any idea where i should look to repair this? turned ice maker off and stopped leaking. turned back on...and continued to pool up at bottom of freezer compartment.
Comments:
Sep 19, 2008
- Thanks for the idea. I looked at discharge hose and appears to be over ice tray. Almost seems like the leak is coming down the back interior and then leaking out of vent holes, but I can't see any active drips.
-   My water comes down the back of the freezer, no where near where the ice mold fills up. I can see it running at the bottom of the freezer through some vent type openings. It pools up in the bottom of the freezer and freezes. I have a Kitchen Aid.-   coachbjl
Nov 17, 2008
-   I just found this website with the exact same complaint as mine. I figured its has been seen before. My water spills are sporadic but significant with alot of ice forming at the bottom of the drawer compartment of the same side. I was thinking that the ice may periodically not exit the ice tray when dumped which would lead to an overfill. I've called a service guy in hopes that he would have an idea for a fix.-   jfhdds
Sep 30, 2008
-   Water leaks from icemaker and "freezes" the ice bin into the refrig. I checked everything but there is so much ice inthe back it is hard to tell...I guess I will need to defrost and check agina-   rckhydn
check the water discharge hose which fills the ice maker after ice is dumped into the bin. the line is located in most cases at one end of the ice maker and allows the water to flow into a funnel like device above the ice maker mold. the hose has the diameter of a penny, it is probably misaligned with the ice maker itself/
Was this helpful?
Yes
No
Popular Solutions for Samsung RM255LASH Side by Side
my side by side refrigerator SR-S22DTC control panel changes temperature by itself what could be the...
(More)
my side by side refrigerator SR-S22DTC control panel changes temperature by itself what could be the problem and how you you remove the control panel.
I change my water filter, and when I try to reset the change filter indicator light on the front...
(More)
I change my water filter, and when I try to reset the change filter indicator light on the front door, after touching the light for 3 seconds the light never change colors.
Lost power to the house but when power came back on, the control panel flashes with 98 on the left...
(More)
Lost power to the house but when power came back on, the control panel flashes with 98 on the left and A8 on the right. can not control or reset panel
ice not dispensing and the frozen food and ice are slowly melting.... fridge part is okay..this is...
(More)
ice not dispensing and the frozen food and ice are slowly melting.... fridge part is okay..this is for the samsung quattro..thanks
