv wont stay on. shuts off 10 seconds. If I insert a vhs tape it ejects the tape and shuts off. Please help
  • bobmat May 29, 2008
    VCR tape was stuck in unit. A relay kept cycling as if to eject the tape. I disassembled the unit and removed the tape from the VCR. After reassembling the unit, the relay continues to cycle and the capstan in the VCR turns a couple of revolutions each time the relay actuates. Does anyone have any suggestions? Or a diagram?
  • cbmomadkins Jun 12, 2008
    Did any one figure out what to do?? I have taken the VCR apart and I am looking at the guts. The VCR has no tape in it but it will not move back into the full eject posstion. How do you move it back into the eject postion or the ready to take a tape postion?
  • Anonymous Jul 29, 2008
    Put the VHS tape in, the right way. I pressed play and it made a weird noise and then shut off. i turned it back on, pressed eject and it didnt eject. The tv stays on for 10 seconds tops and then turns off again. It sais "eject t" on the top left corner. I have tried to force the video out, but it didnt work. Im preparing to take it apart.
  • Anonymous Nov 03, 2008
    After removing a cassette the TV still thinks the cassette is still there!!! The TV will stay on for only a few seconds.
  • cutie_ehrlic Mar 21, 2009
    the same thing is happening to my tv
    i can turn it on and the display says "eject t" then turns back off after 10 to 15 seconds. i cant force the tape out.
    what do i do?
    President:
  • 3,130 Answers
This is a hard call man. Some combos have to be laid down when taking the back off or it will collapse when you do take off the back, falling over backwards as they are top heavy. These units are so tight inside by means of no room to work so alot of maufacturers have extension cables to attach to componets ie vcr deck and main chassis. After they take them apart. If you really feel confident then lay the set down on its face and take off the back and after the back is off look to see in the deck part if the tape has come out of the cassette or if it all looks normal. If you see the tape out of the cassette ,cut off the tape on both sides and see if the tape will eject. It it does then go back in after and remove the remainder of the old tape. Now it could have been a bad tape but most likly something is wrong with the mechanism. If you cant see anything out of norm, dont try to force the tape out as you WILL cause more damage and most likely unrepairable. Really there are no user serviceable parts inside these buggers so the best advise I can give ya is to disconnect the thing and take it into your repair shop for an estimate!! Good Luck
Posted on May 23, 2006
  • Larry  Dillon
    Larry Dillon Jun 13, 2006
    What you want man a magic wand to fix your problem??? lmao!!
My tv was doing the same thing. As soon as you put in a tape it tries to read it then spits it back out, and every once in a while it will turn off itself. I could never get it to play a tape. I bought it used at a discount because the vcr didn't work. I took it apart and found a little black roller that had fallen off in the tape mechanism. I put it back on and it didn't seem to fix the problem. I gave up and put it back together and tested it one more time and now it works. I can't say if the roller fixed it or I moved something else to make it work , but now it's good as new. This tv is fairly easy to take apart. I believe the roller may have fallen off if the tv was ever upside down.
Posted on May 26, 2008
    Problem Solver:
  • 5 Answers
Unplug the Unit, remove (the 7 screws of and ) the Cover of the Combo , slide (back) out the VCR Tray, remove (the 4 screws of and) the VCR Tray Cover, then remove the VCR Tape by Hand.
If necessary to remove the VCR Tape, plug in the Unit and as the VCR Tapes moves on the Roller Mechanism, help the VCR Tape go out the front of the Unit.
Posted on Apr 04, 2008
    Problem Solver:
  • 6 Answers
I have a TOSHIBA MW20FP1 20" FLAT SCREEN TV/DVD/VCR COMBO and after rewinding the VCR section wouldn't work.  The eject button would not work at all.  The TV would indicate that there was no tape inside when there was.
I decided to take it apart.
You have to remove the six screws on the back at the sides and the two small one by the power cord.
Then you have to detach the red cable that goes around the picture tube (note the way it was inserted) and the sound cable.
Then you have to remove the two screws that sets the base unit with the vcr and dvd to the cabinet.  Be careful not to touch any electronics.  If possible wear insulated gloves so that you don't kill yourself with the capacitors that make the tv image possible.
Turn the bottom part around so that it faces you.
Remove the two screws that attach a metal screen over the vcr assembly so that you can access the spools.  Make note of the position of the screws and use some tape to keep the wire and screw together so that they don't touch anything else.
What you do is push the little lever by the left spool and push it in while at the same time forcing MILDLY the two guides TOWARD YOU that will pull in when the tape is ejected.  I believe that by doing this something loosened and the tape ejected and all was normal once again. Again just pull mildly about 1/8" or 2 mm.  You just want to get rid of any kink that is lying hidden beneath the mechanism that you cannot see.  If this had not worked I would have to have disassembled the whole circuit board and I sure didn't want to do that because you cannot access the screws that lie beneath the tape.
When you assemble the tv once again make note of the little plate by the LINE2 input on the front of the TV (I used some making tape to secure it to the circuit board) and make careful note to get the EJECT MECHANISM coordinated with the door on the tv front or else the door won't lift when you press eject as the tape will hit a closed door.  I know, I did this when I assembled it.
Good luck and please be careful as electricity CAN KILL YOU.
Posted on Oct 15, 2007
I had this same problem, tape got stuck, the vcr would try to eject and make a whirring sound then power off after 5 seconds. What I did was lay the TV on the floor screen down and take the back off, after that it was just easy to take the tape out of the VCR. After that, everything was ok for me, I turned it back on and the tray went back into place, there was no more whirring an it didn't auto power off. -Matt
Posted on Sep 08, 2007
Cheaper to buy another one......
Posted on Jun 13, 2007
    Novelist:
    Champion:
  • 277 Answers
Some VCR may have some rough spots around the inner and outer edges. If such a VCR is used, this unit may reject the tape. To remove these rough spots, rub the edges with a pencil or ball-point pen, etc.
Posted on Jun 13, 2006
4 Suggested Answers
SOURCE:
techman
  • 3130 Answers
SOURCE: samsung tv vcr combo
according to the info I have on that set theres a front panel control key theres also a lcd display?? as I see the picture you may have locked the set with this control key?? if this dosent work go online and look up samsung LTP179DW remote controls or contact samsung directly at www.samsung.com and go to customer assistance. Hope this helps ya!
Posted on Apr 02, 2006
jomaru
  • 337 Answers
SOURCE: TV shuts off after 10 sec
TV/vcr combo units develop problems in the vcr section,what happens is the cassete assembly draws too much current then the tv senses this increase and it says NO and shuts down,you will not be able to use the vcr anyway because it has a problem and the tv will continue to shutdown until the vcr is repaired,I have seen combo units with the tv working only as long as the vcr is not use.Remove the light you have in the opening and hope the tv works fine by itself.Adding a light is not safe.I hope this inf.helps somehow.Good luck
Posted on Sep 19, 2006
  • 3422 Answers
SOURCE: Stuck VHS Tape in Samsung TV/VCR Combo
HI,
Please unplug all the cords of your TV for 4 hours and allow it to reset.After 4 hours plug the cords back in and now try removing the tape.
Let me know the result
Posted on Oct 09, 2008
VHS stuck in Orion tv how do I get it out
https://www.howtomendit.com/answers.php?id=73308
Besides trying the upside down approach, try Sharon's tip at the very bottom of the link.
Quoting:
"I just had a tape stuck in a VCR/TV combo so went on the Internet for help and all other answers were to take the top off the VCR which of course is not possible with a tv combo.
While stuck the the power would turn on it would just emit a low moan-whining noise for a few seconds starting strong then running down and then power off. Couldn't watch TV in that state, it would automatically power off.
So I got down comfortable on the floor eye level with the input slot with the flapping door cover and pressed the power button then quickly with my fingers of one hand inserted them in the tape load slot and using my middle fingers continously began pushing up on the top edge of the cassette in a stiff but quick flicking motion over and over again (like trying to physically force the tape up with intermittent prodding short and quick strokes so it could clear the lip if the eject mechanism kicked in) while simultaneously pressing and holding the eject button with my other hand and after a few tries and 5 or six upward prods on the front top edge of the cassette the eject mechanism activated and spit out the tape.
Sharon
June 2007"
Oct 23, 2018 | Orion Televison & Video
Power goes off when a cassette is inserted. Tried cleaning heads but it won't even run that. When power is turned back on the cassette is immediately ejected.
Good day!!!
Most common problems
  • VCR refuses to FF or REW and shuts off.
  • VCR shuts off entering PLAY or REC or at random during PLAY or REC.
  • VCR eats tapes.
  • VCR doesn't accept tapes or ejects them without cause.
  • Sound is wavery, fluctuating, or muddy.
The cause for all of these is very often a bad idler tire or other dirty, worn, or tired rubber parts
Sep 12, 2011 | Philips Magnavox DVD/VCR Dual Player
A cassette has jammed inside my vcr machine. It will not move forward or backward Can yoy please help
Since the tape won't come out then it means you will have to manually remove the stuck tape. This involves you disassembling the unit in order to help/assist the player get the stuck tape out.
Turn of the unit and remove from the wall, get a Philip screw driver, use it to remove all the screws from the unit and take it apart.
Open the cover and you will see the stuck tape and what's hooking or preventing it from coming out/ejecting.
Now plug the unit, and turn it on. Press the eject button, as the tape tries to come out, support it with your hand so that it can come out.
Or if it happen that the cassette tape has coiled inside the unit, carefully free the coiled tape and the press the eject button.
Lastly, the moment you disassemble the player, you would see what's preventing it from coming out, then you can free whatsoever that is making it stuck press the eject button and the tape should come out.
Make sure the unit is turned off each time you want to remove what's making the cassette stuck.
I hope understand the above explanations.
Good luck.
Mar 04, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Will not eject cassett
try this unplug and then keep finger on eject and plug back in keeping hold of eject if not work then
UNPLUG and take top off video and you will see were the tape is stuck THERE WILL BE A RUBBER BELT ON ONE SIDE OF MECHANISM TURN COGS THAT BELT ARE ON ( USELY ANT-CLOCK ) takes time you will see parts move towards front of video ( IF NOT CHANGE THE DIRECTION TURNING ) the tape will come out when finished
THEN PLUG IN SO VIDEO CAN RESET MECHANISM
Nov 08, 2009 | Cell Phones
Sony slv-960 VCR cassette stuck inside
As your "free service" is not free I solved the problem by throwing the item into the trash.
Jun 25, 2009 | Sony SLV-675HF VCR
CASSETTE STUCK IN VCR WONT EJECT I TURN VCR ON IT STAYS
turn on the machine. use your figure push on the cassette, when you feel the cassette can't go any farther (don't jam it),and hold it there. press the eject button, you may have to try this couple of times in order for the cassette to come out.
the cassette deck need to have the drive belt change.
Apr 16, 2009 | Emerson EWC1303 13 in. TV/VCR Combo
When the tape has been removed the carriage deck will still be in the wrong position. The cassette tray has to be aligned so that the timing of the tape will detect that there is a tape in the machine. At the moment your VCR thinks there is a tape still in it because the cassette tray is not in the full eject position. This can be fixed by a service technician.
Mar 26, 2009 | Emerson EWV401 S-VHS VCR
Vcr tape stuck in unit
Marvin,
I am not registered here as an expert, so there should not be any charges. I do not have the option of chatting I am guessing only the registered experts have that. Here goes: 1. Take a phillips screw driver and remove all the screws that are holding the case on, there will be some big ones on the sides and a few maybe smaller ones on the back. 2. Lift the the case off 3. You should see the tape on the inside the vcr 4. You may or may not have to remove some of the metalic shielding which should be only anywhere from 4-6 screws if you have a piece of metal directly over the vcr tape some have them some do not. 5 Gently pull the magnetic tape up from around the feeder posts and the drum. 6. Try and work the vcr tape up and out, If you are having extreme difficulties with this try plugging the vcr back up and pushing the eject button while still holding the magnetic tape. The tape should eject now and you and carefully pull it out. 7. When you get the tape out, use your thumb to push up and turn one side of the white reals on the tape to slowly wind the magnetic tape back inside the tape. 8. Unplug the vcr again and replace everything that you had to remove and replace the cover.
I hope this helps and let me know if you need further assistance. And since I am not a registered expert here there should be no charge for this help unless you chatted or got help from one of the registered experts.
Jul 05, 2008 | Samsung DVD-V5500 DVD Player/VCR
TVSC1320 13 in. combo from January 2000 VCR Tape is Stuck
i took mine out with 2 butter knifes. 1 pressing on each side of the tape forcing it outward while pressing eject at the same time
Dec 23, 2007 | Zenith TVBR1330 13 in. Combo
Help!
My guess is that the prisim broken or led (light emitting diode) below it has failed so the vcr is stuck in an endless load...
It will have to be taken apart and the tape in it manually unloaded by turning the load motor counter clockwise. Then visually inspect the prisim and test the diode.
If any of this sounds too foreign take it to a good shop and they'll have it back and running in no time..
Hope this helps!
Bill
Nov 14, 2007 | Philips CCC132AT 13 in. TV/VCR Combo
Samsung CXJ1964 19 in. TV/VCR Combo Logo
2,130 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
