Sharp Aquos LC-2640u, color problem
My daughter slammed a door near tv, tv is on stand not wall mounted. The color is really off. Orange face, green hair. Adjustments can only change , but do'nt fix. Geek squad sent tv to sharp, firmware did not fix. They said 900.00 to fix, bad scaler board. I'm handy, ebay board 120.00. Does this sound like the right fix. Thanks Randy
motaro
  • 449 Answers
SOURCE: advised by geek squad , virus on hp computer
get lost, u are to careless for misplacing the document i cant help you.FOOL
Posted on Jul 05, 2008
freetek
  • 5568 Answers
SOURCE: green vertical line on the right side of screen
Warranty still alive?
Hope so; the problem could be an expensive one.
The screen appearance is controlled by allowing light from a backlight through by turning pixels off and on.
This switching is done by a matrix that turns on vertical and horizontal pixels of the right shade at the right time to produce the image you see.
One of the control elements for the vertical that controls the transmission of green light from the backlight, has died (no longer switching off and on when told) and these are normally a part of the LCD screen assembly itself and not easily replaceable.
I would be talking to Sharp - this shouldn't happen in 6-7 months of use.
Posted on Jul 09, 2008
StuartB
  • 807 Answers
SOURCE: Geek Squad Backup Disks
Usually you just put the first backup disk in the CD/DVD drive and restart/reboot the computer.
If it does'nt boot up you have to go in to the bios settings and change the boot sequence so that it boots from the CD/DVD rom instead of the Hard Drive. When it's finished the restore task you can either leave the bios settings as they are, or change it back to boot from the Hard Drive. Sometimes the backup/restore disks will put the PC back to the same as the day you bought it, which means completely wiping the Hard Drive and reloading the Operating System (Windows) and any programs that where installed at the time the disks were made. If you can run the backup/recovery from within Windows there will be a program in the Programs list on the Start menu. That way you usually keep anything that you have added since you bought the PC and it just reinstalls the Operating System to restore it back to it's original condition.
Hope this helps.
Posted on Jul 18, 2008
  • 36 Answers
SOURCE: Shorted Capacitor on LC 03 Scaler Board 3139 123 5680.4 v1 wk 319.5
BEAD 100MHz at 120ohms
Part# 242254945333
Posted on Aug 20, 2008
INTERLOGIC
  • 326 Answers
SOURCE: Speakers not working after geek squad installed new hard drive.
check the corresponding drivers
Posted on Apr 19, 2009
NEED BASE STAND FOR A SHARP LC-46SV50U
Go to shopjimmy.com and get a universal stand. It attaches to the back of the TV just like a wall mount.
Mar 30, 2013 | Sharp AQUOS LC-46SV50U 46" 1080p LCD TV -...
Looking for a stand for Sharp Aquos LC-2084U-SM
Nov 08, 2012 | Sharp Aquos LC-20B4U-S 20 in. LCD EDTV
Can't find tv stand for Sharp Aquos LC-32D44U
You can get a universal stand from shopjimmy.com. It attaches to the back of the TV just like a wall mount.
Aug 15, 2012 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Sharp Aquos LC-45GD4U - looking for the stand neck and stand crews
I've just listed the stand for LC-45GD4U at TVPartsGuy.com if your still in need.
May 19, 2012 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
Have sharp quos 52" screen went pink. Can still
Hi, My guess is your daughter messed it up. Go to menu and color and reset to default should fix it.
You may have to adjust color for your best viewing. Good luck.
Sep 27, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Missing parts for stand. Can parts be purchased?
I'd check on eBay. Many people will remove the stand and mount the TV to a wall or to a console stand. Discarding or selling the original stand. You can usually get them for far less than you'd pay for replacement parts.
Good luck,
Mark
Apr 02, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Is the Sharp LC32D47UT 32-Inch LCD HDTV suitable for use in Australia
Quite possibly as it can cope with NTSC and PAL
The elegant AQUOS® LC-32D47UT easily enhances the decor of any family room, living room or den. With a 16:9 aspect ratio, HDTV resolution of 1366 x 768 and breathtaking color purity, it is a next-generation TV to carry you into the high-definition future. The LC-32D47UT features a high contrast ratio, 6ms response time and wide viewing angles. The LC-32D47UT includes built-in ATSC/QAM/NTSC tuners, 3 HDMI™ and 2 HD Component Video inputs as well as a D-sub, 15-pin input for PC compatibility. The LC-32D47UT features a black cabinet, and the included table stand easily removes for wall mounting applications.
Features
  • True 16:9 - widescreen aspect ratio with 1366 x 768 HDTV resolution.
  • Built-in ATSC/QAM/NTSC Tuners - provide access to DTV and available analog TV channels.
  • High Brightness - Sharp LCD TVs are very bright, so you can put them virtually anywhere - even near windows, doors or other light sources - and the picture is still vivid.
Jan 08, 2011 | Sharp 19 in. LCD HDTV
Can not remove the stand to mount it on the wall
If the Aquos 46 is anything like the Aquos 42, the monitor is attached to the base with machine screws (bolts). They are located in the lower back portion of the monitor, probably need an Allen wrench to loosen and remove. Once that is done, the base can be removed from the monitor. Best way is to lay the monitor face down on a tabletop padded with foam, a quilt or blanket, etc to protect the screen as you work. Remove the stand from the monitor, not the monitor from the stand; it is easier and safer that way.
Jan 18, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos 37 inch LCD HDTV - black trails on picture when hot
LCD LAG COMPENSATION CIRCUIT? never heard of that, dosent mean it dosent exist, you may have a LCD driver board issue, never seen the trails thing on Aquos, have had to update the software on many of these critters though.
Jul 07, 2007 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
